Domoticz version 4.9700 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
Toulon7559
Target OS: Raspberry Pi
Domoticz version: latest
Re: Domoticz version 4.9700 released (Stable)
Post by Toulon7559 » Saturday 29 September 2018 22:50
@waaren
Clearing of Browsercache was already tried in vain:
therefore my question.
Thanks for the hint to appcache, which was effective.
Back in business, :-( although with loss of data, because of an older database-file for restore .......
Set1 = RPI-B+RFXCom433+S0PCM+Linksprite-shield for BMP180/DS18B20/RS485+DDS238-1ZN
Set2 = RPI-3+RFLinkGTW+ESP8266s+PWS_WS7000
Common = 3*PVLogger+PWS_TFA_Nexus+KAKUs
=> Energy & Data Management based on Time and on PV&Consumption&Meteo
Thuis
Domoticz version: 2.9700
Post by Thuis » Thursday 04 October 2018 20:35
In Windows, huh Windows? :lol:
yes,in Windows, it says version 2.9700 instead of 4.9700 :o
p1 Smartmeter, CM15Pro, Lyric T6, Sonoff, Xiaomi Aqara, Intel Xeon.
Plantje
Post by Plantje » Thursday 04 October 2018 21:24
But on the website it says 4, right? Mine does. And it is also Windows
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Thursday 04 October 2018 22:51
waaren wrote:
Toulon7559 wrote:
Saturday 29 September 2018 22:24
Today on my Raspberry B+ with version V3.8153 'repair' of precipatation-info was not possible [= taking out 'strange' values by indicating through Shift+MouseLeft]
Also backup of database was refused.
Upgrade to latest Beta-release and restore of latest available database-file seemde OK, till I selected the subpage 'Weather'.
Is totally corrupt: all widgets on that page have same 'nonsens'-layout.
Somebody an idea how to restore to 'normal' layout?
A lot of the problems users experience after a domoticz update are gone when the browsercache and appcache are cleared. There are also quite a number of posts on this forum related to these kind of problems.
To summarize and sorted from little effort to a bit more effort take these steps and check after each step if it address the issues you encounter.
- clear browser cache and appcache
Chrome: chrome://appcache-internals/#
Firefox: https://support.mozilla.org/en-US/kb/storage
- in www/js look for domoticz.js.gz, if its there remove it, (KEEP domoticz.js !! )
- use incognito mode using
Chrome [control] [shift] n
Firefox: [control] [shift] p
- restart domoticz
- rename the location of the original installation and install the new version to an empty target directory. Next copy database and scripts from the old location and fire it up.
Hope this will also solve your problem.
Can this be pinned (if not already) if not already in the forum and Wiki? I did know the trick about Chrome but no idea abut the js.gz trick. Saw it by chance.
It would be good if it is so where easier to see for next time as I’m sure I’ll forget where I saw Wareen’s instructions :D
11101101 - www.machinon.com
RymeB
Post by RymeB » Friday 05 October 2018 14:08
Is there any ETA for the next stable release? I have three new Philips HUE lamps that I can't add to Domoticz > Devices. One of them is a multicolor bulb that I want to use for halloween in combination with a Z-wave PIR sensor. It would be nice to know if I would have to search for a work-around or if I should have a little bit more patience so I can use my Domoticz setup in time.
Thuis
Post by Thuis » Tuesday 09 October 2018 15:17
Yes it is 4 :-)
Solderbro
Domoticz version: 4.9980
Post by Solderbro » Thursday 18 October 2018 19:53
Question: Do this stable version share the same database version than 4.9980 beta?
So a downgrade would be possible?
Greetings
Solderbro
Synology DS218+ (8GB), Aeotec C5, Eurotronic Spirit, Fibaro FRGBW, Zipato PIR, Aeotec Multi 6, Everspring AN180
eSumo
Post by eSumo » Tuesday 23 October 2018 11:34
Hi. On the Wake-on-LAN hardware, I create a new node with a MAC address. Previously (before updating) a new light/switch was automatically created. Several of them I already an uses.
Now it is not possible. The node is created but the light/switch is not created. :(
Where can be a mistake? :?
Thanx...
Domoticz latest stable (v4.9700) on RPi 2 with MySensors GW (2.0.0), RFLink 433 R48 with NODO...
...and 42x 433MHz devices + 11x MySensors...
Test env.: latest Domoticz beta on Win10, home made RFLink 433 R48 with NRF for MySensors...
WildeFA
Domoticz version: v4.9700
Post by WildeFA » Tuesday 23 October 2018 19:26
I did a clean install of Stretch lite. Installed the latest version of Domoticz and restored a backup of the Domoticz database as described on page 1 of this post and it works perfect. No issues after two weeks.
Solderbro
Post by Solderbro » Thursday 25 October 2018 18:49
Checked out the database compatibility, short answer: NOPE
This stable does not eat the backup file from beta, nor does it accept a copy of the .db file. It results to a complete ignore, emptied devices at all and full amnesia.
Don't see the idea why a SQL database must be incompatible as feature :shock:
Solderbro
eSumo
Post by eSumo » Thursday 25 October 2018 19:03
Thanx...
[Resolved]
In settings must be allowed to add new devices!
Same is for Pinger.
It's good? :?
In the previous version I turned it off and Pinger and WOL added.
Plantje
Post by Plantje » Thursday 25 October 2018 22:09
Nice that you get back to this!
trantitell
Post by trantitell » Monday 05 November 2018 18:17
Version 4.9700 introduced support of new I2C pins expander. Outputs works fine,but how to use MCP23017 as inputs ?
During review of source code I noticed what inputs are not implemented - it is true or I'm just looking in a wrong place ?
tlkg
Post by tlkg » Tuesday 06 November 2018 21:34
(Sorry this should have been posted in the "Bugs and Problems. Please move if appropriate)
I am having a problem getting restores to work on my Raspberry Pi. Every time I try and do a restore (any of the db's in the backup folder) it either crashes or hangs Domoticz and when restarting Domoticz all I get is the message that nothing has been setup. Luckily I have one backup I saved via my windows browser, but it is about 2 weeks old, but seems to work fine.
My concern is, are the backups that are being saved on the Pi are getting corrupted somehow. I am running V4.9700 and have auto backups enabled. There are a lot of backup db's (they are all from v4.9700) in the backup folder on the Pi, but I can't get any of them to work on a restore (i.e. Hourly, Daily or Monthly.)
Domoticz is currently working fine for now, but I'm worried that if I do need a complete restore in the future, it won't work.
Thanks for any info.
brjhaverkamp
Post by brjhaverkamp » Wednesday 21 November 2018 14:27
Just out of curiousity. The original anouncement mentioned the plan to do monthly releases. I think that is a bit ambitious to jump into right away. But half-yearly or quarterly releases would be nice. Is there already a rampup to a new release?
Also, Is there a forum for the "hardcore" developers, where the current work is discussed? And where would-be contribors can read up on the thoughts and plans of the development team before jumping in?
Regards,
Bert
marcbakker97
Domoticz version: 3.8153
Post by marcbakker97 » Friday 14 December 2018 23:32
It is working fine whit all mij devices, z wave, kodi and thermostat. It is not working whit satel integra outputs, the text outputs, the lua scripts not working anymore
