Pushbullet notification only show header
tyho
Target OS: Raspberry Pi
Post by tyho » Sunday 15 January 2017 19:03
Hello everyone,
I am new to domoticz and i have a question ^^:
I use pushbullet for push notification on my iphone and on chrome (PC).
I have added my smart meter to my raspberry and i want to get a notification when i use 5000W+
My problem is, i see only the header called Domiticz. So my push notifications on my login/home screen look like:
Pushbullet
Domoticz
If i open the message it shows also "Your usage is ***** watt.", but not on my login/home screen
On Chrome it shows:
Pushbullet
Domoticz
Is there a way i also get it this way on my iphone?
Maybe remove the header and only show the message
Pushbullet
drmabuse71
Re: Pushbullet notification only show header
Post by drmabuse71 » Thursday 02 February 2017 11:52
Got the same problem,
seems to be a problem with pushbullet,
occured since their latest update.
searched the web but couldn´t find any solution
kleinspr
Post by kleinspr » Saturday 04 February 2017 13:31
Hi I am Hans , from Eindhoven(NL)
Same issue when someone uses a apple watch
the message shows:
PUSHBULLET
with message Domoticz, and not the message it self
And if you are using the iphone, some issue
and if you are opening the pushbullet app you get the real information
najtram
Domoticz version: v3.5877
Post by najtram » Thursday 09 November 2017 10:27
Maybe a solution!!
I had the same issue en noticed the reason for my situation. My issue showed up for notifications triggered from blocky events. In the blocky events I was a bit to lazy to use different texts ;) . When these texts are the same, pushbullet uses the text domoticz as header. When they are different you will receive the header.
So in short: DON'T use the same text twice. :idea:
:arrow: (at least in blocky events in combination with iOS)
Domoticz on Raspberry Pi 3 with USB RFLink Gateway at 433 Mhz for several KAKU switches. Bluetooth Soma Smart Shades. USB Opentherm Gateway connected to Remeha iSense with Remeha Tzerra boiler. ITHO ecofan RFT (ESP8266+CC1101). Almost running homebridge.
