Domoticz App Topic is solved
Harald1966
Re: Domoticz App
Post by Harald1966 » Sunday 17 December 2017 19:00
Can anybody help me
I m just fresh in the Domoticz story
Install the server on my synology
runs perfect
IP are 192.168.0.116
Https port 8443
http port 8084
I set up a user an password on my server
both work perfect in the browser
Now I like to use the app on my Iphone with are in my home network.
But what ever I add it can not find the server. Not with 8443 or 8084.
What should be in the directory ?
Harald1966
Re: Domoticz App
Post by Harald1966 » Monday 18 December 2017 18:02
Hi get now at least inside local network a connection.
Server setting
result = ok
But than ?
No button to save or next slide . I can only go back.
How should I go now ?
Harald
galadril
Target OS: Raspberry Pi
Domoticz version: latest
Re: Domoticz App
Post by galadril » Wednesday 20 December 2017 21:06
The directory is for exapmle:
"http://192.168.1.25:8080/domoticz/#/Dashboard"
if this is you rdashboard url, then domoticz is your directory..
galadril
Re: Domoticz App
Post by galadril » Wednesday 20 December 2017 21:08
Server setting
result = ok
Do you get that result on https?? (with self signed certificate...?)
i000
Re: Domoticz App
Post by i000 » Wednesday 20 December 2017 21:56
Hi! For me over WiFi is not possible interact with home. Only if I disconnected wifi.
Harald1966
Re: Domoticz App
Post by Harald1966 » Wednesday 20 December 2017 21:58
Thanks for answer I move to a other plattform.
Harald
galadril
Re: Domoticz App
Post by galadril » Tuesday 02 January 2018 16:33
Just to let you know. -> There's a new beta coming one of these days..
- Fixed barometer graphs not showing
- Added possibility to change User Variables
- Added possibility to enable/disable Events
- Changed some layout files for better look on Tablets
- Added Demo setup + Reset button to Server Settings page
- Updated version of Xamarin Forms (+ other libs that i use)
PS Happy New Year
fvdl
Domoticz version: 3.9501
Re: Domoticz App
Post by fvdl » Sunday 07 January 2018 23:40
I'm new to Domoticz
I run a system on an Raspi3-B with Raspian stretch lite and Razberry z-wave+ device. Switches and door sensors NeoCoolcam
(all latest update/upgrade)
on my Iphone i use the Domoticz app and Prowl for push notification (no problem)
Domoticz works fine except for the Domoticz app
it works oké but the switches and sensors don't toggle right if a sensor switches on. When a switch or sensor is activated by Domoticz the switches keep white instead of green.
in the log it's oké
if i use the switches on the Iphone they do toggle right and very fast
everytime i restart the app it's shows the proper situation
the app shows a good server connection
is this a known issue? hope someone can give me a hint
henrybcn
Target OS: OS X
Re: Domoticz App
Post by henrybcn » Monday 08 January 2018 13:38
Hi, I am having a similar issue with the app. It worked well until Xmas, but I updated and now on the server setting I can only input either the external/DNS url OR the local IP/port I have my domoticz. If I add both (with the button "use different address for local connection"), it does not work :( Any idea why? Is anyone else experiencing the same?
marcotrumpet
Re: Domoticz App
Post by marcotrumpet » Monday 08 January 2018 13:59
Mine works only if I use username and password in domoticz..
Inviato dal mio iPad utilizzando Tapatalk
fvdl
Re: Domoticz App
Post by fvdl » Tuesday 09 January 2018 1:11
I created a virtual switch in Domoticz.
When i push this switch on my Iphone everything will refresh correctly
It's a temporarily solution, but it works
Tino4785
Re: Domoticz App
Post by Tino4785 » Sunday 14 January 2018 22:09
Hey
what a super system and a super app ...
I do have a question about the notifications. if I send a test notification I will receive it .. but otherwise how is this possible?
greeting martijn
Cavas
Target OS: OS X
Re: Domoticz App
Post by Cavas » Tuesday 23 January 2018 18:19
I bought it for notification but I don't have any sounds on notifications.
Any idea about that ? :|
Thanks.
galadril
Re: Domoticz App
Post by galadril » Monday 29 January 2018 11:23
it shoud use the sound settings that all notifications use
galadril
Re: Domoticz App
Post by galadril » Monday 29 January 2018 11:24
Whats the issue?
Can I test against your system?
galadril
Re: Domoticz App
Post by galadril » Monday 29 January 2018 11:25
New feature in next version is:
Use a different language then the default phone language..
I added that settings on the settings page
marcotrumpet
Re: Domoticz App
Post by marcotrumpet » Monday 29 January 2018 12:17
Whats the issue?
I don’t know why but if I use my domoticz system without username and passeord the app give me a connection error (it work for a minute or so and then the error appear) but I found out that if I set user and passwd I can use the app without problem at all.
Inviato dal mio iPhone utilizzando Tapatalk
djac
Re: Domoticz App
Post by djac » Friday 02 February 2018 15:04
I am sorry to ask the basic question, I have seen other have the same issues so maybe resolved but not answered here.
Can you please indicate what needs to be added to the "Server settings" page, I have a plain setup without password and I try to access from same network but I get the "Error: not connected to network"?
In a browser I connect with https://192.168.1.177/#/Dashboard
djac
Re: Domoticz App
Post by djac » Sunday 04 February 2018 12:18
I actually got it up and connected now, I see everything that I see in the web interface but here comes a strange thing... I cant use the buttons, meaning I can see the switches and they go to "green" but they don't turn the devices on or off?
galadril
Re: Domoticz App
Post by galadril » Tuesday 06 February 2018 9:56
Does you account that you use to login have enough rights to flip the switches?
is it an admin account on domoticz?
