vThings - CO2 Monitor for Home Automation
Spotted a nice hardware deal? Share here!
vlast3k
Post by vlast3k » Thursday 03 March 2016 18:18
I would like to bring to your attention a CO2 Meter that i have been developing over the last year. Following my Kickstarter project
My initial goal was that it is cheap and simple to use. Eventually i got in contact with the guys from domoticaforum.eu - here is discussion about it
The guys over there asked me to create a version specially for Home Automation Systems, which has minimal display options, but has an accurate NDIR CO2 Sensor and allows configuring a custom HTTP Server or MQTT server for reporting. As well as configurable interval and minimum threshold of the value to trigger reporting.
The first batch is now out, few improvements have been done for the second revision and now I think i am ready to offer it to more interested people.
There are also options with OLED display and LED bar, and also a cheaper version with a less accurate (+/- 15 %) sensor. In all variants, the enclosure is 3D printed with White PLA @ 0.2mm layer height
You can have a look on the Web Shop i just setup : http://vair.anker-bg.com
The price for the device specially for HA is 60 eur. Shipping is flat @ 4eur per order
I can offer a 5% discount for forum users. If you are interested in this and would like to purchase, you can use VTHINGS_5 coupon code during checkout.
I can also add changes to the firmware based on your requirements (it is open sourced at github)
bwired
Target OS: Raspberry Pi
Re: vThings - CO2 Monitor for HA
Post by bwired » Monday 14 March 2016 18:55
I have them running on MQTT now, but a http post can the device also do
works great for me
Shaggie_NB
Post by Shaggie_NB » Monday 28 March 2016 19:50
Has anyone used this with domoticz?
Or has anyone another solution with z-wave or 433? (< 100 Euro).
vlast3k
Post by vlast3k » Tuesday 29 March 2016 6:03
Shaggie_NB wrote:Has anyone used this with domoticz?
The device integrates with Domoticz using a "Dummy" device, a "Virtual Sensor" and then configuring the Device to post to a Custom URL in the form:
http://server:port/json.htm?type=command&param=udevice&nvalue=0&idx=1&svalue=%s
server:port - your http or https port of Domnoticz. If you use user/pass they can be added as http://user:pass@server:port
IDX parameter - this is the IDX id of the device
%s - this is replaced with the actual CO2 PPM Value
In Domoticz you need to create a "Dummy" Device, and then add a "Virtual Sensor" to it of type "Air Quality"
Once the connection is setup, you can configure the Interval and PPM Threshold values on the CO2 monitor - how often to send the data.
(i just added this info also here)
nmaster
Domoticz version: 3.6304
Re: vThings - CO2 Monitor for Home Automation
Post by nmaster » Saturday 02 April 2016 12:47
Hi vlast3k,
I'm interested by this sensor for my house.
Your web site seems empty, so is the device is selling again ?
vlast3k
Post by vlast3k » Saturday 02 April 2016 13:20
yeah.. i am selling it, just that i deleted the site by mistake few days ago, and now i need to do it again :)
send me a PM what you have chosen
vlast3k
Post by vlast3k » Saturday 02 April 2016 21:55
nmaster wrote:I'm interested by this sensor for my house.
Aaahh am sorry, but apparently i am too fresh on the forum to be able to send private messages :) so i cannot answer you :) I did not knew about this feature
So anyway - some additional details until i bring up the site again (hopefully tonight)
1. Web Site: http://vair-monitor.com/ - just information on the different options
2. With Domoticz you currently need the Wifi option as the device uses serial communication only for configuration. Though if it is possible that Domoticz communicates over the serial port with devices by following some kind of protocol, i will be glad to add it. Just give me some example as i couldn't find such easily in the docs...
3. The battery option - it turned out that i cannot sent batteries via the standard post, so i am not offering it anymore. But the device consumes 70-100 mAh. So you can connect it to an usb power bank
4. The plain option is with Leds. And the price with Wifi and the NDIR sensor is 70 eur, with the less accurate sensor it is 55 eur. Shipping is 4 eur (to add an OLED display is +10 eur)
stuiow
Domoticz version: 3.6857
Post by stuiow » Sunday 03 April 2016 10:11
Is there plans to do a Carbon Monoxide version of the monitor?
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
vlast3k
Post by vlast3k » Sunday 03 April 2016 10:23
stuiow wrote:Is there plans to do a Carbon Monoxide version of the monitor?
In general i plan to create various kinds of sensors and CO is one of them.
But i was with the impression that CO monitoring is a commodity already and there are various sensors available?
(but we have central heating and no open fires so i havn't dig to deep in this topic to be honest)
Can you elaborate what is missing? Connectivity to a Domoticz etc.. or ?
vlast3k
Post by vlast3k » Monday 04 April 2016 17:31
Web shop is up again
http://shop.vair-monitor.com
nmaster
Post by nmaster » Tuesday 05 April 2016 15:52
On the web site for this model (plain with leds) the wifi option at 10€ brings the sensor at 80 euros, isn't it ?
vlast3k
Post by vlast3k » Tuesday 05 April 2016 16:09
Thanks for noting this, initially i planned to have fixed amount discounts, then i switched to percentage and the pricing is not yet too consistent on all places :)
But anyway, please use this coupon code
APRIL_VAIR
to get 10 eur discount from the vAir CO2 monitor in April, regardless of options chosen :)
pvm
Domoticz version: Stable
Post by pvm » Wednesday 06 April 2016 7:40
This code does not work :(
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
vlast3k
Post by vlast3k » Wednesday 06 April 2016 7:46
pvm wrote:This code does not work :(
Sorry... for some reason i forgot to activate it yesterday ...
now it works
(this time i tested :) i still havn't got used to running the web shop, sorry)
pvm
Post by pvm » Wednesday 06 April 2016 12:30
now it works
Hmmm.. I just retried, the site still complains when using this code...:
Error: Coupon is either invalid, expired or reached it's usage limit!
vlast3k
Post by vlast3k » Wednesday 06 April 2016 13:36
pvm wrote:Hmmm.. I just retried, the site still complains when using this code...:
Are you trying the vAir - CO2 Monitor - this one http://shop.vair-monitor.com/index.php? ... uct_id=123
and check if you are not adding some extra space before it
APRIL_VAIR
it should display a green panel:
Success: Your coupon discount has been applied!
pvm
Post by pvm » Wednesday 06 April 2016 14:37
Ah, i am ordering "vThings - CO2 Monitor (Wifi + NDIR) for Home Automation"
You state :
I did not see the difference between VThings and vAir...
So my mistake :oops:
vlast3k
Post by vlast3k » Wednesday 06 April 2016 15:09
pvm wrote:I did not see the difference between VThings and vAir...
Naming things is definitely not one of my strengths :) Sorry for the confusion caused
pvm
Post by pvm » Thursday 14 April 2016 17:05
Thnx, received the sensor couple of days ago, had to move the %s to nvalue instead of svalue:
http://192.168.1.3:8080/json.htm?type=command&param=udevice&nvalue=%s&idx=199&svalue=0
(this is according to the wiki )
Result:
First measurements
Thnx... next step is integration with my ventilation system (using the 'afzuigkap' (cooking fumes), CO2 level, geofence status, in and outside temperature)
edit:added wiki link
alexsh1
Domoticz version: v3.8975
Post by alexsh1 » Saturday 30 April 2016 2:05
I was not able to use the coupon today
