Re-include existing node
EdddieN
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by EdddieN » Tuesday 02 October 2018 9:14
Hello there,
I have a Z-wave TRV (Euronic) and it has been working well for a year or so. Batteries started to go down and when I went to replace the batteries, the TRV was asking to be included on a network again, but Domoticz already has it.
Is there a way to re-include it without having to update all the IDx and some Events with a new node?
11101101 - www.machinon.com
emme
Domoticz version: latest
Re: Re-include existing node
Post by emme » Tuesday 02 October 2018 10:19
the follow works on Aeotec Stick Gen5
if th device lost its zwave home id you can start the inclusion procedure as a normal (new) node.
zWave stick will re-assign the same ID
if this does not work, you can try to use zensys tool to manual remove the device and include it back again, but this is not really suggested
"We always done this way"
hamster
Post by hamster » Saturday 06 October 2018 22:00
Can also try going into the zwave controller Control Panel in domoticz and run a 'test and heal' on the dead node. This works for me when nodes die.
EdddieN
Post by EdddieN » Sunday 07 October 2018 13:38
hamster wrote:Can also try going into the zwave controller Control Panel in domoticz and run a 'test and heal' on the dead node. This works for me when nodes die.
The device reset itself. I tried re adding but the device came as new. I’ll have to play a bit more before giving up :)
Patricen
Domoticz version: Beta rel
Post by Patricen » Tuesday 06 November 2018 8:09
Same issue with a Popp TRV (Thermostat Radiator Valve) using Domoticz and OpenZWave USB Version: 1.4-3229-g68ad0abe-dirty.
For some reason, I had to reset the TRV, but
I'm unable to reassign the original address. Did you find a trick?
EdddieN
Post by EdddieN » Tuesday 06 November 2018 11:04
No I had to add it again as a brand new node
