Cheap Chinese IP Camera find Snapshot with ONVIFER
JHO01
Target OS: Raspberry Pi
Domoticz version: 49700
Post by JHO01 » Monday 04 June 2018 18:08
I recently bought some cheap chinese ip camera's with ONVIF RTSP support, not expecting the snapshot capability, but....... to my surprise I accidentally did find the precious snapshot link with the help of ONVIFER
https://nl.aliexpress.com/item/H-265-H- ... 4c4dSmCSlm
https://nl.aliexpress.com/item/ONVIF-P2 ... autifyAB=0
Install https://play.google.com/store/apps/deta ... ifer&hl=en (free) on an Android device and setup the camera.
Once the camera is detected, press test and the link to the snapshot stream is visible :
http://192.168.2.211/webcapture.jpg?com ... &channel=1
In Domoticz, Add Camera and fill in what is discovered in ONVIFER
IP address: 192.168.2.211
Port: 80
imageURL: webcapture.jpg?command=snap&channel=1
Please note:
The above mentioned camera's are almost constantly trying to communicate with the outside world:
23.91.102.185:8086
23.91.102.59:8086
203.12.203.24:8086
My pFsense firewall does not allow this :mrgreen:
RPI-3, Z-stick Gen5, RFlink, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, , BMP018
EdwinK
Re: Cheap Chinese IP Camera find Snapshot with ONVIFER
Post by EdwinK » Wednesday 13 June 2018 22:16
I think something has changed in the app, I can't get this information for my camera.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
gielie
Domoticz version: latest β
Post by gielie » Thursday 14 June 2018 9:37
All chinese cams are phoning home, if someones buying a chinese cam make sure to block all outside communications, big brothel is watching you.
- Vision ZU1401 USB Stick
- Aeotec MultiSensor 6
- FIBARO FGS222
- FIBARO FGWPE Wall Plug
- Everspring AN157
- Neo CoolCam Power plug
- Neo CoolCam PIR Sensor
- Popp Smoke Detector
- Toon
- Kodi Media Server
JHO01
Post by JHO01 » Thursday 14 June 2018 10:38
I am running ONVIFER 12.01
Procedure:
-install camera
-right click on camera feed
-select edit and scroll down to see the snapshot address (if available)
alternative
-install camera
-select edit
-select test
-scroll down to see the snapshot address (if available)
EdwinK
Post by EdwinK » Thursday 14 June 2018 11:28
O.. You use a web version. I had it on Android phone.
