Lidl NL: Weather station with outside sensor
Spotted a nice hardware deal? Share here!
rtna
Target OS: Raspberry Pi
Post by rtna » Monday 16 January 2017 21:31
https://www.lidl-shop.nl/AURIOL-Weerstation/p100210996
€8,99
Tested with RFXCOM / Domoticz. Works like a charm.
maluko
Re: Lidl NL: Weather station with outside sensor
Post by maluko » Monday 16 January 2017 21:45
what rfxcom you have? rfxtrx433 or E?
rtna
Post by rtna » Monday 16 January 2017 21:55
E
maluko
Post by maluko » Monday 16 January 2017 23:41
i assume that willnot work on rfxtrx433, can anybody confirm? what protocol detect?
desertdog
Post by desertdog » Monday 16 January 2017 23:45
a short description how to add this device to the Domoticz would be nice indeed
bbqkees
Domoticz version: 3.8x
Post by bbqkees » Tuesday 17 January 2017 14:58
The 'E' extension was mostly for support of the Somfy RTS controller.
I am pretty confident the outside temp sensor of this Lidl weather station can be seen bij the 'older' RFXCOM.
The inside temperature can of course not be viewed as this sensor will be in the weather station itself and therefore it does not output the data va RF.
So this deal buys you a cheap outside temperature/humidity sensor.
Intel NUC-> Philips Hue, Aeon Zwave stick V2, Qubino, Fibaro, Everspring, Philio, RFXCom, X10, Harmony Hub, Xiaomi Flora + Gateway, BS440. And P1 / Resol VBus / Nefit EMS bus / DHT21 / DS18B20 / Sonoff / I2C display, all via Arduino/ESP8266.
maluko
Post by maluko » Tuesday 17 January 2017 23:46
i refer this beacause i have this sensor and old rfxcom and cant add him.
rtna
Post by rtna » Wednesday 18 January 2017 13:49
Rubicson/IW008T/TX95
bbqkees
Post by bbqkees » Wednesday 18 January 2017 17:51
maluko wrote:i refer this beacause i have this sensor and old rfxcom and cant add him.
Could be you need to change the firmware or enable the protocol.
SteGe
Post by SteGe » Thursday 19 January 2017 9:53
Does it also shows the humidity or only temperature?
sent by tapatalk
Raspberry pi 3b
RFXtrx433E
Sompfy sunscreen
Cresta weatherstation
4 elro power switches
Doorbell/chime
Letterbox "reader"
Eneco Toon (also for reading smartmeter by P1)
MySensors (Humidity, Temperature, Lux)
desertdog
Post by desertdog » Thursday 19 January 2017 14:08
With the RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (Version: Ext2/1009) the outside sensor is recognised after a couple of minutes in the devices as Rubicson/IW008T/TX95.
The Rubicson protocol has to be on in the hardware -> RFXCOM - RFXtrx433 Modes
desertdog
Post by desertdog » Friday 20 January 2017 13:29
This device is filling up my log with lots of connections. Is there a way to bring them down to say. every five minutes?
2017-01-20 12:22:50.821 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:23:21.821 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:23:52.821 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:24:23.821 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:24:54.820 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:25:25.821 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:25:56.820 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:26:27.820 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:26:58.753 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
2017-01-20 12:27:29.820 (Transceiver RFX) Temp + Humidity (Sensor Balkon)
SteGe
Post by SteGe » Saturday 21 January 2017 10:54
I don't know how you can manage it, but I see you get temp + humidity. Is the humidity visible in domoticz graphs?
sent by tapatalk
Raspberry pi 3b
RFXtrx433E
Sompfy sunscreen
Doorbell/chime
Letterbox "reader"
desertdog
Post by desertdog » Saturday 21 January 2017 10:57
No the Humidity is always 0%
SteGe
Post by SteGe » Saturday 21 January 2017 12:33
Hmmm already thought so. I was looking at it at the local lidl shop but couldn't find anything about humidity on the box. Should be a very nice sensor for me if it had it.
Hope you get an answer soon about the interval of the sensor sending the readings.
sent by tapatalk
Raspberry pi 3b
RFXtrx433E
Sompfy sunscreen
Doorbell/chime
Letterbox "reader"
bravo
Post by bravo » Saturday 21 January 2017 21:23
I just received 2 of these but i cannot get them to show up in Domoticz.
Specs:
- RFXCOM E-version, Firmware EXT/1013
- protocols enabled: Byron/Rubicson/ARC/AC
What i tried:
- Only put batteries inside sensor
- Put batteries in both sensor and receiver
- Put sensor next to RFXCOM
- Changed firmware to EXT2 version 1013
- Clicked on "allow sensors to be added for 5 minutes"
Still i see nothing appearing in my devices/logs. This has been for a couple of hours now.
Any suggestions?
bravo
Post by bravo » Saturday 21 January 2017 21:45
Fixed by downgrading RFXCOM to 1009...
desertdog
Post by desertdog » Sunday 22 January 2017 17:29
Do you also have a lot of sensor updates? ABout every 30s?
I feel this might be flooding my system as other 433mhz switches are not working very well anymore.
Anyone notices this too?
bravo
Post by bravo » Sunday 22 January 2017 21:18
Yes every 30 seconds an update is received. I have 2 sensors, so i have them even more often, but still it's not flooding, or bursting. All my other devices are still working without any hassle.
desertdog
Post by desertdog » Sunday 22 January 2017 21:21
Thanks for the info. I don't know why devices suddenly arent working correctly anymore. So I decided to transfer the domoticz system from my synology to a raspberry pi and place the 433 antenne in a more central space. Hope that will work
