Notification
BertB
Target OS: Raspberry Pi
Notification
Post by BertB » Thursday 30 June 2016 13:18
I was experimenting with getting notifications from my RPI Domoticz server on my android phone, when I noticed that they also arrive on the Domotica app. Great, but ... it only seems to work when all notification options are checked, so I also get an email.
Is this intended?
Where can I find notification history?
Greets, Bert
marcelk
Re: Notification
Post by marcelk » Tuesday 12 July 2016 14:26
I'm trying to figure out how I can have Domoticz (I run it on a Windows system and a pi) send notifications to the Domoticz-Lite app (on Android) so I hope you at least explain how you got this to work?
BertB
Re: Notification
Post by BertB » Tuesday 12 July 2016 18:16
I think you need the Pro Version to het notificaties. Did you enable the notificaties in the app by allowing it in the settings?
marcelk
Re: Notification
Post by marcelk » Friday 15 July 2016 22:21
I got it working but like you mentioned I also have to select every notification method in the switch-config. I did not configure the notification options in setting so I don't get them via email or pushbullet for example but only via the Domoticz Lite app.
It would be nice if there was an option to select the Domoticz App as Notification destination instead of all the other options.
Andrex
Re: Notification
Post by Andrex » Thursday 13 October 2016 19:46
Marcelk would you like to share with us how you did it?
dobber
Re: Notification
Post by dobber » Sunday 11 December 2016 18:01
marcelk wrote:I got it working but like you mentioned I also have to select every notification method in the switch-config. I did not configure the notification options in setting so I don't get them via email or pushbullet for example but only via the Domoticz Lite app.
I'm having the same issue. All need to be selected for notifications to be sent to android app.
I tried every single option by itself, but no go.
delfisastre
Domoticz version: 3.8153
Re: Notification
Post by delfisastre » Tuesday 27 December 2016 19:47
I have the same problem! when all the notifications are ON. (email, pushbullet...) everythink works ok, but if i try all except email. The notifications are not send to my mobile.
paralight
Re: Notification
Post by paralight » Monday 27 February 2017 14:33
hi
i've got notifications problems too. Sometimes i get notifications on phone , sometimes not. very annoying.. all notifications are checked on domoticz. logs works fine , so it's not a captors issue.
