BMP085 on P5 header Raspberry PI
Moderator: fantom
iganin
Target OS: Raspberry Pi
Post by iganin » Sunday 21 February 2016 20:39
Due to the fact that I attached PiFace to Raspberry PI, I've decided to use P5 header (RPI B Revision 2) for BMP085 connection.
As you can see below I managed to detect the sensor and read the values.
pi@Gate ~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_BMP085 $ sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- 77
pi@Gate ~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_BMP085 $ sudo python Adafruit_BMP085_example.py
Temperature: 18.70 C
Pressure:    1007.52 hPa
Altitude:    47.82
However Domoticz doesn't see BMP085:
2016-02-21 16:53:30.696 Error: BMP085: Error reading sensor data!...
I assume the root cause that Domoticz tries to find the sensor in I2C =1 instead of I2C =0
Does someone find or know a workaround?
Thank you in advance.
KR
Iganin
