Luxtronic Heatpump controller
Aandegrens
Re: Luxtronic Heatpump controller
Post by Aandegrens » Friday 02 June 2017 21:56
Is this the only error you are getting.
Comment that part out and try the rest.
vaevictis
Post by vaevictis » Friday 02 June 2017 23:09
Aandegrens wrote:Is this the only error you are getting.
All lines are giving the same error. How can I deduct what value is for what field? I have a Alpha Innotec WSZ heatpump.
Aandegrens
Post by Aandegrens » Friday 02 June 2017 23:23
I can't help you any further because i'm not a Python specialist.
Are you using Python 3.4.2?
It looks like the following part doesn't works correctly:
stat = struct.unpack( '!i', s.recv(4))[0]
len = struct.unpack( '!i', s.recv(4))[0]
array_calculated = []
for i in range(len):
    array_calculated.append(struct.unpack( '!i', s.recv(4))[0])
I've got it working with trail and error.
At least you can get de data from the heatpump and that's the first step.
I checked the values by comparing them directly with the values shown on the display of the heatpump.
vaevictis
Post by vaevictis » Friday 02 June 2017 23:28
Aandegrens wrote:I can't help you any further because i'm not a Python specialist.
Yes python 3.4.2, anyone else? It seems that index of the array is invalid somehow.
vaevictis
Post by vaevictis » Saturday 03 June 2017 9:18
Got it working! Did some cleanup of the code for Python 3.
#!/usr/bin/python3.4
import socket
import struct
import datetime
import http.client
# Luxtronik 2.0 IP
hostHeatpump = '10.50.2.160'
# Luxtronik 2.0 port (standard 8888)
portHeatpump = 8889
# Empty variables
leng = 0
s = socket.socket( socket.AF_INET, socket.SOCK_STREAM)
s.connect( (hostHeatpump, portHeatpump))
s.send( struct.pack( '!i', 3004))
s.send( struct.pack( '!i', 0))
if struct.unpack( '!i', s.recv(4))[0] != 3004:
        print("Error: REQ_CALCULATED CMD")
        exit()
leng = struct.unpack( '!i', s.recv(4))[0]
for i in range(leng):
print("Calculated")
print(stat)
print(leng)
print(array_calculated)
print("\n")
print("Temperatuur buiten : ", array_calculated[15] /10)
print("Temperatuur voorloop : ", (str(float(array_calculated[10])/10)))
print("Temperatuur naloop : ", (str(float(array_calculated[11])/10)))
print("Terugloop Doel : ", (str(float(array_calculated[12])/10)))
print("WQ ingangs temp : ", (str(float(array_calculated[19])/10)))
print("WA uitgang temp : ", (str(float(array_calculated[20])/10)))
print("Bedrijfstijd Verdichter 1 : ", (str(datetime.timedelta(seconds=int(array_calculated[56])))))
print("Impuls VD1 : ", (str(array_calculated[57])))
print("Bedrijfsuren WP : ", (str(datetime.timedelta(seconds=int(array_calculated[63])))))
print("Bedrijfsuren Verwarming : ", (str(datetime.timedelta(seconds=int(array_calculated[64])))))
print("Verbruik verwaming (kWh) : ", (str(float(array_calculated[151])/10)))
print("Verbruik heet water (kWh) : ", (str(float(array_calculated[152])/10)))
print("Bedrijfsuren WW groei : ", (str(datetime.timedelta(seconds=int(array_calculated[65])))))
print("Status regel 1 (code) : ", (str(array_calculated[117])))
print("Status regel 2 (code) : ", (str(array_calculated[118])))
print("Status regel 3 (code) : ", (str(array_calculated[119])))
print("Status sinds : ", (str(datetime.timedelta(seconds=int(array_calculated[120])))))
print("WMZ doorloop l/h : ", (str(float(array_calculated[155]))))
#Haven't got this below running yet.
#conn = httplib.HTTPConnection("192.168.1.5:8080")
#conn.request("HEAD","/json.htm?type=command&param=udevice&idx=191&svalue=" + (str(float(array_calculated[151])*100)))
# res = conn.getresponse()
#print res.status, res.reason
s.close()
poostrom
Target OS: Raspberry Pi
Domoticz version: Latest
Post by poostrom » Monday 12 June 2017 15:57
I didn't see any replies since the last couple of months ;)
Anyway, I've got it working all the way. I didn't use the kWh anymore, since the values are not not electrical kWh's but heating, so there is a huge difference between these values and the actual electrical power consuming....
See the attachments for temperatures, which is working fine ;)
2017-06-12 16_02_22-Domoticz.jpg (77.21 KiB) Viewed 1826 times
vaevictis
Post by vaevictis » Monday 12 June 2017 16:02
poostrom wrote:I didn't see any replies since the last couple of months ;)
Can you share your code?
poostrom
Post by poostrom » Monday 12 June 2017 16:09
Sure ;)
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
hostHeatpump = '192.168.200.107'
portHeatpump = 8888
        print 'Error: REQ_CALCULATED CMD'
        exit()
for i in xrange(len):
s.close ()
# Temp buiten
conn = httplib.HTTPConnection("192.168.200.15:8080")
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=924&nvalue=0&svalue=" + (str(float(array_calculated[15])/10)))
# Temp aanvoer
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=188&nvalue=0&svalue=" + (str(float(array_calculated[10])/10)))
# Temp retour
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=189&nvalue=0&svalue=" + (str(float(array_calculated[11])/10)))
# Bron in
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=190&nvalue=0&svalue=" + (str(float(array_calculated[19])/10)))
#Bron uit
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=191&nvalue=0&svalue=" + (str(float(array_calculated[20])/10)))
#Heet water temperatuur
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=200&nvalue=0&svalue=" + (str(float(array_calculated[17])/10)))
#Heet gas compressor temperatuur
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=229&nvalue=0&svalue=" + (str(float(array_calculated[14])/10)))
# Lees huidige functie warmtepomp
if array_calculated[119] == 1: array_calculated[119] = '0'
if array_calculated[119] == 0: array_calculated[119] = '10'
if array_calculated[119] == 5: array_calculated[119] = '20'
if array_calculated[119] == 10: array_calculated[119] = '30'
if array_calculated[119] == 15: array_calculated[119] = '30'
conn.request("HEAD","/json.htm?type=command&param=updateuservariable&idx=5&vname=warmtepomp_functie&vtype=uservariabletype&vvalue=" + (str(array_calculated[119])))
tweakertje
Post by tweakertje » Friday 27 October 2017 21:15
I´m trying to get the switch working but it keeps logging I want only the changes in the log not every minute when the script runs.
this is my json
conn.request("HEAD","/json.htm?type=command&param=switchlight&idx=327&switchcmd=Set%20Level&level=" + (str(array_calculated[119])))
2017-10-27 21:09:02 StartBlokkering
2017-10-27 21:08:02 StartBlokkering
2017-10-27 21:07:02 StartBlokkering
2017-10-27 21:06:02 StartBlokkering
2017-10-27 21:05:02 StartBlokkering
2017-10-27 21:04:02 CV
2017-10-27 21:03:02 CV
2017-10-27 21:02:02 CV
2017-10-27 21:01:03 CV
2017-10-27 21:00:04 CV
2017-10-27 20:59:03 CV
poostrom, how is yours???
when I use yours it responde with an OK but threre is nothing changed...
conn.request("HEAD","/json.htm?type=command&param=updateuservariable&idx=327&vname=warmtepomp_functie&vtype=uservariabletype&vvalue=" + (str(array_calculated[119])))
please help...
Wiljums
Post by Wiljums » Sunday 11 February 2018 23:02
Can someone provide instructions how to get this working for a noob with raspberry and python?
Wiljums
Post by Wiljums » Friday 09 March 2018 22:08
Sure ;)
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
        exit()
s.close ()
# Temp buiten
# Temp aanvoer
# Temp retour
# Bron in
#Bron uit
Hi, could you help to get this working in Domoticz? What should I do with this code? Snap er de ballen van..
Ronker
Post by Ronker » Saturday 10 March 2018 8:31
Sure ;)
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
        exit()
s.close ()
# Temp buiten
# Temp aanvoer
# Temp retour
# Bron in
#Bron uit
The script doesn't get the output that you earlier showed on the picture. I cant find the kWh in the script could you explain? Sorry my bad didn't read your text from the picture message
Ronker
Post by Ronker » Saturday 10 March 2018 8:35
Sure ;)
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
        exit()
s.close ()
# Temp buiten
# Temp aanvoer
# Temp retour
# Bron in
#Bron uit
In hardware you can add a dummy and than add virtual sensors. If you did this you can see the virtual sensor in devices.
Every virtual sensor gets an IDX copy this and place it where I put the star *
# Temp buiten
conn.request("HEAD","/json.htm?type=command&param=udevice&idx=924&nvalue=0&svalue=" + (str(float(array_calculated[*])/10)))
To get output from the script you can create a cron job that is running every minute.
You can send me a pm if you want.
Wiljums
Post by Wiljums » Tuesday 20 March 2018 9:21
I also found this piece of software: https://github.com/coolchip/luxtronik2
In the code you find: 'Read all readable data'. So it might extract more data than the tool in this forum.
Which one is better do you think?
poostrom
Post by poostrom » Thursday 29 March 2018 11:07
Sure ;)
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
        exit()
s.close ()
# Temp buiten
# Temp aanvoer
# Temp retour
# Bron in
#Bron uit
# Temp buiten
You placed the star at the wrong position. array_calculated[*] is the place in the array being read from the luxtronik. You should leave that. You should change the udevice&idx=924 to the right device in Domoticz. So 924 should be changed to whatever ID is being used in your own virtual sensor ;)
poostrom
Post by poostrom » Thursday 29 March 2018 11:11
Interesting ;)
My script (carefully stolen) only reads stuff. It actually reads everything from the Luxtronik, but I use just the things I want to...
The interesting about this script is that it can actually send commands to the Luxtronik. So in theory you should be able to change values through Domoticz...
See if I can make it work :)
Regards,
Patrick
Wiljums
Post by Wiljums » Sunday 15 April 2018 9:23
Interesting ;)
Regards,
Patrick
Have you got it working?
poostrom
Post by poostrom » Tuesday 17 April 2018 11:20
Hi Wiljums,
It's working. You need to install nodered for it (and the other stuff for the luxtronik as well). (I only looked at setting values, not reading, though that works as well).
The only thing I made working is the + and - temperature setting. I made a virtual selector switch and every step runs a script from domoticz. Bit complicated, but I don't have the knowledge how to integrate it. You can have node talk to MQTT which talks to Domoticz, but really don't know how that works. I only needed the + and - temp setting, so it works...
The action on the selector switch in Domoticz:
script:///home/pi/domoticz/scripts/node/temp+10.sh
and the content of the shell script temp+10.sh:
node /home/pi/domoticz/scripts/node/temp+10.js
The temp+10.sh needs to be executable
and the content of the node script temp+10.js:
const luxtronik = require('/home/pi/node_modules/luxtronik2/luxtronik');
/* eslint no-console: "off" */
const pump = luxtronik.createConnection('192.168.200.145', 8888);
pump.write('heating_target_temperature', 1, function (err, data) {
if (!err) {
console.log(data);
The '1' after target temperature is the setting, so either 0,1,2,3,4,5 or -1,-2,-3,-4,-5
The luxtronik doesn't go beyond +5 or -5 degrees.
Good luck ;)
Users browsing this forum: No registered users and 4 guests
