Auto reboot when domoticz chrashes?
tjabas
Target OS: Raspberry Pi
Postby tjabas » Saturday 31 December 2016 0:16
Hi!
is there a way to get the raspberry to reboot itself when domoticz chrashes?
Domoticz crashes sometimes and all the events and timer will ofcourse not work.
so is there an easy way to monitor domoticz?
Egregius
Domoticz version: 3.5877
Re: Auto reboot when domoticz chrashes?
Postby Egregius » Saturday 31 December 2016 0:36
Of course, a simple bash script can do:
#!/bin/bash
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=devices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
   exit
   sleep 5
   STATUS2=`echo $DOMOTICZ | jq -r '.status'`
   if [ "$STATUS2" == "OK" ] ; then
      exit
      sleep 5
      STATUS3=`echo $DOMOTICZ | jq -r '.status'`
      if [ "$STATUS3" == "OK" ] ; then
         exit
         curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
         NOW=$(date +"%Y-%m-%d_%H%M%S")
         cp /volume1/appstore/domoticz/var/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
         sudo /var/packages/domoticz/scripts/start-stop-status stop
         sleep 8
         sudo kill $(sudo netstat -anp | awk '/ LISTEN / {if($4 ~ ":8084$") { gsub("/.*","",$7); print $7; exit } }')
         sleep 8
         sudo /var/packages/domoticz/scripts/start-stop-status start
      fi
   fi
fi
Execute it by cron to run every minute.
Scripts ask domoticz the status of device idx 1.
If status = ok it exits.
If not 2 more tries are executed.
If all 3 fails domoticz is stopped, killed and restarted. Alter those command to suit your needs.
tjabas
Postby tjabas » Saturday 31 December 2016 0:48
Thanks alot :)
but i have just started this raspberry pi thing and im not yet so good at this but could you please explain a little more how i install this script?
Do i need to istall cron as well?
Egregius
Postby Egregius » Saturday 31 December 2016 0:56
I think you should meet my best friend Mr. Google :P
Maybe hard to say it like that, but what if you just copy/paste without understanding what you're doing?
Isn't it better to learn how you must do it? Like Google 'execute bash script by cron'?
If you have a 'normal' linux you should have cron installed.
Check it by 'sudo service cron status'
Should return something with 'Active: active (running)' in it.
create the file with this command:
nano /home/pi/checkdomoticz.sh
paste the code in it
make the file executable:
chmod +x /home/pi/checkdomoticz.sh
add it to cron:
sudo crontab -e
* * * * * /home/pi/checkdomoticz.sh
tjabas
Postby tjabas » Saturday 31 December 2016 0:59
ok, thanks alot, i will try this :)
tjabas
Postby tjabas » Saturday 31 December 2016 1:06
Should this:"http://127.0.0.1:8084/ be replaced by the domoticz web adress and port? or should i just leave it like it is?
Egregius
Postby Egregius » Saturday 31 December 2016 1:08
You should/must run it on the same device so 127.0.0.1 is good. If you use another port, yes change the port.
tjabas
Postby tjabas » Saturday 31 December 2016 1:11
ok, no domoticz is on the same device, i just use port 8080, the raspberry, so i have now copy, pasted it and im about to save the file now.
And then :sudo crontab -e
but what are the * * * * * below?
sorry for my stupid question , but im learning.
tjabas
Postby tjabas » Saturday 31 December 2016 2:09
I really need to learn more about this linux programming, i installed the script, but i managed to get the whole pi do die, i had to install a old backup:)
But i will give it a try again.
Egregius
Postby Egregius » Saturday 31 December 2016 3:13
How can your pi die with this?
Did you change the commands to suit a pie? Those above are for syno.
Minute hour day dayofmonth dayofweek I think. 5 stars just means every minute
Egregius
Postby Egregius » Saturday 31 December 2016 3:37
Almost got it right:
* * * * *  command to execute
 │ │ │ │ └───── day of week (0 - 7) (0 to 6 are Sunday to Saturday, or use names; 7 is Sunday, the same as 0)
 │ │ │ └────────── month (1 - 12)
 │ │ └─────────────── day of month (1 - 31)
 │ └──────────────────── hour (0 - 23)
 └───────────────────────── min (0 - 59)
manjh
Postby manjh » Saturday 31 December 2016 10:43
Is there a way to do this on a Windows-10 server?
Hans
tjabas
Postby tjabas » Saturday 31 December 2016 12:15
Egregius wrote:How can your pi die with this?
Well, i really dont know what happened, i rebooted the pi several times and it was running for about 10 minutes every time, then it just stopped.
I must have done something wrong,im really new to this linux thing :) but im learning.
i didnt change anything in these * * * * *, i just copy/pasted and saved the whole line.
i will of course try this again, it seems like a really good way to get domoticz running without any hangups.
sincze
Domoticz version: 3.6179
Re: RE: Re: Auto reboot when domoticz chrashes?
Postby sincze » Saturday 31 December 2016 12:16
tjabas wrote:I really need to learn more about this linux programming, i installed the script, but i managed to get the whole pi do die, i had to install a old backup:)
If you want a visual interface as well maybe use 'monit' is can also monitor your 'ssh daemon'. Auto restart a process and send you a nice email.
tjabas
Postby tjabas » Saturday 31 December 2016 12:18
yes i will look into that as well. thank you for the tip.
tjabas
Postby tjabas » Sunday 01 January 2017 17:06
When i try to make the file executable, is it just to paste this: chmod +x /home/pi/checkdomoticz.sh
in the command line and press enter?
i have done this but nothing really happens.
HansieNL
Postby HansieNL » Sunday 01 January 2017 17:42
@tjabas : With chmod +x you set the file permission to executible. If you don't do that the file can't be run.
Domoticz on Raspberry Pi 2, Hue lights, Toon thermostat, Homey, Fibaro Push Button
tjabas
Postby tjabas » Sunday 01 January 2017 17:49
HansieNL wrote:@tjabas : With chmod +x you set the file permission to executible. If you don't do that the file can't be run.
ok, i understand that, all i need to do is to copy/paste the line in the commandline when using putty and then press enter?
Should i get some sort of notification when i press enter?
HansieNL
Postby HansieNL » Sunday 01 January 2017 23:53
"ls /home/pi/checkdomoticz.sh -l" should give you the answer.
Execute above command before and after chmod. Three - should be change to x.
havnegata
Domoticz version: 3.4834
Postby havnegata » Saturday 07 January 2017 22:17
I am reading this with great interest :-)
I don't fully understand what is happening line by line in the script, but I see a reference to some folders which don't exist in the Pie. Is it those folders we need to alter to suit the Pie or some other code?
Return to “General Discussion”
