Domotics touchscreen remote
ledfreak3d
Domoticz version: 3.8025
Re: Domotics touchscreen remote
Post by ledfreak3d » Wednesday 25 April 2018 10:52
the are 3d print services in most countries
but i printed my own
also my design
Unleashe the magic smoke ;)
Remicade
Target OS: Raspberry Pi
Post by Remicade » Sunday 13 May 2018 20:12
Hi ledfreak3d,
We had contact about the remote you made.
Because this is screen and programming the ESP is totaly new for me and others on the forum a question:
Can you make a very simple list of used programs and steps to make to get the ESP flashed with the .bin file?
I really like your set up and want to use it as a fixed unit in the living room.
Thanks for your work!
Paul
ledfreak3d
Post by ledfreak3d » Sunday 13 May 2018 20:31
hey Paul.
yes ofcourse.
you can use the arduino ide.
or just flash the bin file using any of the standard flash programs any will do the job realy dont hesitate to send me a email if you need anything
you can use this one
http://domoticx.com/esp8266-wifi-softwa ... l-flasher/
or this one
https://github.com/nodemcu/nodemcu-flasher
make sure you always flash to addres 0x0000
btw the housing is on thingiverse
Remicade
Post by Remicade » Tuesday 15 May 2018 18:06
Hi ledfreak3d,
Okidoki, I flashed the bin file to the Wemos.....looks like it is ok.
Now Nextion....Trying to copy the HMI file to SD but the Nextion does not find the file. Have to look further, any hints are welcome ;)
But then I opened the Github page again and found an INO file???? What to do with that one?
It is al running on the Wemos isn't it?
Bit confused at the moment...
Thanks,
Paul
Remicade
Post by Remicade » Tuesday 15 May 2018 18:16
HMI is running!
Have to take out the SD after the loading of the tft file to the HMI.
Hieperdepiep!
ledfreak3d
Post by ledfreak3d » Tuesday 15 May 2018 20:45
great is everthing working ok ?
Remicade
Post by Remicade » Tuesday 15 May 2018 21:29
ledfreak3d,
Now I have a little fight whithin the Arduino compilation....
All libraries are downloaded and installed but the compilation stops..:
Arduino: 1.6.7 (Windows 10), Board:"Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
WAARSCHUWING: Foutieve map .github in bibliotheek 'ArduinoJson'
WAARSCHUWING: Foutieve map .github in bibliotheek 'WiFiManager'
C:\Users\Asus\Downloads\Domoticz-remote--master\Domoticz-remote--master\remote\remote.ino: In function 'void configModeCallback(WiFiManager*)':
remote:102: error: 'tick' was not declared in this scope
ticker.attach(0.2, tick);
C:\Users\Asus\Downloads\Domoticz-remote--master\Domoticz-remote--master\remote\remote.ino: In function 'void setup()':
remote:155: error: 'setup_input' was not declared in this scope
webserver.on("/", setup_input); // If the user types at their browser http://192.168.0.100/ control is passed here and then to user_input, you get values for your program...
remote:156: error: 'homepage' was not declared in this scope
webserver.on("/homepage", homepage); // If the user types at their browser http://192.168.0.100/homepage or via menu control is passed here and then to the homepage
remote:157: error: 'page1' was not declared in this scope
webserver.on("/command1", page1); // If the user types at their browser http://192.168.0.100/page1 or via menu control is passed here and then to the page1
C:\Users\Asus\Downloads\Domoticz-remote--master\Domoticz-remote--master\remote\remote.ino: In function 'void homepage()':
remote:290: error: 'append_HTML_header' was not declared in this scope
append_HTML_header();
remote:297: error: 'append_HTML_footer' was not declared in this scope
append_HTML_footer();
C:\Users\Asus\Downloads\Domoticz-remote--master\Domoticz-remote--master\remote\remote.ino: In function 'void page1()':
remote:341: error: 'append_HTML_header' was not declared in this scope
remote:347: error: 'append_HTML_footer' was not declared in this scope
exit status 1
Dit rapport zou meer informatie hebben met
"Tijdens de compilatie uitgebreide uitvoer weergeven"
ingeschakeld in Bestand > Voorkeuren.
So I will be busy for a while.
But all credits to you! I have the HMI running now whitout casing or ESP attached.....even the wife loves it already!
Cheers,
Paul
ledfreak3d
Post by ledfreak3d » Tuesday 15 May 2018 21:33
hey Paul denk dat eem van de librarys niet klopt
mail.me anders even dan kijk ik wel even
Remicade
Post by Remicade » Wednesday 16 May 2018 20:30
Looks like my PM is not working?
ledfreak3d
Post by ledfreak3d » Wednesday 16 May 2018 21:19
looks like it have not recieved any
email is faster. :)
Remicade
Post by Remicade » Saturday 19 May 2018 12:31
Hi Forum and ledfreak3d,
Step by step getting there i think,
- uploaded the tft file to an sd card (Nextion Editor, File, Open Build Folder, choose tft file)
- Used flash_download_tool_v0.9.6_150419 to flash WeMos D1 mini.
- Arduino IDE 1.8.5 used to load ino to Wemos D1 R2&mini with 3M SPIFFS
Now Domo-remote is visible in the WIFI list.
Have to find the password.... ;)
Connect Nextion to Wemos.
Do I forget something?
Cheers Paul
Remicade
Post by Remicade » Saturday 19 May 2018 13:19
Got it!
First real attemt connecting the WeMos and Nextion and it works
Now have to play with the website to use right IDx's
Nice!
p.s. Is it possible to show humidity and temperature of DHT in bathroom?
ledfreak3d
Post by ledfreak3d » Saturday 19 May 2018 14:56
should be possible ill look into it when i have some spare time
code needs a lot of cleaing up not all library's work perfectly with some others but it does the job for most of the time
