NeoCoolCam Motion , PIR Sensor questions
lumjajo
Target OS: Raspberry Pi
Post by lumjajo » Saturday 30 December 2017 22:39
Hi Guys,
does anyone use the NeoCoolcam PIR sensor? I have it inculded, but it only shows 4 switches, 2 Motion alarm, one Motion Sensor and a Burglar switch.
It should show a Lux meter as well. Thi sbrings me to my second question.
Configuration of a battery powered device is really difficult. How do you handle this, In this case, I cannot update the configuration no matter how often I am pushing the "upload " button.
Thanks and have a happy 2018
lumjajo
Re: NeoCoolCam Motion , PIR Sensor questions
Post by lumjajo » Saturday 30 December 2017 22:45
I wrote this, updated my device list and the Lux Meter can be seen. However, update of the configuration is still not possible.
koningdde
Post by koningdde » Saturday 30 December 2017 22:50
Press the button inside once, this will wake up the device. Then send!
madpatrick
Domoticz version: 3.8153
Post by madpatrick » Sunday 31 December 2017 12:44
You indeed to push the button inside the PIR and then submit the changes.
Sometime you need to repeat this several times before it is accepted.
Does somebody know how you can get an frequently updated lux measurement to domoticz ?
miremi
Post by miremi » Sunday 31 December 2017 13:12
I have 6 of them and on each of them i get 7 devices:
Alarm Type
Alarm level
Pir sensor
Burglar
Alarm type: burglar
LUX
Temperature
To update configuration first make changes save and then push the button once on motion sensor. The stored configuration the pushes to sensor.
To change lux update time i have changed settings
7. Light sensor polling interval to 180 sec.
And
9. Ambient illumination Lux level report from 100 to 2.
This working fine for me and i get in 3 minutes update if lights changed.
Ubuntu 16.04.3, Core i5 8GB Ram 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5
lumjajo
Post by lumjajo » Monday 01 January 2018 19:10
Hi and thanks for the information.
I will test it.
What surprises me is, that you have temperature. I would need this , but I did not get the switch. It slao not in the documentation as far as I see. But they do not have so many different PIR sensors as far as I know.
Anyway, lets see.
Jo
sincze
Domoticz version: 3.8875
Post by sincze » Monday 01 January 2018 21:44
Ha after a hard reset I never received the lux meter back again on any of my motion sensors from NEO.
It's a pitty as it should work and did work on 2 of them at least.
However removing and re-adding them to the network does not give me back my lux meters.
Even after a hard reset.
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
miremi
Post by miremi » Monday 01 January 2018 23:12
I will test it.
Anyway, lets see.
Jo
From what i know in first version there was no temperature sensor. Recent version has it on board.
https://www.aliexpress.com/item/NEO-COO ... e1e2e7f0d7
Did you try hard reset pir sensor by pushing the button for 20 sec? And remove all associated devices from domoticz device tab and then include it again.
I have more than 20 coolcam devices and all works fine.
lumjajo
Post by lumjajo » Tuesday 02 January 2018 16:09
Thanks, I have mine bought from ali just revcently, BUT it was 10€ cheaper.Good to knoe it has temperatur included now. So I will buy some more.
sincze
Post by sincze » Wednesday 03 January 2018 19:50
A yes, that 20 seconds got me into this situation ;-) after the hard reset they (lux) did not show up, only motion.
USB: RFXCom, ZWave
wube
Post by wube » Tuesday 09 January 2018 14:49
Hi guys,
I have a gen5 aeon labs z-wave stick and also bought this pir sensor. I have read that when you add it via button on the usb stick they not always get discovered well, so i've added it via Domoticz (few times excluded and included, also reset the usb stick as well as the pir) and I always and i mean always get:
Lux sensor in Utility tab
and in the switches tab i get:
Alarm Type
Alarm Level
Sensor
Sensor
Alarm Type Burglar (0x07)
All apear as on/off switches ... on some of them i can see on / off time when open Log.
There is no motion sensor.
Any Idea how to properly include this and have the full functionality?
Domoticz running on QNAP (3.8314) from Aug 17th 2017
Nautilus
Post by Nautilus » Wednesday 10 January 2018 1:00
Alarm Type
Alarm Level
Sensor
Sensor
This is how all motion sensors work at least for me. When first created, the sensor shows as on/off switch. Then you just change the type to a motion sensor. The documentation should tell you what all the different devices are for but usually it is one (or two) of them that follows the motion triggers so just choose that, change the type, and be happy...:) Unless you really need to find out how utilise the others as well.
lost
Post by lost » Wednesday 10 January 2018 14:15
All devices IDs are in the hexadecimal form XXYY, with XX=node ID in hardware tab under z-wave controller items. YY is the sub-ID of switches/temp sensors etc belonging to device XX.
When not sure, just classify all known devices per last update, trigger the device (move in front for a PIR...) & refresh: You should find the right subdevice ID in the very first lines.
Nautilus
Post by Nautilus » Thursday 11 January 2018 0:05
A good tip but in my reply I referred to documentation if you need to understand the purpose of the other switches created. It should be quite easy to identify the one (or two) which follows motion triggers. But then which one is a tamper sensor etc. is maybe not that clear.
rizzah
Post by rizzah » Monday 15 January 2018 11:16
I have bought a couple of NEO Coolcam's lately. When i added them to domoticz it received lux value, but soon it was showing that sensor as dead, or atleast it didnt receive anymore updates. I replaced the battery and it received a couple of lux updates, however, it does not anymore.
Does anyone know what i can do to keep the neo coolcam to send lux updates to domoticz?
lost
Post by lost » Wednesday 17 January 2018 10:13
Should be a device parameter setup stuff: Send updates every YY seconds or if lux vary more than XX percent... Just take care to wake-up device (pressing internal switch also used for association, usually 1 time) for changes to be effective immediately for such battery operated device.
rizzah
Post by rizzah » Friday 26 January 2018 13:27
@lost Thanks, it was that parameter indeed!
