New (beta) version library requirement (Arm/Debian)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
Jan Jansen
Target OS: Raspberry Pi
Re: New (beta) version library requirement (Arm/Debian)
Post by Jan Jansen » Monday 16 October 2017 15:45
@pvangorp
After following your step by step instruction everything seemed OK. But after "cd domoticz" and "./updatebeta" it was impossible to connect again via the web interface. I went back to Strectch in combination with the latest stable.
pvangorp
Domoticz version: Latest B
Post by pvangorp » Monday 16 October 2017 15:53
You can’t update like that. You’ll go back to stock Domoticz. You need to update like this:
# git pull
# make -j 4
vmb
Post by vmb » Monday 16 October 2017 15:55
@pvangorp Also updating by webinterface aint possible?
pvangorp
Post by pvangorp » Monday 16 October 2017 15:57
Correct, you’ll go back to stock. It doesn’t take as long as the initial build, but longer than the integrated update.
Jan Jansen
Post by Jan Jansen » Monday 16 October 2017 20:51
Your step by step instruction is clear about updating, so is the wiki. Unfortunately, I got stuck again.
After:
cd domoticz
git pull
make -j 4
>>putty shows the next last line
[ 21%] Linking CXX executable domoticz
The next 3 hours nothing happened. It looks like the issue described in my mail of October 12th.
My production machine runs the latest stable version of domoticz on stretch. At the moment there is no need for the beta version. But I wanted to try to install it from the source, unfortunately, without success.
Thanks so far
anconakip
Domoticz version: 7722
Post by anconakip » Tuesday 17 October 2017 7:10
here also problems. When is update my libssl de pi say it is already the newest. Help!!
Patrickwit
Post by Patrickwit » Sunday 22 October 2017 13:42
something goes wrong with getting the beta version I think?
nog I have the stable version. 3.8153 and I tought maybe the beta version is better.
but when I doe de command
./updatebeta
the raspberry says:
Updating to latest beta version...
Please Standby...
--2017-10-21 07:03:52--  http://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... failed: Name or service not known.
wget: unable to resolve host address ‘www.domoticz.com’
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Restarting Domoticz... (please standby...)
mosjonathan
Post by mosjonathan » Sunday 22 October 2017 13:46
looks like a dns problem the script cannot resolve www.domoticz.com
Patrickwit
Post by Patrickwit » Monday 23 October 2017 8:22
what can be the solution?
Patrickwit
. something went wrong with this post.
Last edited by Patrickwit on Monday 23 October 2017 14:28, edited 2 times in total.
mosjonathan
Post by mosjonathan » Tuesday 24 October 2017 15:46
does your raspberry have a static address or do you use dhcp?
if you use static than probably your dns servers are not properly configured.
DannyElfman
Domoticz version: 3.8136
Post by DannyElfman » Saturday 04 November 2017 18:53
Does anyone have installed the latest stable or beta on a Debian 9 ?
I am running a Debian 9.2.1 64bits on a Xeon server and I get the same error :
domoticz.sh[1397]: /home/root/domoticz/domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
Domoticz is looking for libssl 1.0.0 when I have 1.0.2l-2+deb9u1
 ldd domoticz
        libssl.so.1.0.0 => not found
        libcrypto.so.1.0.0 => not found
Any idea ?
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
DannyElfman
Post by DannyElfman » Saturday 04 November 2017 22:04
FYI, the fix has been explained in some other posts bt just in case :
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1%2Bdeb8u6_amd64.deb
dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_amd64.deb
systemctl restart domoticz
Et voilà !
roblom
Post by roblom » Sunday 05 November 2017 22:06
gizmocuz wrote:
Saturday 09 September 2017 12:28
For new (beta) versions it is required that libssl 1.0.0 is installed.
This might not be at your current system (for example a raspberry running rasbian jessy or older)
To install this, issue:
sudo apt-get install libssl1.0.0
After this you should be able to upgrade to the new beta via the web interface, or via the command line
cd domoticz
./updatebeta
for people running an armv6 system (raspberry pi 2 or below) you might need to issue
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
If i'm right the libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb isn't there anymore. Can i just use the libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb then?
DannyElfman
Post by DannyElfman » Monday 06 November 2017 18:48
roblom
Post by roblom » Monday 06 November 2017 19:34
Ignore my stupidity but is the file from the debian source the same as the one from the raspbian source?
I recently screwed up my system again by another attempt to fixed the "illegal instruction" and our the missing lines errors. It's probably my fault but at the moment I fix one problem and get 2 other problems back. And the more I fix the more unstable Domoticz gets.
DannyElfman
Post by DannyElfman » Wednesday 08 November 2017 16:30
One piece of advice : Make a clone of you sdcard using clonezilla for instance (or dd command but that might sound a bit complicated) or any other software, anytime you are touching the system (installing libraries and so).
This link is a reliable one as it is one of the official Debian repository and the version is the ARM one for any PI device :
The official official info is here but it is mentionning the lateste version, u7 :
https://packages.debian.org/jessie/armh ... 0/download
DannyElfman
Post by DannyElfman » Wednesday 08 November 2017 17:19
Note that I understand your are reluctant to use another source, that is completely understandable.
I guess, apart from the version number, you have the checksum on both side to make sure this is the one ;)
BullHead
Domoticz version: V3.8771
Post by BullHead » Monday 04 December 2017 17:33
Is the latest beta still not working with Pi 1(BCM2835)?
Best regards
Jonas
jvdz
Domoticz version: Stable
Post by jvdz » Monday 04 December 2017 19:35
I have it running fine after doing the earlier indicated install of the lib ssl.
This version just has a memory leak that causes the crash which causes monit to restart domoticz.
Jos
Users browsing this forum: No registered users and 4 guests
