Aeotec Siren Gen5 parameters Topic is solved
Mecallie
Target OS: Raspberry Pi
Re: Aeotec Siren Gen5 parameters
Post by Mecallie » Friday 23 June 2017 9:34
mrdata wrote:<SNIP> Something in French</SNIP>
I have tried your json commands mrdata. At first I did not think they worked, until I noticed the "applyzwavenodeconfig" part in the URL. It seems it only works once: when the initial config is applied. For instance: when I set the sound to 3 and the volume to 1 in Domoticz my siren sounds. When I replay that json command it does not, because it is already set. When I play a different sound, say sound 4 volume 1, it works. Again: only once.
I think the applyzwavenodeconfig needs to be replaced by some kind of alarm command, but I have no idea what it would be :)
Until then I do not think you can use this for an alarm. If it has been triggered once, it will not trigger again. Unless you reset it to something different every x time. But that would get annoying since the siren would sound every time you did that. Now that I think of it: it would only sound if there was an alarm event. Otherwise it would ofcourse still be on the original setting and not sound...
bvhoesel
Post by bvhoesel » Sunday 13 August 2017 20:49
The following urls (shown here send with curl) will switch the sounds:
// "Sound 1 - Low Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMSAtIExvdyBWb2x1bWU%3D'
// "Sound 1 - Mid Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMSAtIE1pZCBWb2x1bWU%3D'
// "Sound 1 - High Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMSAtIEhpZ2ggVm9sdW1l'
// "Sound 2 - Low Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMiAtIExvdyBWb2x1bWU%3D'
// "Sound 2 - Mid Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMiAtIE1pZCBWb2x1bWU%3D'
// "Sound 2 - High Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMiAtIEhpZ2ggVm9sdW1l'
// "Sound 3 - Low Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMyAtIExvdyBWb2x1bWU%3D'
// "Sound 3 - Mid Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMyAtIE1pZCBWb2x1bWU%3D'
// "Sound 3 - High Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgMyAtIEhpZ2ggVm9sdW1l'
// "Sound 4 - Low Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNCAtIExvdyBWb2x1bWU%3D'
// "Sound 4 - Mid Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNCAtIE1pZCBWb2x1bWU%3D'
// "Sound 4 - High Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNCAtIEhpZ2ggVm9sdW1l'
// "Sound 5 - Low Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNSAtIExvdyBWb2x1bWU%3D'
// "Sound 5 - Mid Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNSAtIE1pZCBWb2x1bWU%3D'
// "Sound 5 - High Volume"
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=<NODE-ID>&valuelist=37_U291bmQgNSAtIEhpZ2ggVm9sdW1l'
To be sure the selected sound is heard (if you set it to the same sound as before) just switch the siren on (and later off) with:
// ON
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=switchlight&idx=<DEVICE-IDX>&switchcmd=On'
// OFF
curl 'http://<DOMOTICZ-SERVER>:8080/json.htm?type=command&param=switchlight&idx=<DEVICE-IDX>&switchcmd=Off'
Where <DOMOTICZ-SERVER> needs to be replaced with your domoticz server IP or name. And <NODE-ID> is the z-wave NodeID of the siren. And <DEVICE-IDX> is the index of the corresponding switch device.
The base64 and url encoded part after valuelist=37_ is the description of the sound as seen in de config page, for example "Sound 5 - High Volume" (without the double quotes). I dit not test all the urls so there might be a typo. But if so you know how to check and correct it.
Just incorporates these in you preferred language and then "Happy sound switching".
Ries
Domoticz version: 3.9639
Post by Ries » Friday 18 August 2017 11:08
I checked all the urls, but none of them worked even though the json call reported success.
Version 3.9639
Platform: Jessie lite
Hardware: Raspberry pi 3B; RFXCOM; Weather Underground; Dummy; OpenZwave USB; Fritzbox Callmonitor via LAN interface; System Alive Checker (Ping); Philips Hue Bridge; Atag One Thermostat
bvhoesel
Post by bvhoesel » Sunday 17 September 2017 13:58
They do work for me. Can you switch sound from the z-wave device config page? If so, did you check you have the correct z-wave NODE-ID (for sound setting) and Domoticz DEVICE-ID (for on/off)? You cannot rely on the json return status as indication of a correctly executed action on the intended device. As I saw, it is most of the time "OK". If I mangle a working url it shows OK as return status but no sound. So double check all values to be substituted in the example url's and try again. Where did you execute the curl command from? It definitely works for me when executed from the PI itself.
renerene
Post by renerene » Sunday 25 February 2018 13:56
Only swtich on/off works for me.
The other command
http://192.xxx.0.xxx:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=96&valuelist=37_U291bmQgMSAtIEhpZ2ggVm9sdW1l
gives error in browser:
   "status" : "ERR"
what is the 'U291bmQgMSAtIEhpZ2ggVm9sdW1l' part at the end? Is it unique per device?
Ries
Post by Ries » Tuesday 12 June 2018 10:06
Still no result
Version 3.9639
