Integrating control of my Velux windows into Domoticz
simonrg
Target OS: Raspberry Pi
Domoticz version: 3.8807
Re: Integrating control of my Velux windows into Domoticz
Post by simonrg » Sunday 12 July 2015 0:22
nigels0 wrote:You need one KLF-100 per group - so if you wanted to control all individually, you'd need 10 - but if you grouped some(or all) of the windows together and the same with the blinds - then you'll need just 2.And any other combination in between of course.
Thanks, really a non-starter then, they are not easily groupable or at least dependent on time of day and the weather the devices move between different groups, so I would need 10 KLF-100s.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
ThinkPad
Post by ThinkPad » Sunday 12 July 2015 0:54
Moved topic to 'Show your projects' subforum. Fits much better overthere ;)
ThinkTheme - theme for Domoticz
My (Dutch) blog: http://thinkpad.tweakblogs.net - My Domoticz scripts: Bitbucket
I'm not (very) active anymore on this forum as i don't use Domoticz anymore.
ubfssF
Domoticz version: 2.2364
Post by ubfssF » Sunday 22 November 2015 15:47
Nice project! Is the EETH008 really needed? Wouldn't an EETH002 (https://www.antratek.nl/eth002) be enough?
StanHD
Post by StanHD » Sunday 22 November 2015 16:37
Should be ok, I just use 2 relays from the eth008, one for Open, one for Close, and both together for stop.
Domoticz Slave - Asrock Ion - Linux, Python:- Broadlink RM2, Sonos
pepeEL
Post by pepeEL » Saturday 30 January 2016 17:50
I have a problem. I want use GPIO relay on Raspberry to control my Blinds by remote Telis 4 RTS.
I use 2 relay connect by GPIO to my Raspberry with Domoticz. I use wirePi library to control GPIO by Domoticz. I create Switch with set GPIO o open and to Close Blinds. But i Have one problem. Pulse from relay is too long. Longer then when i press button manual on remote. I user events with set time 0.2 secund but nothing change... WHen i click example on close switch sometimes i hear that relay has long time pulse sometime short time pulse. How can i set time to relay by GPIO to shorter less than 0.2 secund ? Because problem is that relay has too long pulse and when pulse is too long blinds not close , it change position step by step.
Maybe i can use script with set time pulse for relay ?
Please i need help
Domoticz - Raspberry Pi 2 + RaZberry Z-Wave Gen 5 + RFLink 433MHz + 1-Wire Dallas DS9490r + Raspberry GPIO
Devices: Fibaro FGS-221, 2xFibaro FGRGBWM-441, Fibaro FGWP-011, 5xElmes CTX-4H, Flamingo FA20RF, 4xANLUT Wall Plug(by JULA shop), 4xDS18b20
Derik
Post by Derik » Friday 21 April 2017 15:04
StanHD wrote:I decided to bite the bullet an ordered one of these:
http://www.robot-electronics.co.uk/htm/eth008tech.htm
Will report back how it goes. Image
Dear StanHD...
Do you have this board working in domoticz??
Please tell me how...
With a http command?
StanHD
Post by StanHD » Friday 21 April 2017 15:49
Yes, like this:-
The IP is the address of the ETH008
iocgi? = The onboard embedded interface
DOA7 = Digital Out Active Relay 7
DOI7 = Digital Out Inactive Relay 7
The Off Delay just allows for a 5 second "Pulse" through the contacts.
It is obviously "overkill" for just working with volt-free contacts but I use the other 6 relays for ceiling fan switching, extract fan switching and speed selection etc.
Derik
Post by Derik » Friday 21 April 2017 16:06
mm give it a try on my board. [ time needed ]
Only do you have acces without a password/login?
StanHD
Post by StanHD » Friday 21 April 2017 16:41
Derik wrote:mm give it a try on my board. [ time needed ]
You can activate a password on the ETH008 board, and then I think you can include that in the switch command. (But I am not sure) ;)
dude
Post by dude » Tuesday 31 October 2017 18:36
Instead of Velux, if you have the choice or buying a new one, go for instance to www.fakro.com their products are based on Z-wave. Somfy and Velux IO control are closed systems.
RaZberry PI, RFX 433E, Marmitek Sc9000, MS90, DS90, Everspring AN157, Omnik Solar, Vair Co2, 1-wire, Qubino
