Fibaro Double Switch FGS-223 only switches with physical toggle switch
meijerpeter
Target OS: Raspberry Pi
Post by meijerpeter » Wednesday 15 March 2017 10:44
I have several Fibaro z-wave devices around the house in combination with Domoticz on a RPi3. The majority is installed with a momentary switch in combination with a dimmer module.
My issue is that I cannot switch S1 with Domoticz, only with the (single) toggle switch. S2 can be switched with Domoticz, but I have no physical switch attached to Q2/S2. Parameter 20 is on '2', I have also tried '1'.
Does anyone know if I have to set another parameter to enable the switching from within Domoticz??
Many thanks!
pvdhelm
Re: Fibaro Double Switch FGS-223 only switches with physical toggle switch
Post by pvdhelm » Thursday 16 March 2017 13:18
reboot your domoticz server and it wil work. Had the same issue
meijerpeter
Post by meijerpeter » Tuesday 21 March 2017 8:34
Worked! Many thanks!!
FriedlNet
Domoticz version: 3.6334
Post by FriedlNet » Sunday 09 April 2017 12:33
It works for me very well too. Many thanks!!
berny
Post by berny » Sunday 16 April 2017 1:00
I spend hours to resolve this problem after include FGS-223
S1(switch on/off) / Q1(on/off) => OK
S2(switch on/off) / Q2(on/off) => OK
via domoticz:
S1(domoticz on/off) / Q1(on/off) => NOT OK!!!
S2(domoticz on/off) / Q2(on/off) => OK
when I have read this subject and
I have REBOOT my Raspberry => everything OK!!!
Thanks for this hint.
But why ??
Olfer
Post by Olfer » Tuesday 23 May 2017 10:15
Also worked for me! Thanks a lot for this hint!
Noob.
Domoticz on RPi3 with Aeontec Z-Stick gen5.
Devolo Thermostats and Room Control, Neo CoolCam Power Plug, Devolo Switch (not working), Fibaro Relays 2x3
robpow
Domoticz version: Beta :)
Post by robpow » Tuesday 14 November 2017 21:02
Can’t believe it was that easy! Had the exact same problem.
Matt
Abelphoenix
Post by Abelphoenix » Wednesday 15 November 2017 13:04
I have the same problem Q1 does not change state with domoticz. in windows it does not work restarting the system. Any solution please?
Kazaa2978
Post by Kazaa2978 » Wednesday 27 December 2017 23:41
This worked for me also!
Edit ... Below also solved after next reboot next day
Almost......
Now both the Switches work again within Domoticz but still only one will react from my Homekit
In the beginning the S1 did not react by Domoticz and not by the app (S2 works perfectly)
But now S1 works from Domoticz but domoticz still does not react on Homekit(homebridge) push button
I have all the parameters the same between S1 and S2.
Anybody an idea, or how to see if homebridge actualy sends a signal to Domoticz?
chang
Post by chang » Saturday 27 January 2018 15:32
Rebooting via shell script worked for me too on Ubuntu.
Abelphoenix
Post by Abelphoenix » Monday 05 March 2018 3:50
in windows no found... :(
