Domoticz version 3.8153 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
marton
Target OS: Raspberry Pi
Domoticz version: v3.8235
Re: Domoticz version 3.8153 released (Stable)
Post by marton » Sunday 06 August 2017 17:06
brommetje wrote:After some problems runs for 2 days and now same problem as marton
2017-08-06 15:33:02.538  Error: Domoticz received fatal signal 11 !...
2017-08-06 15:33:02.541  Error:   /home/pi/domoticz/domoticz() [0x1cdc48]
2017-08-06 15:33:02.541  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-08-06 15:33:02.541  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a7f180]
2017-08-06 16:45:32.495  RxQueue: queue worker started...
After restart it works again any ideas?
There is a python file named /home/pi/domoticz/scripts/python/script_device_PIRsmarter.py. After deleting it, I managed to start domoticz.
felix63
Domoticz version: 3.8275
Post by felix63 » Monday 07 August 2017 11:53
Same problem as Brommetje and Marton. Seems to be - for me - related to the use of two python plugins.
Activating Buienradar gives fatal error 6.
2017-08-07 11:50:52.438  (Buienradar) Retrieve weather data from http://xml.buienradar.nl/
2017-08-07 11:50:52.449  Error: Domoticz received fatal signal 6 !...
2017-08-07 11:50:52.451  Error:   /home/pi/domoticz/domoticz() [0x1ce8ec]
2017-08-07 11:50:52.451  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1ce9a4]
2017-08-07 11:50:52.451  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ae0180]
2017-08-07 11:50:52.451  Error:   /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x38) [0x76adef70]
Activating Homewizard gives fatal error 11.
Trigun
Domoticz version: 3.5877
Post by Trigun » Wednesday 09 August 2017 11:50
Trigun wrote:Hi Gizmocus,
first of all I would like to thank you for all the effort you (and a lot of others) punt in the new version of domoticz, V3.8153
after a complete new install on my Rpi-3 I keep getting the following errors.
2017-08-05 16:08:21.767 Starting shared server on: :::6144
2017-08-05 16:08:21.767 TCPServer: shared server started...
2017-08-05 16:08:21.767 RxQueue: queue worker started...
2017-08-05 16:08:23.769 Hardware Monitor: Started
2017-08-05 16:08:23.794 EventSystem: reset all events...
2017-08-05 16:08:23.798 EventSystem: reset all device statuses...
2017-08-05 16:08:23.799 EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-08-05 16:08:23.799 EventSystem: Started
2017-08-05 16:08:25.975 Incoming connection from: 192.168.1.17
2017-08-05 16:08:26.302 Incoming connection from: 192.168.1.52
2017-08-05 16:08:21.483 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-08-05 16:08:21.483 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2017-08-05 16:08:21.484 Startup Path: /home/pi/domoticz/
2017-08-05 16:08:21.707 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-08-05 16:08:21.714 Active notification Subsystems: gcm, http (2/12)
2017-08-05 16:08:21.744 WebServer(HTTP) started on address: :: with port 8080
2017-08-05 16:08:21.764 WebServer(SSL) started on address: :: with port 443
2017-08-05 16:08:21.766 Proxymanager started.
can you please tell me where this goes wrong?
thanks in advance!
indeed, installing python3-dev did the job.
can't remember i installed it with the previous stable version of domoticz.
if it is a necessity, perhaps it is an idea to put it in the installer so a complete package could be installed.
Cheers
MartenW
Domoticz version: 3.4834
Post by MartenW » Wednesday 09 August 2017 17:04
Nice work, now the update function in Domoticz works as supposed. Unfortunately Domoticz will not work any longer after the update. Just the notice Domoticz is Offline appears.
I use the last version of Debian Jessie and that worked fine with the pre version of Domoticz. A fantastic program by the way, glad that my backup system is still working. Have the update function deactivated.
G3rard
Domoticz version: V3.8153
Post by G3rard » Wednesday 09 August 2017 22:23
Make sure there is no file script_device_PIRsmarter.py is the domoticz/scripts/python directory. If it is there you can safely delete is, as it is an old example file causing issues.
Ubuntu Server 14.04 | Domoticz v3.8153 | RFXtrx433E | Z-Wave Aeotec Z-Stick S2
Frontpage | Sonos PHP | Dark th3me | Sony Bravia Python plugin | Sonos Python plugin
felix63
Post by felix63 » Wednesday 09 August 2017 22:48
Did a clean install. No script_device_PIRsmarter.py in the domoticz/scripts/python directory. Could it be that something that was in that specific file was included in a custom script?
toro
Post by toro » Wednesday 09 August 2017 23:16
user1303 wrote:
Tuesday 01 August 2017 11:52
Thank you very much for the update, i always look forward to new features.
however; yesterday i installed the new version on my windows machine, and all went well expect one thing, most of the IDX ids have changed the old ones dont work anymore and new ones were assigned to the same sensors.
this is mostly with motion sensors or anything that sends data back to Domoticz, i use Mysensors and i have plenty of rules, but not none of it works due to the change in IDs and none of the sensors are reporting back.
any idea why new ids were assigned? and is there a way i can fix this easily, otherwise i would need to reconfigure eveything, scripts, events and notifications and its hours of work.
please help because now my whole setup is broken
I have exactly the same. The MySensors devices are added again, all with one extra zero in the Device ID. So now I have for instance device 0000005 with all it's units and 00000005 with the same units. Restoring a backup of the database is not a solution, the devices are added again right after the restore.
poudenes
Domoticz version: 3.8993
Post by poudenes » Thursday 10 August 2017 8:05
Did a fulll clear Raspbian install and domoticz 3.813 install
when i start it using:
./domoitcz -www 8081
and stop it i see a error at the end
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
  what():  boost: mutex lock failed in pthread_mutex_lock: Invalid argument
Aborted
does someone knows what this can be?
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
Padster
Post by Padster » Thursday 10 August 2017 11:02
I'm not sure if this is related to the upgrade which I performed on as soon as released but my smoke and heat alarms and also my two sirens have not been seen since the upgrade.
At least that what it says in the 'Devices' tab. I noticed because I replaced the batteries in them and they still show their old battery levels and last seen as 31/07/2017. However if I go into 'Hardware' and 'setup' on my Razberry2 it shows the alarms nodes as last seen 10/08/2017.
My PIRs and Lights are reporting just fine - it only seems to affect the smoke detectors and sirens.
Any ideas as to whats going on and what I can do to solve it?
arma_esiea
Post by arma_esiea » Thursday 10 August 2017 11:08
Warning my connection port was too high on the latest version, I was forced to lower it below 10000 to be able to restart domoticz
gregzs
Post by gregzs » Thursday 10 August 2017 13:16
Gizmocuz,
Thanks for great work but you could mention that you've limited the port range on which DOMOTICZ can bind, as with previous version I was binding on ports >50000 but after upgrade my DOMOTICZ wouldn't launch. I figure out with current version it has to be below 32768. Any reason for this limitation ?
Best regards,
Greg
gizmocuz wrote:
Sunday 30 July 2017 13:02
Before upgrading it is advised to:
- Make a backup of your database (from the settings page) and scripts folder(s)
- Raspberry Pi; Make a complete backup of the SD card
- Make a backup of the whole Domoticz installation folder
If the above steps are made, you should always be able to switch back in case there are troubles (which we hope not to see)
Domoticz will not be distributed anymore via a Raspbery Pi SD Card, but you can now install it via a single commandline:
sudo curl -L install.domoticz.com | bash
The above should also work for other debian systems
To all who donated via PayPal to the Domoticz project, note that we really appreciate your donations.
They all have been received and used to buy new hardware to integrate into the system.
It is just that we could not yet reply to you all because of the little spare time we have!
Rob
Trigun
Post by Trigun » Friday 11 August 2017 22:00
dear all,
can anyone please help me out here?
I am running on a raspberry pi 3 but after a clean install i got the following error:
after doing some research i installed: sudo apt-get install python3-dev
but then I get the following error.
2017-08-11 19:13:17.796 Build Hash: 494fff7, Date: 2017-07-30 10:19:41
2017-08-11 19:13:17.797 Startup Path: /home/pi/domoticz/
2017-08-11 19:13:18.247 PluginSystem: Started, Python version '3.4.2'.
2017-08-11 19:13:18.277 WebServer(HTTP) started on address: :: with port 8080
2017-08-11 19:13:18.293 WebServer(SSL) started on address: :: with port 443
2017-08-11 19:13:18.294 Proxymanager started.
2017-08-11 19:13:18.295 TCPServer: shared server started...
2017-08-11 19:13:18.295 RxQueue: queue worker started...
2017-08-11 19:13:20.296 EventSystem: reset all events...
2017-08-11 19:13:20.303 EventSystem: reset all device statuses...
2017-08-11 19:13:20.441 Python EventSystem: Module not found - Trying to initialize.
2017-08-11 19:13:20.443 Python EventSystem: Initalizing event module.
2017-08-11 19:13:20.444 EventSystem: Started
2017-08-11 19:13:20.476 PluginSystem: Entering work loop.
can't seem to get a good clean install.
anyone here that canhelp me out?
jvdz
Domoticz version: Stable
Post by jvdz » Friday 11 August 2017 22:09
Don't think there is anything wrong with that last log. Doesn't your system work?
Jos
Trigun
Post by Trigun » Friday 11 August 2017 22:10
The log is continuous, it keeps comming it seems like there is a loop
jvdz
Post by jvdz » Friday 11 August 2017 22:16
So you mean to say that Domoticz crashes and then starts again? This isn't shown in the last log though.
Jos
Trigun
Post by Trigun » Friday 11 August 2017 22:18
Hi Jos, thnx for Your help! After the last line, domoticz starts all over again. I just pasted 1 of the series to show where it Goes wrong
draykfr
Domoticz version: stable
Post by draykfr » Friday 11 August 2017 23:59
Great Job for this update.
Maybe just a little bug, but since this update it's impossible to add an 'ECO DEVICE', we can't add the IP and port for this device, when we choose 'ECO DEVICE'.
In last version it's works.
is there any way to add an device without the web interface, manually ?
SORRY NO BUG, MY MISTAKE WITH THE WEB BROTHER CACHE ... everything is ok
Trigun
Post by Trigun » Saturday 12 August 2017 7:55
Trigun wrote:Hi Jos, thnx for Your help! After the last line, domoticz starts all over again. I just pasted 1 of the series to show where it Goes wrong
Any idea guys?
mivo
Post by mivo » Saturday 12 August 2017 10:22
Any idea guys?
so your Domoticz restarts repeatedly, logging your posted messages repeatedly ? Domoticz does not restart itself probably. What startup method of Domoticz do you use ? Script in /etc/init.d/domoticz.sh or Systemd unit (with Restart=on-failure) ?
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
Pauls
Post by Pauls » Saturday 12 August 2017 11:25
Thanks again for all the hard work.
I have allthough an issue, maybe someone knows how to handle this.
Since the update the status of the door contacts in the floorplan are not updated anymore.
Lights and other items are ok.
In the switches screen however, the status of the door contacts are updated as it should be.
Any idea how to fix this?
Users browsing this forum: No registered users and 4 guests
