Make blockly Else if to an actual else if
ash77
Re: Make blockly Else if to an actual else if
Post by ash77 » Saturday 24 February 2018 2:22
Yeah, I spoke too soon. When m_events is filled from the database for Blockly events, it just remembers a set of condition/action pairs and doesn't remember which Blockly each pair came from.
For example, if I create this Blockly (call it A):
1. condition: temp < 25
action: .....
2. condition: temp > 26
action: .....
then I create a completely different Blockly (call it B):
1. condition: hum > 40
action: .....
2. condition: hum > 20
action: .....
When m_events is loaded, it contains:
action: .....
action: .....
3. condition: hum > 40
action: .....
4. condition: hum > 20
action: .....
with no way to determine that 1 and 2 came from Blockly A and 3 and 4 came from Blockly B. With the change I suggested, if #1 evaluates to true, it will never evaluate 3 which is incorrect.
It will be necessary to change the code in CEventSystem::LoadEvents() to retain EMID for each row from EventRules.
When a true condition is found (after parseBlocklyActions()), skip all remaining items in m_events with the same EMID as the one that was true.
All that being said, I agree with leonmoonen that this change is going to break some existing Blockly scripts. You can count on it.
gizmocuz
Target OS: Raspberry Pi
Post by gizmocuz » Saturday 24 February 2018 10:22
@ash77, not sure i understand, but m_events (or the database is easier to check) is correct looking at your actions
You configured 4 actions (no complicated else stuff), and 4 actions are created and will be checked.
No need to know it is from A or B
Unless you meand that 2. condition: temp>26 was a 'else', in this case i can say that never worked and was/is the problem.
It won't break, making the patch will actually solve issues
Xztraz
Post by Xztraz » Monday 26 February 2018 0:20
i guess this fix excludes else (only else) ? or is it possible to integrate that too? :)
i3laze
Post by i3laze » Thursday 26 July 2018 10:01
I'm trying to implement If [cond.] Do Else Do..
When I leave 'Else if' :arrow: condition as empty, Else Do-block doesn't fire.
Where can I get a 'True' block? :D
How about changing block's behavior for omitted condition to 'True' or adding simple 'Else' as a ⚙ block option?
Users browsing this forum: JoshDinsdale and 1 guest
