Domoticz version 4.9700 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
greenwitch
Target OS: Raspberry Pi
Re: Domoticz version 4.9700 released (Stable)
Post by greenwitch » Monday 02 July 2018 21:53
In appversion.default following info are published
#define APPVERSION 5876
#define APPHASH "b97777b"
#define APPDATE 1478691222
strange and I can see that in all versions this file looks like this. Where I can find real version number?
Adam
Post by waaren » Monday 02 July 2018 22:06
I see the real version in appversion.h
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Kasvand
Post by Kasvand » Monday 02 July 2018 22:42
Well... This is quite a disaster...
I had perfect scripts controlling all the lights using motion sensors etc. But after the update all I get is disco! Lights are blinking all over the place. Lights also seem to turn on and off pretty random, and logging gives no single clue why. :(
No idea what's going on here..... It seems the system is completely messed up. Some groups aren't functioning at all (if I activate them just nothing happens). When I turn the lights off (using a dummy switch) most lights turn off but two of them start blinking and another random light turns on after some time and remains on. There does seem to be some pattern - but there's absolutely nothing in the scripts that can be causing this.... (nb. all Xiaomi lights and sensors...)
Going back to the old release. Don't even have an idea where to start solving this...
Forgot to do a back-up... :( (stupid!), but still have a quite recent one fortunately. Lost an hour of work max. Shame.
Well... we're back online. On the old release that is. Will have to give it another go when I have a few hours time to do debugging. Anyone know if things have changed in this release concerning controlling groups? Cause that's all I can think off that might be causing the strange behaviour of lights...
Bluelightcrew
Domoticz version: 3.6708
Post by Bluelightcrew » Monday 02 July 2018 22:47
SpawnMC wrote:
Friday 29 June 2018 23:07
Bluelightcrew wrote:
Monday 25 June 2018 21:00
I updated from a beta.After some minutes domoticz crashes.I tryed a complete new setup.After adding some devices domoticz crashes.
i have the same problem. after 15 min it crash.
i tried my old setup with jessie and domoticz new beta version
and i tried a new setup on a new sd card with stretch and domoticz stable 4.97
bevore i used domoticz with beta versions for 2 yeras without problems :-(
EDIT: Problem solved by disable all "MyDomoticz configs", the server builds a timeout and after 15 min domoticz crash
That's true! Looks like when mydomoticz is down, domoticz crashes! In the versions before, this didn't happen. Thanks for the info. I also disabled now all mydomoticz functions, because it's really often down.
greenwitch
Post by greenwitch » Monday 02 July 2018 23:00
If so it means that source code is from 5876 and not 9700 as in sourcecode downloaded frm git in appversion.h it is still 5876.
Adam
Post by waaren » Monday 02 July 2018 23:22
That is not what I see.
git clone https://github.com/domoticz/domoticz.git domoticz.dev
Cloning into 'domoticz.dev'...
remote: Counting objects: 56786, done.
remote: Compressing objects: 100% (90/90), done.
remote: Total 56786 (delta 54), reused 47 (delta 28), pack-reused 56668
Receiving objects: 100% (56786/56786), 203.28 MiB | 2.99 MiB/s, done.
Resolving deltas: 100% (40786/40786), done.
cd domoticz.dev
cat appversion.default
#define APPVERSION 9700
cmake -DCMAKE_BUILD_TYPE=Release CMakelists.txt             # first time ===>> stable
-- Compiling Revision #9700
cmake -DCMAKE_BUILD_TYPE=Release CMakelists.txt             # second time ===>> beta
-- Compiling Revision #9740
greenwitch
Post by greenwitch » Tuesday 03 July 2018 9:19
To delete
Hesmink
Post by Hesmink » Tuesday 03 July 2018 21:00
Hi All,
I seem to have a problem with my plugins and Hardware tab.
Symptoms:
- In the Hardware tab I don't see the 'Enabled' checkbox, so I cannot enable/disable Hardware
- I cannot delete the hardware for my Xiaomi Vacuum plugin and Broadlink Smart outlet plugin. If I try, Domoticz hangs.
(Changing the type to Dummy, delete, restart Domoticz works, the Hardware is gone).
- After reinstalling the plugins from source, if I add the plugin hardware, no devices appear.
I see no specific errors in the logging, except that it just doesn't work.
I'm using a RPI3. I recently upgraded by installing Strech-Lite, Domoticz and uploading the database backup.
jimbou
Post by jimbou » Wednesday 04 July 2018 11:17
Abu06 wrote:
Thursday 28 June 2018 9:02
After the installation of the new release, the selector switch was not displayed correctly on the dashboard. I even cannnot create a new dselector switch. It was impossible to edit a simple swith. The return message was "undefined".
After hours of trials, I solved the issue by clearing completely the cache of my chrome browser.
I displayed this parameters page in chrome
chrome://appcache-internals
and removed what was related to chrome. And miracles. It works perfectly now.
André
Thanks André, it worked for me too on my PC. I removed everything relating to Domoticz.
On my mobile, it was not so efficient, so I will use Firefox.
rsm1024
Post by rsm1024 » Wednesday 04 July 2018 12:37
Hi,everyone
I updated Domoticz to the latest release 4.9700, but my openawave driver still "OpenZWave USB
Version: 1.4-2888-g54682370-dirty" not updated to 1.5 ?
thank you
my config : rpi3 stretch, RaZberry v2 ZWAVE.ME.
(sorry for my English, I'm French)
jvandenbroek
Post by jvandenbroek » Wednesday 04 July 2018 16:12
Hi,everyone
thank you
It's compiled against the latest snapshot, which is far more recent than 1.5. Seems odd that on Github there is a 1.5 release from 2016, while on http://old.openzwave.com/downloads/ 1.4 is more recent (despite the even more confusing old.openzwave.com URL :lol:) Anyway, you're fine, it's the latest greatest ;)
Edit: Ah well the latest stable on openzwave.com is also an oldie it seems, just newer builds for different distro's. But then again, it's the latest snapshot, so up-to-date.
CSONNECK
Post by CSONNECK » Wednesday 04 July 2018 22:35
Hello
André
Merci André
gjaa
Domoticz version: Stable
Post by gjaa » Thursday 05 July 2018 13:37
I'v upgraded to the newest version from the latest beta, so far so good
Everything is up and running except the blockly scripts the Buienalarm-sensors and the "Slimme meter" doesn't no whats he doing today
I ugrade to the latest beta but that was not the solution
I'm running on the lastest "Jessie" is that perhaps the problem???
Gerard
DosN
Post by DosN » Thursday 05 July 2018 23:52
After an update to 4.97 the Hue was not working correctly. but finnaly at the beta version there is a patch.
now i see the status of the light are updated again at the dasboard
but strangly it is not fixed completely
at my lua code i check status of some lights
If otherdevices['Woonkamer lampen TV'] == 'On' then
but even if this light is on also at dashboard , i cannnot read it status in lua ??????????????????????????/
it was working in teh previous stable version
are more people hef this problem
Docdigit
Domoticz version: 3.8153
Post by Docdigit » Friday 06 July 2018 9:03
Thanks for this update - works like a charm.
If you need additional Dutch translators for this new version, just let me know.
With both feet on the ground to can't make any step forward...
moi427
Domoticz version: 3.8975
Post by moi427 » Friday 06 July 2018 11:17
Same here, updating and no more working Domoticz: an entirely empty dashboard etc., nothing of my installed and working (before) hardware is there anymore. Stopped and started, trebooted many times. After reading all comments (quite a lot of problems, that's a pitty) I can't find what's wrong. Can't find any solution that worked here, so I'll probably have to try and go back to a backup version.
Trying ./updaterelease stops with next message
Cannot write to ‘domoticz_release.tgz’ (No space left on device).
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Restarting Domoticz... (please standby...)
I'm using an RPi2B with a 8Gb SD card which seems to be filled up apparently. Will try to find where all space went, try to clear something and then retry the ./updaterelease command again.
It's a really pitty, since everything worked fine nowe since I guess good half a year or so. I'm not a Linux programmer so I have to do with regular commands. And then it's a problem when the regular upgrade doesn't work... :cry:
Nibe F1255-6 PC heatpump, SolarEdge SE7K inverter + 16 x Solarwatt panels (in-roof 275Wp) + optimizers, EtaSunPro vacuum collector (40 tubes)
CSONNECK
Post by CSONNECK » Friday 06 July 2018 12:05
Hi moi427
Did you use file expand on your RPi ?
raspi-config --expand-rootfs
Have a nice day
Christophe from France
moi427
Post by moi427 » Friday 06 July 2018 12:52
Hi Christophe,
As far as I remember I've done that when I installed everything. It now anyway doesn't work because it gives an error in raspi-config, but that's probably because the lack of space. Can't find yet where the space is gone (I'm not a Linux programmer :oops: ), so what I can delete to get more space. Probably the restore is my only option left.
jvdz
Post by jvdz » Friday 06 July 2018 12:55
Start looking in /var/log for big logfiles:
ls -l /var/log/*
Jos
moi427
Post by moi427 » Friday 06 July 2018 13:09
Thx Jos!. That shows 685MiB for /var/log/daemon.log plus the same size for /var/log/syslog and that's quite a substantial amount of data I'll delete.
