Lidl NL: Weather station with outside sensor
Spotted a nice hardware deal? Share here!
rlandor
Target OS: Raspberry Pi
Re: Lidl NL: Weather station with outside sensor
Post by rlandor » Thursday 23 February 2017 18:41
Bought three of these with brand name OWIM. The model number on the temperature station is HG00073A-TX. I cannot get them to appear in Domoticz, I downgraded the firmware to version 1009. Any tips to get this working?
rotero
Domoticz version: V2.2284
Post by rotero » Saturday 25 February 2017 22:35
rlandor wrote:Bought three of these with brand name OWIM. The model number on the temperature station is HG00073A-TX. I cannot get them to appear in Domoticz, I downgraded the firmware to version 1009. Any tips to get this working?
You can also test the other firmware types. I don't mean the version numbers, but the Type1, Type2, Ext or Ext2 (Ext and Ext2 only for RFXtrx433E).
Checkout the RFXCOM manual te see which protocols work with which firmware type.
RFXCOM Manual:
http://www.rfxcom.com/WebRoot/StoreNL2/ ... _Guide.pdf
Good luck!
Regards,
Rob
coolwine1962
Domoticz version: V3.8446
Post by coolwine1962 » Sunday 12 March 2017 21:20
Just bought 4 pieces of these Weather station with outside sensors via the Lidle webshop
I can confirm that this is working fine on the old rfxcom
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Type1/1015
Great value for money,
They send there data a lot, approx every 30 second.
1 x HP Gen8 Domoticz V3.5299
1 x ANT GP433Mhz
1 x Rfxcom
5 x TFA
1 x RainSensor
5 x Kaku Switch
5 x KD101
1 x BMP085
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
2 x Fibaro WPG
8 x Greenwave 6
1 x Pi slave for Electra and Gas
EdwinK
Domoticz version: Stable
Post by EdwinK » Wednesday 24 May 2017 15:27
After a few months, are you still happy with these sensors? Want to buy some, but need to be sure if they will work and are stable.
Edit: I ordered 3 of them. Hope they will work right out the box.
Running latest BETASTABLE on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
Jakke2440
Post by Jakke2440 » Thursday 01 June 2017 13:06
thanks bravo.
dowgrading to 1009 did the trick by me also.
I'm now wondering if it is the antenna or domoticz is the problem
.... confusing ...
maluko
Post by maluko » Thursday 01 June 2017 15:04
i have the domoticz v. 3.750 and RFXCOM - RFXtrx433 USB 433.92MHz Transceiver Version: Type1/1017 and now its working well.
EdwinK
Post by EdwinK » Friday 02 June 2017 20:48
[removed post]
EdwinK
Post by EdwinK » Friday 02 June 2017 23:36
It seems to work now. Moved a little closer to the RFxcom. Tomorrow the other two, and then figuring out how to move the transciever so it can reach the sensor in the living room.
EdwinK
Post by EdwinK » Saturday 03 June 2017 11:15
Got them working now. sort off.
They do appear in the Domoticz device listing, and I can see the temperatur, but... only one time. Looks like it isn't refreshing it self. Looking in the log i see this happening every 30 seconds or so.
2017-06-03 10:56:50.729 2017-06-03 10:56:50.729 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:57:21.369 2017-06-03 10:57:21.369 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:57:52.140 2017-06-03 10:57:52.140 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:58:22.760 2017-06-03 10:58:22.760 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:58:53.380 2017-06-03 10:58:53.380 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:59:24.060 2017-06-03 10:59:24.060 Hardware Monitor: Fetching data (System sensors)
2017-06-03 10:59:54.680 2017-06-03 10:59:54.680 Hardware Monitor: Fetching data (System sensors)
2017-06-03 11:00:25.300 2017-06-03 11:00:25.300 Hardware Monitor: Fetching data (System sensors)
2017-06-03 11:00:56.081 2017-06-03 11:00:56.081 Hardware Monitor: Fetching data (System sensors)
Looks like somehow the sensors are being seen as System sensors.
Version: Type1/1015
mrf68
Domoticz version: 3.4834
Post by mrf68 » Monday 05 June 2017 11:38
I got interested in those sensors when I saw this topic and how much they cost. So I bought two, installed the batteries and it works for me. They show up as shown in the screenshot.
EdwinK
Post by EdwinK » Monday 05 June 2017 17:28
mrf68 wrote:I got interested in those sensors when I saw this topic and how much they cost. So I bought two, installed the batteries and it works for me. They show up as shown in the screenshot.
They do show up, but somehow don't show the temperature. In the log are some data that i suspect comes from those sensors, but they show as 'system sensor'.
mrf68
Post by mrf68 » Monday 05 June 2017 17:52
When I enable the "Motherboard sensors" on tab Setup - Hardware then the log looks like your screenprint in your post from 03 june. I think it has nothing to do with the temperature sensors. You could temporarily stop the Motherboard sensors to check what happens. Did you filter the results in the Log or is nothing else showing up?
As for me, the sensors show up in the Devices list, I added them to my inventory and they show up at my dashboard. They send their data every 31 seconds. From the Log:
EdwinK
Post by EdwinK » Monday 05 June 2017 17:57
I have them in devices and in the dashboard, nothing much happens.
Screen Shot 2017-06-05 at 18.00.25.png (62.72 KiB) Viewed 2701 times
So, the last time data was received was a few days ago, and that was the only time.
mrf68
Post by mrf68 » Monday 05 June 2017 18:41
Okay, then I can only think of one thing: they're signal don't reach the receiver, because of their distance or due to interference. I'm sorry I can't be more helpful. :?
EdwinK
Post by EdwinK » Monday 05 June 2017 18:56
I'm waiting for a new antenna for the RFX reciever. So, hope that will change things.
Eddiever
Domoticz version: V4.9700
Post by Eddiever » Monday 19 June 2017 20:26
Looks nice for a fine price. Is it the outside sensor which is connecting to Domoticz? If so, why is shown in Domoticz as a Temp/Hum device? The ad from Lidl claims it is only for temperature.
And can you only use the sensor or is the base unit also needed?
RPi 2B with Domoticz and cam module RPi 3 with cam module
1 rftxtrx433E module 1 solar-edge SE-3500
1 Sonoff Touch 3 Sonoff wifi swithes 6 kaku modules
EdwinK
Post by EdwinK » Monday 19 June 2017 20:44
It is only for temperature. Why it shows as temp/hum. I guess no one knows. Base units are not needed. I'm going to put mine in a garage sale some day.
Eddiever
Post by Eddiever » Tuesday 27 June 2017 20:07
Got two of them today by mail. With version 1019 they were not detected. Upgraded to 1020 and there they are! Somebody want to buy a weatherstation for indoor use only ?
EdwinK
Post by EdwinK » Tuesday 27 June 2017 20:23
Eddiever wrote:Got two of them today by mail. With version 1019 they were not detected. Upgraded to 1020 and there they are! Somebody want to buy a weatherstation for indoor use only ?
Sorry, got 3 of them my self. Indoor only :)
Boredcat
Domoticz version: 3.9639
Post by Boredcat » Friday 14 July 2017 11:44
At this moment there are also available in the store for E8,99 (white and black). Saves you shipping costs.
Just bought 3 and exchanged 1 for not working (was only seen once by domoticz).
RFXCom(E) - Yeelight Lights - KaKu / Alexa HA Bridge
Windows 2012 / Windows 2012R2 / Xpenology/ Pi 3 / Milight / Home build ESP8266 / Sonoff
