Lightning and Domoticz
SweetPants
Domoticz version: V4.10069
Re: Lightning and Domoticz
Post by SweetPants » Thursday 07 September 2017 12:31
DutchHans wrote:
Wednesday 06 September 2017 22:18
Confirmed..
Regards, Hans
Edit:
Working again
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
SweetPants
Post by SweetPants » Thursday 28 September 2017 21:54
http://www.onweeractueel.nl/domoticz_bo.json returns 'null' again
Edit: and fixed again as of 10:00 AM
EdwinK
Target OS: Raspberry Pi
Post by EdwinK » Thursday 23 November 2017 22:37
And 'nill' again I just noticed
Running latest BETA on a Pi-3 | Toon Thermostat (rooted) | RFxcom | Dashticz V2 |
phoenixblue
Domoticz version: 3.7392
Post by phoenixblue » Friday 24 November 2017 21:56
What time do you have received that value?
scripts on github: Link
EdwinK
Post by EdwinK » Friday 24 November 2017 22:53
Sometime yesterday. Can't remember now
EdwinK
Post by EdwinK » Sunday 10 December 2017 11:10
Today again I got a strange reading
x2017-12-09 22:00:00 1
2017-12-09 23:00:00 18446744073709552000
2017-12-10 00:00:00 0
Derik
Post by Derik » Saturday 30 December 2017 16:24
mmm i did a dist upgrade on my dietpi...
After that the python script is not working any more...
Someone have a solution for me?
How can i check python is running?
or how activate i python?
or what package do i need to install??
SweetPants
Post by SweetPants » Saturday 30 December 2017 18:14
What error messsages do you get when started from cli?
Derik
Post by Derik » Saturday 30 December 2017 20:17
hope i do it on the good way:
root@DietPi:~# cd /home/domoticz/scripts/python
root@DietPi:/home/domoticz/scripts/python# ./onweer.py
Segmentatiefout
phoenixblue
Post by phoenixblue » Tuesday 16 January 2018 0:46
Small update : Meanwhile I have rebuild the server script to solve the problem when there is an lot of activity to not crash the temp file.
But unfortunately it not works, so I'm try to filter some parts of EU in seperated files so I hope this will do the trick.
freijn
Post by freijn » Tuesday 16 January 2018 10:28
Derik,
Why are you logged in as root ?
please start the script like :
cd to the script dir like cd /home/domoticz/scripts/python
then do
pi@DietPi:python onweer.py
whats the output or hte last lines it is complaining about.
Also, could it be you moved to a newer python version?
please do python -V
Cheers,
Frank
Derik
Post by Derik » Tuesday 16 January 2018 21:27
mm
Did install domoticz under root... :-)
Now i did a clean install and everything is working fine..
I think my os on my odroid fucked up..
Today count 36 ....
So good work thanks!!!
freijn
Post by freijn » Thursday 18 January 2018 17:15
Welcome to the wonderfull Domo world :-)
Derik
Post by Derik » Tuesday 23 January 2018 19:43
MM
Thanks for the options..
Only can i use it with the intern Domoticz py option? [ by the blockleys part there is PY option ]
So the script is in de DB fro Domoticz??
More friendly... everything in DB from Domoticz
So a backup ....:-)
phoenixblue
Post by phoenixblue » Saturday 19 May 2018 8:26
For those are using the lightning script, the Json file location is switched because some safety guidelines.
So it's changed to -> https://www.onweeractueel.nl/domoticz_bo.json
EdwinK
Post by EdwinK » Sunday 27 May 2018 16:40
So, now I finally had time to check on this again, and...
sudo python3 Onweer.py
Found 1 matches -- Sun May 27 16:36:06 2018
  File "Onweer.py", line 53, in <module>
    (server, port, deviceIdx, value))
  File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 612, in send
    adapter = self.get_adapter(url=request.url)
  File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 703, in get_adapter
    raise InvalidSchema("No connection adapters were found for '%s'" % url)
requests.exceptions.InvalidSchema: No connection adapters were found for '192.168.0.11:8080/json.htm?type=command&param=udevice&idx=159&svalue=1'
EdwinK
Post by EdwinK » Tuesday 29 May 2018 20:20
Getting the script from Phoenixblue's git page made it work again.
Hmm.. Not really. Still doesn't update the counter :(
FrankVZ
Post by FrankVZ » Tuesday 29 May 2018 21:39
Hi I get this error too (anyway: looks very similar).
Domoticz @Synology DS214+,
Python installend + python 2+ 3 (Additional packages).
Running from CLI (putty):
De py script runs but no respons at all (like freezes).
After a ^C you get the notification of the amount of strikes,
another ^C gives some other recent calls (?)
The file /tmp/last_lightning.txt has been made, but it just containers one number.
  • admin@DS214plus:~$ python /volume1/@appstore/domoticzscripts/lightning.py
    ^C:
    Found 2400 matches -- Tue May 29 20:30:17 2018
    0 old matches were ignored -- Tue May 29 20:30:17 2018
    ^CTraceback (most recent call last):
    File "/volume1/@appstore/domoticzscripts/lightning.py", line 96, in <module>
    File "/usr/local/lib/python2.7/site-packages/requests/api.py", line 71, in get
    File "/usr/local/lib/python2.7/site-packages/requests/api.py", line 57, in request
    File "/usr/local/lib/python2.7/site-packages/requests/sessions.py", line 475, in request
    File "/usr/local/lib/python2.7/site-packages/requests/sessions.py", line 585, in send
    r = adapter.send(request, **kwargs)
    File "/usr/local/lib/python2.7/site-packages/requests/adapters.py", line 403, in send
    timeout=timeout
    File "/usr/local/lib/python2.7/site-packages/requests/packages/urllib3/connectionpool.py", line 578, in urlopen
    chunked=chunked)
    File "/usr/local/lib/python2.7/site-packages/requests/packages/urllib3/connectionpool.py", line 385, in _make_request
    httplib_response = conn.getresponse(buffering=True)
    File "/usr/lib/python2.7/httplib.py", line 1183, in getresponse
    response.begin()
    File "/usr/lib/python2.7/httplib.py", line 457, in begin
    version, status, reason = self._read_status()
    File "/usr/lib/python2.7/httplib.py", line 413, in _read_status
    line = self.fp.readline(_MAXLINE + 1)
    File "/usr/lib/python2.7/socket.py", line 480, in readline
    data = self._sock.recv(self._rbufsize)
    KeyboardInterrupt
I used the script from the github, as mentioned on the new site https://www.onweeractueel.nl/ and https://github.com/phoenix-blue/Domotic ... ghtning.py
But to be honest: I'm not sure about the port of the Domoticz server:
It is localhost (since the py-script and domoticz run at the Synology), but the port is set to 6144 (the default port Domoticz uses for the Domoticz clients.... There is no other port open lik 8080?)
What is the problem causing the lightning detection not to work for me/us?
EdwinK
Post by EdwinK » Tuesday 29 May 2018 22:54
I believe on Synology it's port 8084 you need
FrankVZ
Post by FrankVZ » Wednesday 30 May 2018 10:30
Oh wow!
I say: EdwinK for president! :)
I never thought about 8084 (thought that was https port). The problem took me hours....
With port 8084 I get no errors and the script seems to run! Waiting for the thunder this afternoon :)
Thanks for your quick response!
