Qubino Flush 2 relay with push button controll
dagger38
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by dagger38 » Saturday 23 December 2017 15:45
I have got 2 flush 2 relay switches from qubino.
I want to switch these on and off with a push button.
Push button is connected to I1.
the Q1 output is set to mono stable switch type (push button)
Problem , when i press the button the light go's on , if i release it , the light go's off??
Shoudln't the light stay ON untill i push the button one's again??
Or what am i douing wroung??
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
Denny64
Re: Qubino Flush 2 relay with push button controll
Post by Denny64 » Sunday 24 December 2017 19:02
I also have some Qubino switches and they work properly with Domoticz. The only flaw I found is a very frequent latency, and it's not possible to put them inside a scene..
For your problem, try to exclude them from the network and reassociate them by changing parameters 1 and 2 again.
Do not forget to save the configuration, press update and select the Qubino switch again to see if the parameters have been correctly saved.
dagger38
Post by dagger38 » Sunday 24 December 2017 19:08
going to try that
My system:
1 Raspberry Pi 3
1 Milight module
1 Niko home system
