JSON API: access by name instead of IDX
heggink
Target OS: Raspberry Pi
Domoticz version: V3.9530
Post by heggink » Monday 14 May 2018 20:57
Was this ever considered? I have a number of scripts running on different systems that update devices using json/curl. Enabling these to be updated by name is much more future proof if ever I need to switch devices, rebuild the system and so on...
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
u01pei
Re: JSON API: access by name instead of IDX
Post by u01pei » Monday 14 May 2018 21:22
I Don't know if it would be so easy to use the name in the api, I think you get some extra difficulties when your switch name has a space in it.
But fortunately there is a work-around, I've been using this for some years now and it works like a charm!
I use shell scripts to control my house and I have 1 script called Config.sh. It contains a lot of switches by name and every name has a value assigned to it (the idx).
like this:
        idxBadkamerLicht="1178"
        idxBankLicht="714"
        idxEettafelLicht="676"
        idxHalLicht="674"
        idxKeukenLicht="687"
        idxOverloopLicht="1069"
        idxTuinPuiLicht="796"
        idxTuinSchuurLicht="805"
        idxTrapLED="1168"
        idxTVLicht="698"
        idxVoordeurLicht="675"
        idxwasmachine="1227"
        idxZolderLicht1="1066"
        idxZolderLicht2="1067"
It also contains most of the commonly used api calls as a function:
# GET Status NON-Dimming Devices:
    # Format: DeviceStatus=$(GetStatus $idxDevice JQ_Search_Term)
GetStatus() {
curl -s "$Server/json.htm?type=devices&rid=$1" | jq '.result[0].'$2'' | tr -d '"'
In order to use this you create a script as you would usually do and add a line just below the shebang which refers to your config file:
source /home/pi/scripts/Config.sh
Then as you write your script you can use the shortcuts that you have created.
The following will return the status of my kitchen lights as On or Off:
Status=$(Getstatus $idxKeukenLicht Status)
It is also useful for a lot of other functions, like sending a telegram message:
TelegramJeroen() {
curl -s --data chat_id=$JeroenID "https://api.telegram.org/bot$PiBot/sendMessage" --data-urlencode text="$@"
So instead of typing the stupid url's and remembering all the IDX numbers I use referrals and use a naming system that makes sense to me.
It makes script writing a lot easier and quicker! downside is that scripts can't be shared very easy (from me to others).
heggink
Post by heggink » Wednesday 16 May 2018 10:12
Whilst I like the approach, you would still need to know the idx of the device. Agree that you could just build a simple function that retrieves the idx from a json query on startup and use that going forward but that indeed is a workaround generating (useless) extra queries.
In addition, I 'repurposed' both bash and python scripts so I would need to build something for both occasions again duplicating effort.
Spaces in device names really should not be any issue since this has been around for ages and json calls can handle these.
Pi3, latest beta
Harmony hub, Nest
zak45
Domoticz version: V3.9056
Post by zak45 » Wednesday 16 May 2018 12:49
Before that, 'unique device name' should be implemented.
heggink
Post by heggink » Wednesday 16 May 2018 17:23
Why? I would consider that end user responsibility and take the first hit...
Pi3, latest beta
Harmony hub, Nest
Post by waaren » Wednesday 16 May 2018 18:06
have you tried to add a unique index on DeviceStatus(Name) ?
Would be interesting to see if that break something.
Off course you have to delete double entries first and drop the index for a moment when you accept new hardware.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
morilm
Target OS: OS X
Post by morilm » Thursday 24 May 2018 20:29
why don't you use the
d_name = "device name"
d_idx = otherdevices_idx[d_name]
this way you can get always the corresponding IDX for a device and use it not only on JSON but on all scripts.
Users browsing this forum: Bramz, wvries and 4 guests
