Lightning and Domoticz
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
elmortero
Target OS: Raspberry Pi
Domoticz version: 3.9639
Re: Lightning and Domoticz
Post by elmortero » Wednesday 30 May 2018 12:00
Is there a way to parse parameters to http://www.onweeractueel.nl/domoticz_bo.json ?
I wrote a script in dzvents for this but sometimes the json result is too large (which returns "lua script execution exceeded maximum number of lines")
What would be great, if possible, is to send a parameter with max/min LAT and LON so that the number of results gets lower.
For those interested in my dzvents version:
		timer = { 'every 15 minutes' },
		httpResponses = { 'blitz' } -- matches callback string below
        data = {
            last = { initial = 0 }
	execute = function(domoticz, triggerItem)
	   local lightning = domoticz.devices('Bliksemteller')
	   local preLight = tonumber(lightning.rawData[1])
		distance = function(lat1, lng1, lat2, lng2)
		radius = 6371
		dLat = (lat2 - lat1) * math.pi / 180
		dLng = (lng2 - lng1) * math.pi / 180
		lat1 = lat1 * math.pi / 180
		lat2 = lat2 * math.pi / 180
		val = math.sin(dLat / 2) * math.sin(dLat / 2) + math.sin(dLng / 2) * math.sin(dLng / 2) * math.cos(lat1) * math.cos(lat2)
		ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1 - val))
		return radius * ang
		local latHome = 00.000000  --replace with your own coordenates
		local lngHome = 00.000000  --replace with your own coordenates
		local distanceRange = 20    --change to the maximum distance you want for filtering (in KMs)
		local last = tonumber(domoticz.data.last)
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://www.onweeractueel.nl/domoticz_bo.json',
				method = 'GET',
				callback = 'blitz'
		elseif (triggerItem.isHTTPResponse) then
	local response = triggerItem
		if (response.ok and response.isJSON) then
			local value = 0
			local ignored = 0
			tl = #response.json
			tc = 1
			repeat
			local times = tonumber(response.json[tc][1])
			local lat = tonumber(response.json[tc][2])
			local lng = tonumber(response.json[tc][3])
			local distanceBetween = distance(latHome, lngHome, lat, lng)
			 if (distanceBetween <= distanceRange) then
				if (times > last) then
				 value = value + 1
				 value = 0
			  domoticz.data.last = times
			tc = tc + 1
			until tc > tl
			print('Blitz Value = '..value)
			if value ~= preLight then
			lightning.updateCustomSensor(value)
				print('**blitz failed to fetch info')
FrankVZ
Post by FrankVZ » Friday 01 June 2018 16:06
I think we're gonna die.
Look at the results of the lightning strikes with the data and script as mentioned before and get no errors as far as I know.
The amount of strikes (running script every 10 mins for a range of 15 km):
DateTime Series 1
31-05-2018 15:00 0,00
31-05-2018 16:00 4,00
31-05-2018 17:00 18446744073709500000,00
31-05-2018 18:00 0,00
31-05-2018 19:00 0,00
31-05-2018 20:00 0,00
31-05-2018 21:00 0,00
31-05-2018 22:00 0,00
31-05-2018 23:00 0,00
01-06-2018 00:00 0,00
01-06-2018 01:00 0,00
01-06-2018 02:00 0,00
01-06-2018 03:00 0,00
01-06-2018 04:00 0,00
01-06-2018 05:00 0,00
01-06-2018 06:00 0,00
01-06-2018 07:00 0,00
01-06-2018 08:00 0,00
01-06-2018 09:00 0,00
01-06-2018 10:00 0,00
01-06-2018 11:00 0,00
01-06-2018 12:00 0,00
01-06-2018 13:00 0,00
01-06-2018 14:00 1,00
01-06-2018 15:00 18446744073709500000,00
The same script (I gave it another name), and running at a lower refresh rate (2x/hr for 30 km)
31-05-2018 16:00 37,00
01-06-2018 14:00 0,00
01-06-2018 15:00 0,00
Well, are we going to survive? :)
It looks like the misreading occurs, with the first reading after a successful/correct reading.
Someone knows what causes these strange amounts?
EdwinK
Post by EdwinK » Saturday 02 June 2018 20:54
EdwinK wrote:
Tuesday 29 May 2018 20:20
Getting the script from Phoenixblue's git page made it work again.
Hmm.. Not really. Still doesn't update the counter :(
Tried with creating another counter, but still no updating :(
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
FrankVZ
Post by FrankVZ » Thursday 07 June 2018 22:38
Well, a small update: in my case it is updating, but on regular basis the huge error (18 * 10^18 number)
The script starts in my case by the synology task manager (running the python script from there). It has a big advantage: if Domoticz is down (crashed last two days at midnight for some reason) I instantly get notified by the synology that is still brave doing what it has to do.
So that is nice,
but the huge number error is still strange.
But today I also find out, while testing another counter, the same error occurs.
I tested the json command in order to set a new value into the counter with
http://<myip>:<myport>/json.htm?type=command&param=udevice&idx=<mycounter>&svalue=200
It just should put the number 200 into the counter, but got 18*18^10 instead.
So it wouldn't surprise me if the behaviour /bug is coming from the counter function within Domoticz it selves, instead of the script created by Phoenixblue or the sources it uses (the API).
It is quite buggy anyway, because the graph only shows the last 10 hours, but the header says 24hrs :)
Counter errors.jpg (63.02 KiB) Viewed 465 times
Question is of course: how to solve this issue?
Al lot of people should experience counter errors in that case?
Or is it the interpreter between json <-> DZ where is goes wrong?
assenzuid
Post by assenzuid » Thursday 09 August 2018 16:49
Today I noticed the script is not working.
I use the script at page 3 of this topic.
  File "lightning.py", line 76, in <module>
    for pos in data:
TypeError: 'NoneType' object is not iterable
phoenixblue
Domoticz version: 3.7392
Post by phoenixblue » Thursday 09 August 2018 16:58
This is correct, there are some import problems from the main server in Germany.
Unfortunately this part must be solved from external.
When the import is back working I will let it know.
Verstuurd vanaf mijn EML-L29 met Tapatalk
scripts on github: Link
SweetPants
Domoticz version: V4.9866
Post by SweetPants » Friday 10 August 2018 9:19
I have data again since aug 9 16:00, and some lightning strikes where discovered.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Users browsing this forum: No registered users and 4 guests
