Raspberry pi 2 Serial port
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
RKG90
Target OS: Raspberry Pi
Post by RKG90 » Monday 12 February 2018 11:36
I just installed Domoticz, and is pretty psyched about it :)
I have 4 relays connected to the GPIO. This is working perfectly.
Then i have a "Control panel" from at company called NEETS. This is sending custom serial commands when a button is pressed. Like Power1, Power2 ,etc.
I can read the serial data with minicom on the raspberry
How do i read these serial commands on ttyAMA0 with domoticz and use it to toggle the relays ?
Hope someone can help me out
Best regards
RKG90
Re: Raspberry pi 2 Serial port
Post by RKG90 » Tuesday 13 February 2018 17:52
Is there really No one who can help me ?
Marci
Domoticz version: 3.8153
Post by Marci » Tuesday 13 February 2018 17:57
Personally, I'd (install &) fire up Node-Red with a node listening to the serial port, listen for the message, reformat the message to comply with Domoticz JSON API, then fire a http request to the relevant Domoticz device via the JSON API.
Quick and easy to get up & running & test / experiment... then once working perfectly it can be refactored out into a script if necessary.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
RKG90
Post by RKG90 » Tuesday 13 February 2018 18:36
Thanks for the reply..
Is there any examples out there ?
nigels0
Post by nigels0 » Tuesday 13 February 2018 22:21
An alternative is to run a looping python script. There are many examples out there. From the script you can make a call to domoticz to switch on using the JSON api.
Here’s a program that I use for reading an alarm serial port and setting a switch in domoticz on/off. You could adapt it to read the text coming from the serial port and decide what to sendto domoticz
import serial
import os
import urllib2
#Global Variables
ser = 0
#Function to Initialize the Serial Port
def init_serial():
    global ser          #Must be declared in Each Function
    ser = serial.Serial(
        port = '/dev/ttyAMA0',
        baudrate=4800,
        parity= serial.PARITY_EVEN,
        stopbits=serial.STOPBITS_ONE,
        bytesize=serial.EIGHTBITS,
# Need to uncomment this when using hardware DTR
#       dsrdtr=True,
        timeout=5.0,
        xonxoff=False
    ser.open()          #Opens SerialPort
#Call the Serial Initilization Function, Main Program Starts from here
init_serial()
active=False
while 1:
    bytes = ser.readline()  #Read from Serial Port
    print 'You sent: ' + bytes      #Print What is Read from Port
    if len(bytes)>0:
        if active:
          urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx=308&switchcmd=Off')
          active=False
        else:
         urllib2.urlopen('http://192.168.0.52:8080/json.htm?type=command&param=switchlight&idx=308&switchcmd=On')
         active=True
#Ctrl+C to Close Python Window
RKG90
Post by RKG90 » Wednesday 14 February 2018 18:04
Thank you very much
Im getting closer now :)
Users browsing this forum: peteralm and 5 guests
