Domoticz version 4.9700 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
gizmocuz
Target OS: Raspberry Pi
Post by gizmocuz » Sunday 24 June 2018 8:21
Hi Everyone !
After a year of hard work and almost 2000 commits, we are proud to release another stable version of Domoticz !!
Thanks to all developers users and contributors who helped us build and test the beta versions !
Without your support this would not have been possible!
As always, and specially for users using a previous stable version on a raspberry pi that has not recently been updated to 'stretch',
it is a good idea to make a FULL backup of your Domoticz folder (or SD card!)
Then make sure you are on the latest operating system version, for raspbian this is 'Stretch', more on this after the change list below!
If you are using the binary installer of Domoticz, you should be able to upgrade via the menu, or issuing ./updaterelease in the installation folder.
We will try to release new stables on a monthly basis from now on, but please keep testing the beta versions also to help development!
There are to many changes to be listed, but a short list can be found below.
With kind regards,
Rob
Version 4.9700 (June 23th 2018)
- Implemented: Blockly, now possible to directly add/update Text devices
- Implemented: Blockly: now possible to use expressions in debug messages like "My temperature is {{temperaturedevice[1234]}} degrees" (see http://www.domoticz.com/wiki/Events)
- Implemented: Camera: support for HTTPS url's
- Implemented: Comm5 SM-xxxx sensors support
- Implemented: Command line option '-noupdates' to stop using the internal update functionality Corrected 'Proxy' settings in the settings page (missing element closing tag)
- Implemented: Denkovi Smartden IP In (32) with LAN Interface
- Implemented: Disabling the option to downgrade Domoticz and use a newer database (because of database migrations)
- Implemented: Door Lock Inverted
- Implemented: EcoCompteur device
- Implemented: eHouse BMS / Home Automation System Integration
- Implemented: Forcing appcache to be refreshed on every new build
- Implemented: Functionality to allow Python Plugins to integrate with the Domoticz Security Panel
- Implemented: HardwareMonitor monitor own process memory usage
- Implemented: Honeywell Lyric thermostat
- Implemented: I2C: support for MCP23017 (16bit I2C GPIO expander)
- Implemented: Initial support for FS20
- Implemented: KMTronic TCP Temperature hardware
- Implemented: Langiage "Persian" (Big tankgs to "foademadi", "maziar.hafezi" and "reza.hadipour2002")
- Implemented: Language "Albanian" (Big thanks to "arbenik")
- Implemented: Language "Bosnian" (Big thanks to "Vedran")
- Implemented: Language "Catalan" (Big thanks to "delfisastre")
- Implemented: Logitech Media Server: Added option to remove unused nodes
- Implemented: RFXtrx Lucci Fan DC implemented
- Implemented: MQTT Push message on scene/group switch event
- Implemented: MySensors: handling of I_INCLUSION_MODE message.
- Implemented: MySensors: support for SmartSleep option (gateway 2.x)
- Implemented: Netatmo: rssi support
- Implemented: New Managed meter type
- Implemented: OnkyoAVTCP: Add source selection, detection via NRIQSTN
- Implemented: OpenWeatherMap: cloud sensor
- Implemented: RFXCom: support for WIND7, RAIN7/RAIN8/RAIN9
- Implemented: Rtl_433: support for wind sensors, HH and LL humidity values
- Implemented: Selector Switch: correcting display for all UTF8 characters now
- Implemented: Styles folder can have its own images folder to overwrite stock images
- Implemented: Telegram notifications
- Implemented: Voltage/Current for Armbian Kernal 4.14+
- Implemented: Webserver: automatically reload SSL certificates and DH params3
- Implemented: Xiaomi Aqara Cube
- Implemented: ZWave node ID to log
- Removed: NMA Notification system (the service has stopped)
- Updated: Dzvents (version 2.4.6, See dzVents/documentation/history.md)
- Updated: OenZWave driver and configuration files
- Updated: Translation files
- Updated: Various internal libraries (C++/WWW)
- Changed: Floorplans now stored in database
- Changed: Improved color dimmer support
- Changed: Internal HUE/RGB/W/WW handling
- Changed: Philips Hue: internal code
- Fixed: Various, see github
NOTE FOR OLD RASPBIAN USERS (<STRETCH)
It might be best to reinstall your system with stretch-lite:
https://www.raspberrypi.org/downloads/raspbian/
Some notes about the backup:
- backup the database, this can be done on a running system via the 'Settings' option (backup/restore)
- if you use ZWave, backup the zwave configuration file (Config/zwcfg_xxxxx.xml)
- if you are using floorplans, backup images/floorplans, do not that once you start the new stable, the floowplan images are now moved into the database, for feature backups it is not needed to backup this folder any longer!
- if you are using custom/external scripts, also make a backup of them
Once you have setup a new system, install domoticz via the sudo command:
sudo curl -L install.domoticz.com | bash
(This only work on debian/armbian/ubuntu systems)
make sure Domoticz is running
next stop domoticz with:
sudo service domoticz stop
Now you can restore your backup database/files
next launch domoticz with:
sudo service domoticz start
You should now have a running system again!.
Also note, there have been some changes in the command line parameters related to logging/debugging
We hope the transition will be as smooth as possible!
jeanclic
Re: Domoticz version 4.9700 released (Stable)
Post by jeanclic » Sunday 24 June 2018 13:04
Hello !
nice to have a new stable ! I was using a beta since a while, but I now am back on stable channel !
All seems to work perfectly for me, even better than before (faster ?), except for 1 thing : upload of custom icons... nothing happens when I click on "Upload"...
I my browser debug console, I can see that the answer is
"error" : "Invalid",
"status" : "OK",
"title" : "UploadCustomIcon"
but it seems odd to me as I am trying to upload a zip which was perfectly taken into account in previous versions... something I missed ?
Thanks.
[EDIT] : Seems like it works but I need to manually refresh the page to have the new icon displayed. The error in the console seems not right though...
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
jbr79
Post by jbr79 » Sunday 24 June 2018 14:22
Running RBpi3 with Raspbian Stretch Lite.
Got a message from the UI that an update was available and proceeded from there to upgrade.
Most of the process seems to have successfully completed, but afterwards my entire "switches' page is empty, and so is the dashboard, apart from a RFX433-based Luminescence sensor I also had in there before the update.
Both pages load with an error in the console:
Switches: Uncaught ReferenceError: isLED is not defined
Dashboard: DashboardController.js:67 Uncaught ReferenceError: b64DecodeUnicode is not defined
After some time (and a few reboots) everything seems to be OK... must have been a caching issue? :?
ivarka
Post by ivarka » Sunday 24 June 2018 15:48
Also got no switches and the isLed-error in console. Upgraded from last stable.
Ivar
gordonb3
Domoticz version: Custom
Post by gordonb3 » Sunday 24 June 2018 16:18
If you're not using a package manager to install Domoticz you should clean your Domoticz directory and keep nothing but domoticz.db and the scripts directory before installing the new stable. This is in fact good practice for every update you want to install as it prevents orphaned files to remain and possibly (as it does here) cause conflicts.
Dahl1632
Target OS: OS X
Post by Dahl1632 » Sunday 24 June 2018 16:28
After upgrade my system dosnt work anymore.
I was running the stable version on my Rpi2 Wheezy.
Now i get:
domoticz: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
f14driver
Post by f14driver » Sunday 24 June 2018 16:36
After upgrading to V 4.9700 I have something that seems odd.
Measurements from 2 different slave servers are not registerred correctly on the master server.
In my case I read 4 parameters from my UPS'es to their respective slave and the salve forward the readings to my master domoticz server.
They display correctly on the slave itself.
The sensors are defined as custom sensors that are polled every minute through a bash script.
After disconnecting and reconnecting the user which the master server is using tot connect to the slave server the problem persists.
The internal Pi measurements ( useage, memory, disk etc.) get updated normally as before the update.
So basically 50% of the sensor are passed on from the slave to the master server ( the Internal Pi motherboard readings) and on the slave itself the bash script works normally for the UPS measurements.
The UPS measurements are not passed over to the master domoticz server. All servers communicate over the remote shared port 6144.
Does anybody have an idea how to fix the measurements of the UPS not being passed to the master server ?
Calzor Suzay
Domoticz version: 3.9629
Post by Calzor Suzay » Sunday 24 June 2018 16:44
Is this actually 4.9700 as it creates some confusion over the beta being a lower revision in my case 3.9629.
I suspect it's 3.9700 in which it's an upgrade for me and includes all the current Beta goodness.
Dahl1632
Target OS: OS X
Post by Dahl1632 » Sunday 24 June 2018 16:50
I found a workaround for my udev problem. Created a symlink from libudev.so to libudev.so.1 in /usr/lib.
ivarka
Post by ivarka » Sunday 24 June 2018 19:55
Ok, deleted domoticz.js and domoticz.js.gz and updated again (using sudo ./updaterelease). Works now :)
HansieNL
Domoticz version: Stable
Post by HansieNL » Sunday 24 June 2018 20:28
After new Stretch installation and upgrade I gave command "sudo curl -L install.domoticz.com | bash". I did see in terminal:
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git...pi@domoticz:~ $"
Looks like installation stopped before installation completed.
Someone has same problem and possible sollution?
FIXED. Installation went as it should.
Blah blah blah
frenchyyii
Post by frenchyyii » Sunday 24 June 2018 22:02
Hi, please do not pay attention to my english writing as I'm french.
I have also a problem with my database since the update. Domotics starts then shut down, no problem with a blank database wether on stable or beta.
Here is the log:
pi@raspberrypi:~/domoticz $ sudo ./domoticz
2018-06-24 21:54:56.783  Status: Domoticz V4.9711 (c)2012-2018 GizMoCuz
2018-06-24 21:54:56.783  Status: Build Hash: 1f462049, Date: 2018-06-24 14:52:26
2018-06-24 21:54:56.784  Status: Startup Path: /home/pi/domoticz/
2018-06-24 21:54:56.834  Sunrise: 06:13:00 SunSet: 21:55:00
2018-06-24 21:54:56.835  Day length: 15:42:00 Sun at south: 14:05:00
2018-06-24 21:54:56.835  Civil twilight start: 05:34:00 Civil twilight end: 22:33:00
2018-06-24 21:54:56.835  Nautical twilight start: 04:43:00 Nautical twilight end: 23:24:00
2018-06-24 21:54:56.835  Astronomical twilight start: 03:33:00 Astronomical twilight end: 00:35:00
2018-06-24 21:54:56.835  Status: EventSystem: reset all events...
2018-06-24 21:54:56.977  Status: PluginSystem: Started, Python version '3.5.3'.
2018-06-24 21:54:56.979  Status: Philips Hue: Using default poll interval of 10 secs.
2018-06-24 21:54:56.988  Active notification Subsystems: email, http, kodi (3/13)
2018-06-24 21:54:56.990  Status: WebServer(HTTP) started on address: :: with port 8080
2018-06-24 21:54:57.002  Status: WebServer(SSL) started on address: :: with port 443
2018-06-24 21:54:57.005  Status: Proxymanager started.
2018-06-24 21:54:57.006  Status: Camera: settings (re)loaded
2018-06-24 21:54:57.008  Starting shared server on: :::6144
2018-06-24 21:54:57.008  Status: TCPServer: shared server started...
2018-06-24 21:54:57.009  Status: RxQueue: queue worker started...
2018-06-24 21:54:57.279  Status: Incoming connection from: 192.168.2.80
2018-06-24 21:54:57.704  Status: Incoming connection from: 192.168.2.85
2018-06-24 21:54:59.010  Status: Hardware Monitor: Started
2018-06-24 21:54:59.026  Status: Wunderground: Worker started...
2018-06-24 21:54:59.027  Status: GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2018-06-24 21:54:59.027  Status: Wunderground: Worker started...
2018-06-24 21:54:59.028  GPIO: No exported pins found, aborting...
2018-06-24 21:54:59.029  Status: WOL: Started
2018-06-24 21:54:59.029  Status: Netatmo: Worker started...
2018-06-24 21:54:59.030  Status: XiaomiGateway: will listen on 9898 for hardware id 49
2018-06-24 21:54:59.031  Status: XiaomiGateway: Delaying worker startup...
2018-06-24 21:54:59.031  Status: Philips Hue: Worker started...
2018-06-24 21:54:59.032  Status: YeeLight Worker started...
2018-06-24 21:55:00.033  Status: RFXCOM: Using serial port: /dev/ttyUSB0
2018-06-24 21:55:00.035  Status: Domoticz: TCP connected to: 192.168.2.77:6144
2018-06-24 21:55:00.609
2018-06-24 21:55:00.685  subtype           = Interface Response
Sequence nbr      = 2
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1017
Firmware type     = Type2
Hardware version  = 1.3
Undec             off
X10               enabled
ARC               enabled
AC                enabled
HomeEasy EU       disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic           disabled
Mertik            disabled
AD                disabled
Hideki            disabled
La Crosse         disabled
Legrand           disabled
MSG4Reserved5     disabled
BlindsT0          disabled
BlindsT1          enabled
AE                disabled
RUBiCSON          disabled
FineOffset        disabled
Lighting4         enabled
Conrad RSL        disabled
ByronSX           disabled
IMAGINTRONIX      disabled
KEELOQ            disabled
Home Confort      disabled
2018-06-24 21:55:04.032  Status: WOL: Started
2018-06-24 21:55:04.032  Status: (Orchydée) Started.
2018-06-24 21:55:04.032  Status: (Caoutchouc) Started.
2018-06-24 21:55:04.033  Status: (Xiaomi plante bas) Started.
2018-06-24 21:55:04.033  Status: (Roborock) Started.
2018-06-24 21:55:04.033  Status: XiaomiGateway: Worker started...
2018-06-24 21:55:04.044  Status: EventSystem: reset all events...
2018-06-24 21:55:04.047  Status: XiaomiGateway: Using 192.168.2.78 for local IP address.
2018-06-24 21:55:04.054  Status: EventSystem: reset all device statuses...
2018-06-24 21:55:04.088  Status: XiaomiGateway: RGB Gateway Detected
2018-06-24 21:55:04.362  Status: PluginSystem: Entering work loop.
2018-06-24 21:55:05.062  Status: Domoticz: TCP connected to: 192.168.2.140:6144
terminate called after throwing an instance of 'std::invalid_argument'
  what():  stoull
Abandon
If someone can help...
sander
Domoticz version: latest..
Post by sander » Sunday 24 June 2018 23:37
Update!
Found it!
TO ALL, if you experience your install, update, whatever getting stuck and you have no clue why, check your internet provider.
Last night after trying installing and updating stretch and Domoticz I had this brainwave, I have to say I came across a thread where someone experienced something similar...
I do have a filtered internet connection, and turns out they filter also a lot of websites which in this case a fine, to use, but it blocked all my Github downloads and Raspbian.org etc.
After I had turned off the filter all went smooth and in one go!
I think it would be very worthy to a lot of people to put a small make aware note with the installs about this.
Apparently, my ISP has improved the filter over time as I did not have this issue last year I believe.
RIght now I am back to full working order with Domoticz.
I don't really experience much improvement, but I think under the hood many things will be up to date again and prepared for much more to come.
Regards Sander
I am stuck and very sad at the moment, I read yesterday "you can update as normal" klicked the update button and then big trouble.
Meanwhile I have formated and burnt my Pi towards the advised, my Pi 2B+ is now on stretch lite, but when I try to perform the command: sudo curl -L install.domoticz.com | bash I only get to this point:
pi@Domoticz:~ $ sudo curl -L install.domoticz.com | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 194 100 194 0 0 1489 0 --:--:-- --:--:-- --:--:-- 1503
100 16257 100 16257 0 0 49923 0 --:--:-- --:--:-- --:--:-- 288k
::: Script called with non-root privileges. The Domoticz installs server packages and configures
::: system networking, it requires elevated rights. Please check the contents of the script for
::: any concerns with this requirement. Please be sure to download this script from a trusted source.
::: Detecting the presence of the sudo utility for continuation of this install...
::: Utility sudo located.
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: There are 16 updates available for your system!
::: We recommend you run 'apt-get upgrade' after installing Domoticz!
::: Checking for git...pi@Domoticz:~ $ ^C
Well, that looks like I am stuck on the install of Domoticz. I am no programmer, just a handy copy-paste man with some understanding of how things work.
I am very disappointed as I had my system running perfectly since 2015... with updates. I understand this was a biggie, but the WAF factor is no gone, half my house is literally out of control.
I would be very happy for some directions, to get this solved.
Yes I have a DB backup from before things gone mad, but I currently have not the correct files to revert back to the old situation, or the knowledge how to do so.
Thanks Sander
Raspberry Pi 2B+
connected: klik aan klik uit switches, dimmers, weather station, water meter (pulse)
Automation use: Blocky
jeroenb42
Post by jeroenb42 » Monday 25 June 2018 8:13
Got a message in my browser about a new update, clicked on it and got the new version 4.97 on my Pi3.
What I no longer have are any switches.....
Tried to remove domoticz.js and did sudo ./updaterelease, clear browser cache and app cache, still no switches
Of course did not create a backup because hey, I got a link to click on...
For some reason, the dashboard does contain switches, also for my roomplans
I also have the iOS app and it still does have the switches.
I tried anyother browser (use Chrome for Domoticz), Firefox, and still no switches
Any help would be appreciated.
ivarka
Post by ivarka » Monday 25 June 2018 8:32
Did you also delete domoticz.js.gz before running ./updaterelease again?
Koensk
Post by Koensk » Monday 25 June 2018 9:12
Ok I'm having the same problem. Can you tell me how to do this?
Thx
hoeby
Post by hoeby » Monday 25 June 2018 9:52
I only read problems in this thread.
5 months ago i started whit domticz on a stable version. A month ago i went for a beta version because i wanted to use zigate. Only did one beta install, not every update that pop-up in the browser.
2 days ago i went for the stable version 4.9700. Everything went fine, no problems discovered.
Thanks for in the effort all of you are putting in
Koensk
Post by Koensk » Monday 25 June 2018 9:57
sorry I think I found it:
sudo ln -s libudev.so libudev.so.1
Herman-H
Post by Herman-H » Monday 25 June 2018 10:21
I have no skills with Linux, but what i have done is upgraded Wheezy to Jessie and then to Stretch.
wget http://ftp.nl.debian.org/debian/pool/ma ... _armhf.deb
Start the installation: sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
After that: sudo service domoticz.sh start
And then all works as usual. Thanks for Gizmocus and his team for this update.
Calzor Suzay
Post by Calzor Suzay » Monday 25 June 2018 14:07
I see you renamed it all 4.9700+ now :)
