Vaillant EBUS
arudomoticz
Target OS: Raspberry Pi
Vaillant EBUS
Post by arudomoticz » Sunday 11 December 2016 12:15
I have a working Domoticz environment on a Raspberry
With the USB RFXtrx433E USB 433.92MHz Transceiver I can read all my Oregon Temperatures and log them
I also have now a Raspberry with a working EBUS environment.
I use the eservice-online ebus-koppler-usb and the ebusd drivers (from john30)
If I start a telnet localhost 8888 session, then with the command "r -f roomtemp" I receive the message "21.50;OK" in Telnet
In which way can I put the value of the roomtemp from my Vaillant Calormatic 470 in Domoticz and log them?
pvm
Domoticz version: Stable
Re: Vaillant EBUS
Post by pvm » Sunday 11 December 2016 13:11
You can use a dummy device and fill that with a json call to domoticz (see wiki for last part)
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
ropske
Domoticz version: V3_8394
Re: Vaillant EBUS
Post by ropske » Tuesday 10 January 2017 13:06
arudomoticz wrote:I have a working Domoticz environment on a Raspberry
hi,
could you please show me some picture and give me some more information how you did this?
I also have a vaillant heater and would be able to do the same as you.
Thank you!
arudomoticz
Re: Vaillant EBUS
Post by arudomoticz » Tuesday 17 January 2017 16:25
Thanks PVM for your reply, due to some circumstances I had a lack of time to continue this project before.
Now starting again to try to make it happen.
I have read the JSON part ad tried the following after making a dummy temperature-sensor
http://192.168.178.135:8080/json.htm?ty ... alue=21.50
Result is OK and my sensor goes to 21.50!
Thats the manual part...
But how I can read it from the EBUSCTL and writeback to DOMOTICZ ?
Must I use a LUA script, do you (or somebody) have a code example?
or at SSH
ebusctl -p 8888 read roomtemp I receive the message "21.50;OK" in SSH
deennoo
Re: RE: Vaillant EBUS
Post by deennoo » Tuesday 17 January 2017 17:21
Please can you explain how you do this ?
Does your koppler is on the same wire than your room thermostat ?
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
arudomoticz
Re: Vaillant EBUS
Post by arudomoticz » Wednesday 18 January 2017 10:08
Hi, I am using https://blog.sanghera.me.uk/vaillant-eb ... utomation/
Everything works manually.
or at SSH
So Ebusctl works AND Domoticz works, but how can I pass values from Ebusctl to Domoticz?
So how do I get the "21.50" in Domoticz?
Must I use a LUA script, is there somebody who can help me with a code example?
Sappien
Re: Vaillant EBUS
Post by Sappien » Wednesday 18 January 2017 21:21
You could make a bash script like
#!/bin/bash
TEMP=`ebusctl -p 8888 read roomtemp | cut -d\; -f1 | cut -d\" -f2`
echo $TEMP
curl -s "http://127.0.0.1:8080/json.htm?type=com ... ice&idx=[b]IDX[/b]&nvalue=0&svalue=$TEMP"
Barberousse
Re: Vaillant EBUS
Post by Barberousse » Thursday 07 December 2017 21:15
Hello, I made a ebusd plugin here: viewtopic.php?f=65&t=20625
