Siri / HomeKit support for Domoticz
scheveningen
Target OS: Raspberry Pi
Re: Siri / HomeKit support for Domoticz
Post by scheveningen » Thursday 07 July 2016 11:04
I installed the Homebridge, all went well and it is working now. I use app Insteon+ and the app detect the homebridge.
Till hire no problems. So I want to install a plugin, in my case the Sonos plugin. No problem of errors.
pi@raspberrypi:~/homebridge$ sudo npm install -g homebridge-sonos
homebridge-sonos@0.1.0 /usr/local/lib/node_modules/homebridge-sonos
├── underscore@1.8.3
└── sonos@0.8.0 (ip@0.3.3, debug@0.7.4, underscore@1.5.2, upnp-client@0.0.1, xml2js@0.2.8, request@2.27.0)
But now the problem. I edit the config.json and start homebridge.
[Sat Jul 02 2016 16:49:32 GMT+0000 (UTC)] Loaded plugin: homebridge-sonos
[Sat Jul 02 2016 16:49:32 GMT+0000 (UTC)] Registering accessory 'homebridge-sonos.Sonos'
[Sat Jul 02 2016 16:49:32 GMT+0000 (UTC)] ---
[Sat Jul 02 2016 16:49:32 GMT+0000 (UTC)] Loaded config.json with 0 accessories and 1 platforms.
Loaded config.json with 0 accessories and 1 platforms. <-- the problem. I'm all new to this so I know for sure I made a small stupid mistake. But I can not figure out what the problem is. Below the config.json
 "platform": "Domoticz",
 "name": "Domoticz",
 "server": "127.0.0.1",
 "port": "8080"
 "accessories": [
 "accessory": "Sonos",
 "name": "Bedroom Speakers",
 "room": "Woonkamer"
scheveningen
Post by scheveningen » Wednesday 13 July 2016 9:42
Well I found the problem regarding the sonos plugin. I edit the wrong config.json......
I need to edit the config.json in /home/pi/.homebridge/
But when I try to edit it, I get the error [ Error writing /home/pi/.homebridge/config.json: Permission denied ]
second problem, I'm using SSH for login. Now I instald the desktop option. In raspi-config I selected B4
desktop autologin desktop GUI, automatically logged in as "pi" user. But I still get the log in screen and
User pi
pass ****
wont work, but it will work when I connect using SSH
trixwood
Domoticz version: Offline
Post by trixwood » Wednesday 13 July 2016 10:08
file permission or owner is probably wrong, change that (look up chmod, chown with google) or just use sudo from the terminal to edit. e.g.
sudo nano /home/pi/.homebridge/config.json
or
sudo vi /home/pi/.homebridge/config.json
or whatever you use as a text editor instead of nano or vi.
can't help you with the desktop thing, you should probably ask that on the raspberry pi forum.
scheveningen
Post by scheveningen » Thursday 04 August 2016 20:45
trixwood wrote:file permission or owner is probably wrong, change that (look up chmod, chown with google) or just use sudo from the terminal to edit. e.g.
or
sorry for the late replay, but it works thanks to your reaction! Big thanks for that :!:
I have juist one small problem. I can start homebridge with the sonos plugin. And it is working fine.
But when I do,
sudo service --status-all
I get this list,
+ ] dhcpcd
[ + ] domoticz.sh
[ + ] dphys-swapfile
[ + ] fake-hwclock
[ + ] hdparm
[ - ] homebridge
[ - ] hostname.sh
[ - ] hwclock.sh
[ + ] kbd
[ + ] keyboard-setup
It seems to be that homebridge is not running?
Marci
Domoticz version: 3.8153
Post by Marci » Friday 05 August 2016 20:59
See the “Run in Background as Service” section of viewtopic.php?f=36&t=10272 - the instructions are generic for this regardless of the plugin.
But do note, the homebridge-sonos plugin has nothing at all to do with Domoticz, so really you should be asking for help about that over at https://github.com/nfarina/homebridge-sonos/issues - if using the homebridge-sonos plugin you’re connecting directly to Sonos, bypassing Domoticz.
If you want to connect to the Sonos THRU Domoticz then you need to use the homebridge-edomoticz plugin.
scheveningen
Post by scheveningen » Monday 08 August 2016 21:20
Marci wrote:See the “Run in Background as Service” section of viewtopic.php?f=36&t=10272 - the instructions are generic for this regardless of the plugin.
Thank you for your replay. I follow the steps for "run in background" I need option 3 because is used the clean install mode using the Jessy image. I created a new dir homebridge and install hombridge. And it is functional. Just the part "run in background" is tiny problem. I follow the steps and now I get this error message. So what now?
pi@raspberrypi:~ $ sudo systemctl status homebridge.service -l
● homebridge.service - HomeBridge Service
Loaded: loaded (/lib/systemd/system/homebridge.service; enabled)
Active: failed (Result: exit-code) since ma 2016-08-08 20:56:53 CEST; 48s ago
Process: 497 ExecStart=/usr/bin/homebridge (code=exited, status=203/EXEC)
Main PID: 497 (code=exited, status=203/EXEC)
aug 08 20:56:53 raspberrypi systemd[1]: Starting HomeBridge Service...
aug 08 20:56:53 raspberrypi systemd[1]: Started HomeBridge Service.
aug 08 20:56:53 raspberrypi systemd[497]: Failed at step EXEC spawning /usr/bin/homebridge: No such file or directory
aug 08 20:56:53 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=203/EXEC
aug 08 20:56:53 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
Marci
Post by Marci » Monday 08 August 2016 22:39
Path to homebridge incorrect in homebridge.service... Hence the 'no such file or directory' errors. Try changing paths to /usr/local/bin/homebridge, or /usr/local/lib/node_modules/homebridge/bin/homebridge
scheveningen
Post by scheveningen » Tuesday 09 August 2016 21:58
Marci wrote:Try changing paths to /usr/local/lib/node_modules/homebridge/bin/homebridge
Its working! Thank you for your help!
Active: active (running) since di 2016-08-09 21:52:08 CEST; 39s ago
Main PID: 492 (homebridge)
CGroup: /system.slice/homebridge.service
└─492 homebridge
maikelske
Post by maikelske » Friday 30 September 2016 10:27
hi,
can somebody help me.
i'm new to domoticz and homekit.
when i start homekit i get a error that the scrips start is missing.
can some one tell me how i can fix this?
thxs,
maikel
niwreg
Post by niwreg » Friday 30 September 2016 16:07
Hi I ran into a problem when i try to pair an new phone to the excisting homebridge.
The new phone updated to the latest IOS can not find the homebridge, not in the Home app as EVE, the logs say it is running an another phone wich was paired before has no trouble at all.
Why won't my phone find the homebridge? It is connected to the same wifi etc.
v40jlt4
Domoticz version: V3.8035
Post by v40jlt4 » Sunday 02 October 2016 22:10
maikelske wrote:hi,
thxs,
maikel
I just spend a few hours having the same issue.
The wiki assumes homebridge is not installed but the most recent rPi2 images have homebridge installed, but in a different location!
The wiki does mention the fact that in the case you have that more recent image, you should skip to "configure", but as of that point the wiki cannot be used. Should be adapted,
It assumes homebridge to be installed in /home/pi/homebridge, but it's in /usr/lib/node_modules/homebridge
you can try to apply the wiki directions there. But you might have to change permissions:
cd /usr/lib/node_modules/
sudo chown -R pi homebridge
npm run start still gave the start script missing error.
That's because there's no start in package.json.
So I tried npm run dev (there's a dev in there).
Now it works with the new ios10 "woning" app.
Marci
Post by Marci » Sunday 02 October 2016 23:46
Ignore the massively out of date wiki, follow instructions for the image version in first post of the homebridge-edomoticz thread. These instructions cater for all the images' oddities.
maikelske
Post by maikelske » Monday 03 October 2016 10:03
v40jlt4 wrote:
maikelske wrote:hi,
thxs,
maikel
thank you!
i'm going to try it today.
thxs,
maikel
possible
Post by possible » Monday 10 October 2016 22:14
Hi guys,
I am also new with Domoticz.
Hardware:
Raspberry Pi 2
Installed Rasbian newest version. Jessie
I updated everything with apt-get commands.
I followed the following commands:
sudo curl -sL https://deb.nodesource.com/setup_0.12 | bash -
sudo apt-get install nodejs
sudo apt-get install libkrb5-dev
sudo apt-get install libavahi-compat-libdnssd-dev
Command sudo curl -sL https://deb.nodesource.com/setup_0.12 | bash - did not work. (Permission errors??) So i changed it to:
curl --silent --location https://deb.nodesource.com/setup_0.12 | sudo bash -
so far so good.. However I am getting errors with :
sudo npm install -g homebridge && sudo npm install -g forever command.
It first starts with:
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.12.16"
but coninues with:
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/.node-gyp"
make: Entering directory '/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/build'
entire code:
gyp ERR! cwd /usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
gyp ERR! node -v v0.12.16
gyp ERR! node-gyp -v v3.3.1
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding/bignum.node --module_name=bignum --module_path=/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding' (1)
node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:110:17)
node-pre-gyp ERR! stack     at maybeClose (child_process.js:1019:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:1091:5)
node-pre-gyp ERR! System Linux 4.4.21-v7+
node-pre-gyp ERR! command "node" "/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
node-pre-gyp ERR! node -v v0.12.16
node-pre-gyp ERR! node-pre-gyp -v v0.6.30
node-pre-gyp ERR! not ok
npm ERR! Linux 4.4.21-v7+
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "-g" "homebridge"
npm ERR! node v0.12.16
npm ERR! npm  v2.15.1
npm ERR! code ELIFECYCLE
npm ERR! bignum@0.12.5 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the bignum@0.12.5 install script 'node-pre-gyp install --fall
npm ERR! This is most likely a problem with the bignum package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR!     node-pre-gyp install --fallback-to-build
npm ERR! You can get information on how to open an issue for this project with:
npm ERR!     npm bugs bignum
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!
npm ERR!     npm owner ls bignum
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
Is there anyone who can help me with this?
Marci
Post by Marci » Monday 10 October 2016 23:16
See tutorial in the eDomoticz thread, and instructions on the homebridge GitHub page:
sudo npm install -g homebridge --unsafe-perm
Tharland
Post by Tharland » Saturday 15 October 2016 13:58
i have installed homebridge, and i see my accessories but when i speak to siri she doenst understand what to do... how i i activate siri to turn on lights ?
Marci
Post by Marci » Saturday 15 October 2016 14:13
'Hey Siri, turn on {name of device}'
Tharland
Post by Tharland » Saturday 15 October 2016 14:45
Marci wrote:'Hey Siri, turn on {name of device}'
thanks! maybe should change siri to english, simplier :)
deejc
Domoticz version: 3.5641
Post by deejc » Saturday 15 October 2016 15:07
Try http://hey-siri.io for all the commands Siri understands
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
robyhood
Domoticz version: 3.5817
Post by robyhood » Tuesday 25 October 2016 16:30
Hi there!
I'm quite new to Raspberry, Domoticz and Homebridge. I've been reading this forum since some days to make my domotic system works and until now eveything was working fine.
I'm running Domoticz 3.5817 on a Raspberry Pi model B, with Homebridge installed.
Homebridge is working like a charm, I'm using it to control with Homekit a relay board connected to Rpi's GPIO pins, and in Homekit I control a Philips Hue bridge, too.
Now, I'd like to make Hombridge recognize Domoticz platform to control (and maybe sync the state of) my devices, but something is wrong...
The issue is that homebridge doesn't recognize Domoticz as platform and I'm not able to read it's devices on Homekit app.
This is my config.json file:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
    "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
   "platforms": [
      "name": "Domoticz",
      "port": "8080"
    "accessories": [
        "accessory":      "FakeBulb",
        "name":           "Test lamp",
        "bulb_name":      "Lamp1"
      "accessory": "GPIO",
        "name": "GPIO23",
        "pin": 23,
        "inverted": "false"
        "name": "GPIO24",
        "pin": 24,
        "inverted": "false"
        "name": "GPIO25",
        "pin": 25,
        "inverted": "false"
    "platforms": [
Domoticz is running on the Rpi so the localhost 127.0.0.1 IP is correct and it is running on port 8080, too.
But when I start Homebridge service, I receive the following messages...
 Loaded config.json with 4 accessories and 0 platforms.
(... snip... snip...)
Loading 0 platforms...
Loading 4 accessories...
I can't figure out what the problem is... I mean, I understand that Homebridge is not loading Domoticz platform, but I can't understand why...
Could you please help me or give me some advice?
Thank you very much.
Roberto.
