Domoticz version 3.8153 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
galadril
Target OS: Raspberry Pi
Domoticz version: latest
Re: Domoticz version 3.8153 released (Stable)
Post by galadril » Monday 31 July 2017 9:44
Nice!!!
jadijkstra2000
Post by jadijkstra2000 » Monday 31 July 2017 9:59
I had something strange.... just did the update, was okay, after reboot...old version...
Any thoughts?
FritzzJan
Post by FritzzJan » Monday 31 July 2017 10:13
Thank you Gizmocuz for all the hard work!
freijn
Post by freijn » Monday 31 July 2017 11:36
Many thanks !!!!
Hit the upgrade button and Voila :
2017-07-31 10:24:45.673 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-07-31 10:24:45.674 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2017-07-31 10:24:45.674 System: Raspberry Pi
2017-07-31 10:24:45.674 Startup Path: /home/pi/domoticz/
2017-07-31 10:24:45.722 EventSystem: reset all events...
2017-07-31 10:24:45.909 PluginSystem: Started, Python version '3.4.2'.
2017-07-31 10:24:45.919 WebServer(HTTP) started on address: :: with port 8080
2017-07-31 10:24:45.925 WebServer(SSL) started on address: :: with port 443
2017-07-31 10:24:45.927 Proxymanager started.
2017-07-31 10:24:45.928 Camera: settings (re)loaded
2017-07-31 10:24:45.964 TCPServer: shared server started...
2017-07-31 10:24:45.964 RxQueue: queue worker started...
2017-07-31 10:24:45.984 Incoming connection from: 192.168.1.163
2017-07-31 10:24:47.964 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2017-07-31 10:24:47.968 Wunderground: Worker started...
2017-07-31 10:24:47.968 SolarEdgeAPI Worker started...
2017-07-31 10:24:47.968 EventSystem: reset all events...
2017-07-31 10:24:47.969 EventSystem: reset all device statuses...
2017-07-31 10:24:48.107 Python EventSystem: Module not found - Trying to initialize.
2017-07-31 10:24:48.109 Python EventSystem: Initalizing event module.
2017-07-31 10:24:48.109 EventSystem: Started
2017-07-31 10:24:48.169 RFLink: Using serial port: /dev/ttyACM0
2017-07-31 10:24:48.225 PluginSystem: Entering work loop.
2017-07-31 10:24:49.091 RFLink: Controller Initialized!...
2017-07-31 10:24:49.167 RFLink Detected, Version: 1.1 Revision: 39 Build: 1
2017-07-31 10:24:49.749 Incoming connection from: 192.168.1.156
But any idea who wants to play Ping Pong with me?
Never seen this message before.... :-(
2017-07-31 11:30:39.645 RFLink: 20;50;PONG;
2017-07-31 11:31:29.665 RFLink: 20;51;PONG;
2017-07-31 11:32:19.689 RFLink: 20;52;PONG;
2017-07-31 11:33:09.708 RFLink: 20;53;PONG;
blacksn0w
Post by blacksn0w » Monday 31 July 2017 11:39
freijn wrote:Many thanks !!!!
This is the "alive" check of your RFLink, Domoticz is sending the ping, RFLink is answering with the pong.
Migration in progress, hello Home Assistant.
Herman-H
Post by Herman-H » Monday 31 July 2017 11:43
Thanks,
nizaga
Post by nizaga » Monday 31 July 2017 11:45
I just updated to latest stable, everything works OK, but i get now an error message everytime i iniciate a switch command.
The command gets successfully executed, but an error message is shown (happens for every switch type, zwave, whatever...)
2017-07-31 11:38:43.948 User: Admin initiated a switch command
2haasm
Domoticz version: 3.8153
Post by 2haasm » Monday 31 July 2017 12:02
Is this really an error message?
In the settings/ protocol, there are three headers:
all, status, error
I knew from some older beta versions, that sometimes messages are send to the wrong section (e.g. status messages are in the error header)
As long as there are no other problems, i reduce the logging of domoticz to a minimum level, by adding "-loglevel 1" do DAEMON_ARGS in the /etc/init.d/domoticz.sh script
DAEMON_ARGS="$DAEMON_ARGS -log /var/tmp/domoticz.txt"
DAEMON_ARGS="$DAEMON_ARGS -loglevel 1"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
Messages like yours probably won't show up any more
Raspberry Pi 3, Aeon Labs Z-Wave USB Stick Gen 5
Fibaro (FGWPE, FGS213, FGS223, FGMS001, FGK10x, Swipe), Qubino (ZMNHSDx), Popp (KFOB-C, Smoke, solar siren), etc.
nizaga
Post by nizaga » Monday 31 July 2017 12:08
thanks.. but i prefer to go back to the previous stable and wait for issues to be solved.
there are no really errors, in fact, the message keeps coming and coming (same message):
2017-07-31 11:54:44.432 User: Admin initiated a switch command (285/M80/Off)
and so on....
thanks anyway
jadijkstra2000
Post by jadijkstra2000 » Monday 31 July 2017 12:18
Hmmm, update via interfaces fails, via console works OK, until reboot... old version...
any idea?
jimtrout87
Post by jimtrout87 » Monday 31 July 2017 12:31
jadijkstra2000 wrote:Hmmm, update via interfaces fails, via console works OK, until reboot... old version...
any idea?
I had this before and it was a corrupt SD. The data stays in memory and seems to work until reboot. Be worth checking logs on one of your devices and check when it was last updated. I had lost 3 months or so of info. Also if you created any new blocky\lua since last reboot, are they are still there?
On another note, does the update include the changes to Python - i did beta updates and it broke all my plugins... i dont really have time to sort these at the moment.
SweetPants
Domoticz version: V4.10196
Post by SweetPants » Monday 31 July 2017 12:32
nizaga wrote:2017-07-31 11:38:43.948 User: Admin initiated a switch command
Where does it say it's an error message?
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
basmeyer
Domoticz version: 3.5837
Post by basmeyer » Monday 31 July 2017 13:21
Hi yall Domoticz members (post #1)!
I was very pleased to see in the web-interface that there was an update!
At the same time and to my regrets, as of today Domoticz was for a hours no longer working here. Coincidence?
Following the logical route to update, as an attempt of many to get Domoticz back online again, did not result in an update on a Asustor NAS (AS6202T).
But now, hours later, a miracle: the web-interface frontend on various devices is saying V3.8153 and everything within Domoticz seem to be working as normal again!
The only weird thing is, when I go into the NAS frontend so to the App Central to check which version of Domoticz is running, it is still saying that it is on version 3.5837 with last modification on 2016/04/29. Clicking on Update results in a message that all apps seems to be up-to-date.
Any thoughts?
SweetPants
Post by SweetPants » Monday 31 July 2017 13:24
Cleared your browser cache and/or App Cache?
jadijkstra2000
Post by jadijkstra2000 » Monday 31 July 2017 13:30
Indeed....created blocky event...gone after reboot.
I will buy a new card and restore the data (hopefully that works!)
any idea?
Luigi87
Post by Luigi87 » Monday 31 July 2017 13:46
Thanks to all who contributed to this update :D
basmeyer
Post by basmeyer » Monday 31 July 2017 15:01
SweetPants wrote:Cleared your browser cache and/or App Cache?
Not sure what you mean, but there was no need to clear the browser caches.
On the app that is running on the Asustor NAS there are no other options then to start and stop the app, which I tried, including restarting the NAS.
PieterS
Domoticz version: V3.9483
Post by PieterS » Monday 31 July 2017 15:37
jumbotroll wrote:
cyberbob69 wrote:
PieterS wrote:...Wondering if there is any change for version Domoticz Stable for Synology V3.8153 for DSM 5.2 at the site of Jadahl. Its not on the list. :?
Indeed, she is not. Have you any news ?
Domoticz Stable V3.8153 for DSM 5.2 and DSM 6.1
http://www.jadahl.com/
Thanks a lot for fast service. Glad to see there is still support for my good old NAS. :D
SweetPants
Post by SweetPants » Monday 31 July 2017 21:18
This is in your browser. I'm pretty sure you have to do that.
niceandeasy
Post by niceandeasy » Monday 31 July 2017 22:17
Nice. A new version. It killed some of my LUA-scripted functionality. I was getting fired up to flame the new dzVents system but luckily, I found the culprit before I starting my rant...
LUA scripts are commonly named script_device_something.lua. An important change: if you have a device named 'something', this script will only execute on device changes of device 'something'.
So, after renaming some of my scripts, everything started working again.
Couldn't find this on the list of new features.
I'll look into dzVents later, when I have more time.
Now, let's search for the elusive colour info output for dummy RGB(W) dimmer, preferably in RGB format, so it can be used in LUA, for controlling home-brew RGB LED lighting...
