DIY motion sensor for under €5
theSpiked
Target OS: Raspberry Pi
Post by theSpiked » Sunday 09 September 2018 21:03
I've made my own motion sensors for enabling motion based lights and I'd like to share my project with you guys!
Using ESP8266, HC-SR501 MQTT and Domoticz I've been able to create these sensors for under €5/piece, including a simple project box.
Source: https://thenailz.github.io/mqtt-motion-detection/
Please let me know what you think!
denman091
Domoticz version: 3.8153
Re: DIY motion sensor for under €5
Post by denman091 » Wednesday 19 September 2018 21:49
Hi, i have read your project and it looks very nice. But i'm a newbie in case of esp8266 and Mqtt. I think i'm going to buy the hardware and in the time it is send i will find out how Mqtt is working.
emme
Domoticz version: latest
Post by emme » Thursday 27 September 2018 14:00
ciao,
good job!
Just wish to contribute with with 2 notes:
You use a specific node to store the last-seen value (timestamp)... why don't use context data instead and pass the value as it is?
the esp will send a new telegram ONLY if value changes.... your flow will switch off if it does not get a 1 anymore for 15min...
but if you still have movement... your node does not send 1 anymore and you get the flow switch off the variable even if it is not true...
I would suggest to keep the 1 and 0 values from the node and act by consequence, have then domoticz handle the time difference operation
ciao
M
"We always done this way"
