Automatic backup not working Topic is solved
jammiejammie
Target OS: Raspberry Pi
Post by jammiejammie » Monday 09 January 2017 22:35
Today i had a bad day ....
My raspberry pi sd card crashed. But lucky as i taught i was... i had a solid backup plan in place.
I tunred on automatic backup in Domoticz.
Every night an Rsync task syncs the domoticz folder to my NAS.
This used to work perfectly. used to ...
There where no automatic backups created on the raspberry by domoticz.
So i had to try and restore the live running database. Which obviously was corrupted ....
So i repeared the most recent database i could and now i'm up and running again with an 3 months old database.....
But the main problem is that the automatic backup by Domoticz in not working....
Is there a way i can force Domoticz to do an automatic backup ?
I'm running the latest beta version 3.6325.
SweetPants
Domoticz version: V3.9517
Re: Automatic backup not working
Post by SweetPants » Monday 09 January 2017 22:41
Working here fine on V3.6325
Ubuntu 16.04.3 LTS on Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.1.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
jammiejammie
Post by jammiejammie » Monday 09 January 2017 22:47
Are the backups still on the same location
domoticz/backups ?
Because i don't have such a folder anymore
SweetPants
Post by SweetPants » Monday 09 January 2017 23:00
yup, still there
2017-01-09 22:00:00.998 Starting automatic database backup procedure...
2017-01-09 22:00:01.775 Ending automatic database backup procedure...
jammiejammie
Post by jammiejammie » Tuesday 10 January 2017 0:04
ok this is weird....
After restoring and fixing the database it looks like backing up works again.....
looks like something was not sitting right. thanx anyway!
gomario
Post by gomario » Friday 21 April 2017 5:23
This is quite an old post, but I thought to share my fix anyway, since I just had this problem...
Card corrupt --> New install of Jessie + Domoticz. ---> backup database import.
All working fine, but: Error writing automatic hourly/daily backup file.
Found out that all folders in /domoticz are owned by Pi, except for /backups and it's subfolders. CHOWN fixed that. All working now.
jake
Post by jake » Friday 21 April 2017 19:26
Where do you set the automatic backup? I only see manual backup and restore in the settings.
Verstuurd vanaf mijn GT-I9195 met Tapatalk
HansieNL
Domoticz version: Stable
Post by HansieNL » Friday 21 April 2017 19:33
jake wrote:Where do you set the automatic backup? I only see manual backup and restore in the settings.
Setup - Settings - Automatic Backup - Enable automatic backup
Blah blah blah
allmehandidesigns
Post by allmehandidesigns » Friday 05 May 2017 10:00
i guess you have updated the version, may be it is not working, bc i guess there is a bug in latest version
Susantaylor123
Post by Susantaylor123 » Friday 12 May 2017 13:48
I think it's a software issue or maybe you are using an old version.
Toulon7559
Domoticz version: latest
Post by Toulon7559 » Friday 12 May 2017 22:06
This thread triggered me to check as well whether and where my backup-files are located at the raspberry.
Was surprised by tellback 'permission denied' when trying to access the backups-folder.
How to avoid/circumvent that report?
Set1 = RPI-B+RFXCom433+S0PCM+Linksprite-shield for BMP180/DS18B20/RS485+DDS238ZN1
Set2 = RPI-3+RFLinkGTW+ESP8266s+PWS_WS7000
Common = 2*PVLogger+PWS_TFA_Nexus+KAKUs
=> Energy & Data Management based on Time and on PV&Consumption&Meteo
Garywilson571
Post by Garywilson571 » Wednesday 07 June 2017 12:25
It is perfectly working in the latest version and you can enable this option setup > settings > automatic backup > Enable automatic backup.
Professional essay writers UK
Users browsing this forum: No registered users and 4 guests
