Light percentage sensor
korniza
Target OS: Raspberry Pi
Domoticz version: V3.6028
Post by korniza » Saturday 03 December 2016 20:51
Looking a way to maximize the data that my cameras are getting, I found a script that can measure the percentage of light that camera can read using the following pyhton script and a virtual percentage sensor.
You have to change/remove username:password on what you have saved on your camera interface for user access.
Also <DEVICEID> is the idx of percentage sensor.
You will also install imagemagick.
The mechanism is to resize image to 1 pixel and measure the percentage of light on this pixel.
credits go here: https://matdomotique.wordpress.com/2016 ... camera-ip/
import os, sys
import requests
from subprocess import Popen, PIPE
process = Popen(['wget','-O','/home/pi/shot'+'cam'+'.jpg','http://username:[email protected]'+'/image/jpeg.cgi'], stdout=PIPE)
(output, err) = process.communicate()
exit_code = process.wait()
process = Popen(["convert /home/pi/shot"+'cam'+".jpg -colorspace hsb -resize 1x1 txt: | grep \",*%)\" | cut -f 6 -d ',' | cut -c -5"], stdout=PIPE, shell=True)
value = str(output).replace('\n','')
url = 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=<DEVICEID>&nvalue=0&svalue=' + value
r = requests.get(url)
>>>> Google Home <<<<<
Users browsing this forum: No registered users and 4 guests
