Zwave groups - why?
billytkid
Target OS: Raspberry Pi
Zwave groups - why?
Post by billytkid » Friday 05 January 2018 19:35
I dont relate any of my zwave devices together (ie switch 1 = relay 1), so i dont know what groups do, or are for.
Should I ever change anything in them? Or Just leave them alone?
Below is my current setup, where I've got some devices that have good mesh, but keep 'bouncing' on after they've turned off...
Any advise is greatly appreciated
thanks
cogliostrio
Re: Zwave groups - why?
Post by cogliostrio » Friday 05 January 2018 20:19
If you dont know what it is, or does. I would leave it alone for now.
This is a good read, http://www.vesternet.com/resources/tech ... sociations
You could for instance use association.
As an example, I use association on the lights in my bedroom, to turn off all lights when long press on a switch next to my bed.
..keep 'bouncing' on after they've turned off...
Not quite sure what you mean by this. Could you elaborate, or give some examples?
billytkid
Post by billytkid » Friday 05 January 2018 21:11
ok thanks
On my problem I used Blockly events to do things, such as:
At sunset turn on Scene A (this is about 5 lights)
At sunrise turn off Scene A.
The problem I keep facing on different lights is that within the Scene some of the switches will turn on (or off) when requested, but then a few seconds later will turn off (or back on). Which means instead of the event running and Scene A being off, I'm left with a mix.
This happens on a bunch of different devices, all with a reasonable mesh to other devices...
Really annoying, and it's lowering the WAF factor.
MrRikkie
Post by MrRikkie » Saturday 06 January 2018 14:15
I'm using the groups in combination with my fibaro switches and remote wall switch (ZME_WALLC-S).
I have configured the remote wall switch to turn on some of the lights in my living room and if I double click on the switch all lights in the living room and kitchen switch off.
See attached picture with explaination how it works in my situation.
Group overview
Hope this helps.
billytkid
Post by billytkid » Sunday 14 January 2018 15:52
Thanks all,
I played some with this after your reply and I've found that adding in a 5 second delay between the items in the group fixed the issue.
It seems that Domoticz may have issues sending to several devices at exactly the same time.
thanks
