Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by Madgeni » Thursday 13 July 2017 13:05
afraid it's necessary for 2 good reasons:
1) it's slightly more secure - depends on the cert you use
2) I currently don't handle http requests, which kills Controlicz dead - it's on my list to fix asap :)
Like Controlicz? Want to help keep the lights on? https://paypal.me/madgeni :)
Native Alexa skill and Google app - register at https://www.controlicz.com
Madgeni
Post by Madgeni » Thursday 13 July 2017 13:07
super easy to configure:
go here: /etc/init.d/domoticz.sh
double check this line exists (should be there by default now):
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443" <-maybe change the port number to a higher number, then fix your port forwarding on your router. Restart Domoticz - update Controlicz
Madgeni
Post by Madgeni » Thursday 13 July 2017 13:23
any further Controlicz talk - can we put it here? viewtopic.php?f=21&t=16670
rickwilleme
Domoticz version: 3.6792
Post by rickwilleme » Sunday 16 July 2017 20:08
Hi Madgeni,
Original post at here
rickwilleme wrote:Hey guys,
It's Friday evening, so got myself some coding time.
Managed to install the Alexa - Domoticz integration (https://github.com/madgeni/alexa_domo) and it's actually working pretty well!
Only weird thing I notice is that I'm missing my ZWave dimmers in the discovered devices. Still able to control them with a scene, so got myself a workaround.
Any clue if I should do something special with my ZWave dimmers to get them discovered?
Thanks,
Rick
Madgeni wrote:Hi Rick - the alexa-domo integration thread is here:
viewtopic.php?f=38&t=9446
I'd need some more detail on the dimmers, to tweak the discovery. In that thread can you give me detail on their Type/Subtype etc from Domoticz?
The type is Light/Switch and the subtype is Switch.
Thanks for looking into this!
Regards,
Rick
Raspberry Pi ~ Fibaro Dimmer (Z-Wave) ~ Several KAKU switches and dimmers (433 MHz) ~ Amazon Echo ~ Somfy RTS ~ Sony TV ~ Kodi/XBMC ~ Essent E-Thermostaat (ICY) ~ Cresta thermostat ~ Wundermap Weather ~ Smoke detectors
remb0
Post by remb0 » Sunday 16 July 2017 21:20
it works!
All Domoticz compatible products at shop: https://www.domoticz.com/wiki/Compatibl ... n_gearbest
borcon
Post by borcon » Wednesday 19 July 2017 17:27
Hey madgeni,
some smarthome skills like Philips Hue have the scenes in the scene section in alexa not in devices.
Are there differences or only for better view?
I would like to control my color hue lights with domoticz.
Switch on or off works in alexa but i can't set colors.
Any ideas?
Madgeni
Post by Madgeni » Wednesday 19 July 2017 18:52
Hi there - as far as i can tell, it's cosmetic - i will take a look tho, as it would make it 'neater'
Yes, colours should/were working, so will take another look. I'll do them for Controlicz first..
Madgeni
Post by Madgeni » Wednesday 19 July 2017 19:00
rickwilleme wrote:Hi Madgeni,
Regards,
Rick
Hi - not sure why they aren't being discovered - both type and subtype are standard. Is there anything in your logs? I'm assuming they are in Room Plans.
I saw your note about Controlicz on the FB page - not sure what you mean about testing? It's worth noting that these two are essentially the same ( i should know ;-) ) - also you say you've built your own skill, is this using my code?
Controlicz will probably be updated more rapidly, and obviously, relies on no/little effort on your side!
Scoobydoo
Post by Scoobydoo » Monday 07 August 2017 15:51
Issues with the wesbite, cant access the website or discover anything at the moment. Seems to be down?.
Madgeni
Post by Madgeni » Monday 07 August 2017 16:23
Doh - sorry it's back - User error - was doing some testing.
ressof
Post by ressof » Wednesday 30 August 2017 11:30
Just wondering if there are any differences between the manual install and the Controlicz?
Madgeni
Post by Madgeni » Wednesday 30 August 2017 14:13
no effort to Controlicz (apart from registering) - and i'll be updating Controlicz with functionality in future (As and when it comes to Alexa)
FrankCGN
Post by FrankCGN » Tuesday 05 September 2017 21:10
I have noticed that Alexa meanwhile understands the commands "up" and "down" respectively "open" and "close" in blinds. Unfortunately the blinds are closed with "open" and vice versa.
Is there any way to change that and if so, how?
I use 433Mhz blinds over an RFXCOM - RFXtrx433 on a Raspi 3
Raspberry 3 - RaZberry2 Module - RFXtrx433E - Domoticz beta
Z-Wave: Popp Smoke Detector, Fibaro Motion Sensor, Fibaro Wall Plug, Popp Wall Plug
RFXtrx433E: Bresser Temp.+Hygro Sensor, rohrmotor24 RMF Blindmotor
Other: AVM Fritz!DECT200
stingone
Post by stingone » Monday 11 September 2017 22:35
Hopefully someone can help me. i did a reinstall of domoticz / raspian. system is working. Alexa is also discovering the devices in the homeplan however when im giving alexa a command it says that the device is not being found.....
stingone
Post by stingone » Tuesday 12 September 2017 20:23
Stange.... seems there was a bug in the description of the device name alexa_name: i removed and added the device and now its working :)
Madgeni
Post by Madgeni » Tuesday 19 September 2017 18:31
weird! glad it's working :)
chal
Post by chal » Monday 02 October 2017 14:18
First of all thank you for your work.
I tried to setup the skill it discovers the devices in my alexa app but when i try to switch something alexa says that the device is currently not available or in German "reagiert gerade nicht".
when i run a test in lambda i get this:
START RequestId: 770c26c8-a765-11e7-9b8a-3116929d30f8 Version: $LATEST
2017-10-02T11:33:15.291Z	770c26c8-a765-11e7-9b8a-3116929d30f8	https://xxxx:xxxx@xxxx.com:60900/json.htm?type=command&idx=140&param=switchlight&switchcmd=Off
2017-10-02T11:33:16.189Z	770c26c8-a765-11e7-9b8a-3116929d30f8	SyntaxError: Unexpected token <
    at Object.parse (native)
    at Request._callback (/var/task/node_modules/domoticz-api/api/domoticz.js:94:58)
    at Request.self.callback (/var/task/node_modules/domoticz-api/node_modules/request/request.js:200:22)
    at emitTwo (events.js:87:13)
    at Request.emit (events.js:172:7)
    at Request.<anonymous> (/var/task/node_modules/domoticz-api/node_modules/request/request.js:1067:10)
    at emitOne (events.js:82:20)
    at Request.emit (events.js:169:7)
    at IncomingMessage.<anonymous> (/var/task/node_modules/domoticz-api/node_modules/request/request.js:988:12)
    at emitNone (events.js:72:20)
END RequestId: 770c26c8-a765-11e7-9b8a-3116929d30f8
REPORT RequestId: 770c26c8-a765-11e7-9b8a-3116929d30f8	Duration: 1439.27 ms	Billed Duration: 1500 ms 	Memory Size: 128 MB	Max Memory Used: 37 MB
RequestId: 770c26c8-a765-11e7-9b8a-3116929d30f8 Process exited before completing request
The Test:
"header": {
"messageId": "01ebf625-0b89-4c4d-b3aa-32340e894688",
"name": "TurnOffRequest",
"namespace": "Alexa.ConnectedHome.Control",
"payloadVersion": "2"
"payload": {
"accessToken": "123",
"appliance": {
"additionalApplianceDetails": {
"switchis": "On/Off",
"WhatAmI": "light"
"applianceId": "140"
also tried to setup it from scratch but same problem
Madgeni
Post by Madgeni » Monday 02 October 2017 15:14
can you just double check the conf.json file for formatting?
hayman
Domoticz version: 3.8153
Post by hayman » Friday 06 October 2017 17:42
hallo,
im using domoticz on my synology and ive forword the port 8443 ,try to singup but not working i get error on the website ...?
please help .....
Madgeni
Post by Madgeni » Friday 06 October 2017 18:24
weird, website is up, and i've just registered a test account fine
