Domoticz version 3.8153 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
gizmocuz
Target OS: Raspberry Pi
Post by gizmocuz » Sunday 30 July 2017 13:02
Hi Everyone!
It has been quite a long time since a new release version has been published!
7 Months of hard work, debugging, testing , more work.. more testing, and we now hope to have reached a good point to make this new release.
Too many new features/changes and fixes have been made, but some important once have been listed below.
Big thanks to all beta testers and fellow developers !
Version 3.8153 (July 30th 2017)
- Fixed: Camera Editor, will now always refresh thumbnail in table
- Fixed: Devices could become invisible when a scene/group was added to the 'hidden devices' room plan with the same idx
- Fixed: JSon float/nan value, solved by upgrading JSonCPP
- Fixed: OZW, when a value is updated and the sensor did not exists before (for example a kWh sensor), it is created (saves a restart)
- Fixed: Daemonize compatible with Systemd forking type
- Changed: Blinds T5 till T13 new DeviceID generation, could cause new sensors
- Changed: Lessen rounding errors for computed energy
- Changed: Minimized On/Off/Script execution time
- Changed: SolarEdgeAPI, now only needs API Key
- Changed: Support symlinks for plugin and theme directories
- Changed: Switch type 'Door Lock' renamed to 'Door Contact'
- Changed: Temperature Only charts will not display the Humidity axis
- Changed: Wind Direction Graph, if sensor does not supports 'Gust', the 'Speed' value is used
- Changed: Updated OpenZWave (and configuration files)
- Implemented: Added a new parameter to disable the logging of event script triggers 'Script event triggered: ...'
- Implemented: AppLamp/LimitLess bridge V6.0 RGBW/RGBWW
- Implemented: Blinds T1 till T13 new supports the Stop button
- Implemented: Blockly/Lua Set SetPoint option
- Implemented: Devices, Log icon for Blinds
- Implemented: Dummy Hardware, Temp+Baro
- Implemented: Estonian Language support (big thanks to Kuido)
- Implemented: EvohomeWeb support (Thanks to Gordon3!)
- Implemented: General/Text sensor now able to be shared
- Implemented: I2C BME280 sensor (temp+hum+baro)
- Implemented: I2C for non arm systems
- Implemented: InfluxDB Data push
- Implemented: Latvian Language support (big thanks to Edgars)
- Implemented: Netatmo Home Coach support
- Implemented: Notification for Dummy Soil/Moisture sensor
- Implemented: Notification for Dummy Temp/Hum/Baro sensor
- Implemented: Notification for Alert Sensor via udevice JSON call
- Implemented: Onkyo AV Receiver (Thanks to dwmw2!)
- Implemented: Option to replace an Meter device
- Implemented: OZW, Added support for Atmospheric Pressure sensor
- Implemented: Python Plugin System
- Implemented: RFXtrx Lucci Fan implemented
- Implemented: RFXtrx RFY2 protocol implemented
- Implemented: RFXtrx Kangtai / Cotech implemented
- Implemented: RTL433 (Thanks to Petri Ahone!)
- Implemented: SolarEdgeAPI, support for multiple inverters
- Implemented: Support for Ble Box hardware
- Implemented: Support for different usage/return costs for electricity
- Implemented: Support for Intergas InComfort LAN2RF Gateway
- Implemented: Support for Open Weather Map
- Implemented: Support for Open Web Net
- Implemented: Support for XiaomiGateway Gateway
- Implemented: Support for YeeLight
- Implemented: Support for Youless LS120
- Implemented: Switch type 'Door Lock'
- Implemented: SysFS GPIO (Thanks to hvbommel/jvandenbroek!)
- Implemented: Teleinfo : Added a switch indicating the current cost slot
- Implemented: Timer Plan editor
- Removed: Razberry ZWave handling method. Existing users need to migrate to OpenZWave
^^ And many more features and changes !!
Before upgrading it is advised to:
- Make a backup of your database (from the settings page) and scripts folder(s)
- Raspberry Pi; Make a complete backup of the SD card
- Make a backup of the whole Domoticz installation folder
If the above steps are made, you should always be able to switch back in case there are troubles (which we hope not to see)
Domoticz will not be distributed anymore via a Raspbery Pi SD Card, but you can now install it via a single commandline:
sudo curl -L install.domoticz.com | bash
The above should also work for other debian systems
To all who donated via PayPal to the Domoticz project, note that we really appreciate your donations.
They all have been received and used to buy new hardware to integrate into the system.
It is just that we could not yet reply to you all because of the little spare time we have!
Rob
maomanna
Re: Domoticz version 3.8153 released
Post by maomanna » Sunday 30 July 2017 13:26
great work!!
can this version be considered as the new stable?
gizmocuz
Post by gizmocuz » Sunday 30 July 2017 13:27
Yes it is...
Gerwin
Re: Domoticz version 3.8153 released (Stable)
Post by Gerwin » Sunday 30 July 2017 13:55
this is amazing
Thank you for all the hard work
dressie
Domoticz version: V3.8153
Post by dressie » Sunday 30 July 2017 14:37
Thank you so much for all the hard work and dedication!
Getting ready to install it now... :)
dressie
G3rard
Post by G3rard » Sunday 30 July 2017 14:38
That is great!
Thanks to all developers who have worked on this release .
Ubuntu Server 14.04 | Domoticz v3.8153 | RFXtrx433E | Z-Wave Aeotec Z-Stick S2
Frontpage | Sonos PHP | Dark th3me | Sony Bravia Python plugin | Sonos Python plugin
Doler
Post by Doler » Sunday 30 July 2017 14:50
It's a pity that dzVents didn't get a mention :o
Mark: Domoticz Beta on Raspberry Pi 3 running Debian Jessie - RaZberry - RFXCom - MySensors - SolarEdge - Dahua - dzVents
camielk
Domoticz version: 3.8153
Post by camielk » Sunday 30 July 2017 15:20
Thank you to all the developers of this stable version of Domoticz! :D :D :D
andi216
Domoticz version: 3.7243
Post by andi216 » Sunday 30 July 2017 17:40
Thank you for all the hard work !!!
nizaga
Post by nizaga » Sunday 30 July 2017 20:58
Thanks for all the hard work! What is the OZW version packed with the new release? Is the central scene now supported for devices like fibaro button?
Enviado desde mi iPhone utilizando Tapatalk Pro
PieterS
Domoticz version: V3.9483
Post by PieterS » Sunday 30 July 2017 21:14
Thanks for all the hard work.
Wondering if there is any change for version Domoticz Stable for Synology V3.8153 for DSM 5.2 at the site of Jadahl. Its not on the list. :?
bueno79
Domoticz version: 3.5877
Post by bueno79 » Sunday 30 July 2017 22:10
Thanks you so much for all your efforts. COntinue like this! We love Domoticz !!!
EddyG
Domoticz version: 3.9517
Post by EddyG » Sunday 30 July 2017 22:22
Perfect. Thanks to all developers. Keep up the brillant work. :D
Regards,
Eddy
cyberbob69
Post by cyberbob69 » Sunday 30 July 2017 22:52
PieterS wrote:...Wondering if there is any change for version Domoticz Stable for Synology V3.8153 for DSM 5.2 at the site of Jadahl. Its not on the list. :?
Indeed, she is not. Have you any news ?
Domoticz Stable V3.8153 on Synology DSM 5.2 / 2xRFlink V47.0 - 433.92 & 433.42 MHz / Script in LUA & Blocky
jumbotroll
Post by jumbotroll » Sunday 30 July 2017 23:09
Domoticz Stable V3.8153 for DSM 5.2 and DSM 6.1
http://www.jadahl.com/
Jumbotroll
Plantje
Post by Plantje » Monday 31 July 2017 0:16
How do I update when using Windows? If I hit the update now button I get a 404 error message.
gizmocuz
Post by gizmocuz » Monday 31 July 2017 8:47
Plantje wrote:How do I update when using Windows? If I hit the update now button I get a 404 error message.
Seems you are on windows, so just download the new installer from our homepage
Plantje
Post by Plantje » Monday 31 July 2017 9:23
Yes, I am on Windows. Created the backups, so I will run the installer. Thanks!
Perhaps in a new update that could be taken along: if on Windows disable the update button or guide the user to the installer.
corbin
Post by corbin » Monday 31 July 2017 9:34
Good to see the new release, thanks!
