Disappearing nodes after restart
TomekM512
Post by TomekM512 » Saturday 21 April 2018 10:42
Does anyone know why i can't see any nodes after restart?
Z-wave seems to work properly. After reinstalling Domoticz they appears, but after restart, nodes list is empty.
In devices list i have all of them but not responding. I have answer: ×
Error sending switch command, check device/hardware !
I'm using Razberry with
OpenZWave USB
Version: 1.4-2501-g5af6780-dirty
See my log:
2018-04-21 08:34:24.768 OpenZWave: Received timeout notification from HomeID: 3885638811, NodeID: 255 (0xff)
2018-04-21 08:34:37.592 OpenZWave: Received timeout notification from HomeID: 3885638811, NodeID: 255 (0xff)
2018-04-21 08:35:15.489 OpenZWave: Driver Ready
2018-04-21 08:35:15.613 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-04-21 08:35:15.614 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2018-04-21 08:35:15.614 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2018-04-21 08:35:15.615 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-04-21 08:35:15.615 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-04-21 08:35:15.615 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-04-21 08:35:15.616 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-04-21 08:35:15.616 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-04-21 08:35:15.616 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: METER, Label: Energy, Instance: 1
2018-04-21 08:35:15.616 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: METER, Label: Power, Instance: 1
2018-04-21 08:35:15.617 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-04-21 08:35:15.617 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-04-21 08:35:15.617 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2018-04-21 08:35:15.617 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Power Management, Instance: 1
2018-04-21 08:35:31.697 OpenZWave: Received timeout notification from HomeID: 3885638811, NodeID: 8 (0x08)
2018-04-21 08:35:31.975 OpenZWave: Awake Nodes queried
2018-04-21 08:35:47.315 OpenZWave: Received timeout notification from HomeID: 3885638811, NodeID: 255 (0xff)
2018-04-21 08:36:38.118 OpenZWave: Heal Network command initiated...
2018-04-21 08:38:06.202 OpenZWave: All Nodes queried
EDITED: Interesting thing: after including already added node it appears and working until restart.
Tomek
DutchHans
Target OS: Raspberry Pi
Re: Disappearing nodes after restart
Post by DutchHans » Saturday 21 April 2018 23:24
Do you have an RF-link aswell.?..
If that is the case, switch off the pi.. Unplug the RF-link... Boot the Pi... After a minute or so replug the RF-link.. All the z-wave nodes are back.. (that is the case in my setup)
Success, Hans
TomekM512
Post by TomekM512 » Saturday 21 April 2018 23:32
Thanks for answer, but I haven't RF Link. Clear system. Only Razzbery added.
I have no idea what is wrong.
Wysłane z mojego SM-N950F przy użyciu Tapatalka
