All Z-wave nodes gone after server reinstall Topic is solved
Evelen
Domoticz version: 2.4538
Post by Evelen » Friday 22 December 2017 17:45
Hi.
I Am running Domoticz on Ubuntu server, and it worked perfect, but due to mess on the ubuntu server I just wanted to do a clean install.
Så this is what i did:
- created a database backup "domoticz.db"
- Reinstalled Ubuntu Server
- Installed Domoticz
- Started Domoticz, imported domoticz.db
- All devices are presented in devices, and all my RFXCOM devices work, but not the Z-wave devices. I use UZB1
- Also noted that the login to Domoticz webpage changed to the same username as on last installation (not really a problem)
Any solution?
PS: This is a VM in ESXI, and I have a backup of the old VM, so if i need some files or something I a amble to get that.
Quax1507
Target OS: Raspberry Pi
Re: All Z-wave nodes gone after server reinstall
Post by Quax1507 » Friday 22 December 2017 17:54
I normally make a backup of the whole /.../domoticz directory which can be copied over the new installation.
This worked fine so far...
Clemen
Post by Clemen » Friday 22 December 2017 18:34
The z-wave configuration are stored on the z-wave stick.
What type of z-wave stick are you using?
Is it connected, it seems to that your domoticz can't see the stick
Evelen
Post by Evelen » Friday 22 December 2017 18:56
Got ut to work by re-insetting it in the ESXI host :D
thanks for help
lost
Post by lost » Tuesday 26 December 2017 19:05
thanks for help
Another tip was given here:
http://www.domoticz.com/forum/viewtopic ... 59#p156459
But didn't tried as after my reinstall that lead to same zeroed IDs, never runned again in this problem.
