Confused about which device belong to which zwave-node Topic is solved
jvdz
Target OS: Raspberry Pi
Domoticz version: Stable
Re: Confused about which device belong to which zwave-node
Post by jvdz » Sunday 07 January 2018 12:11
datagutten wrote:
Sunday 31 December 2017 15:14
You should send a pull request on this, it would be nice to have as a default feature.
Pull request is made: https://github.com/domoticz/domoticz/pull/2033
Edit:
When using whitespace the search does not work, so the underscore must be there.
I see you changed your post, but I have implemented it in the same was as displayed in the Zwave hardware devices list.
It now displays like this:
What I do to check things is just type the name of the ZWave hardware "ZWAVE" and then sort on the Hardware column so the display has the same sequence as the ZWave hardware devices list.
Jos
mischa
Domoticz version: 3.8872
Post by mischa » Tuesday 23 January 2018 0:43
First of all, thank you for this addition. Makes life a lot easier, switching from PI to Synology and have to include 30 nodes.
As some of the devices only appear after a while or for example when clicked on like the triple click of Fibaro devices.
this could take a while.
Not sure if possible but would it be a nice addition if the table could be grouped
Something like this.
Hardware
NodeID
Devices
Perhaps there is other hardware that could also benefit from this approach, like evohome, rfxcomm, ect ect
Mischa
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
SchattenMann
Post by SchattenMann » Wednesday 14 February 2018 13:04
thank you @jvdz - this is the single best add to Domoticz since I can remember :D
As a suggestion, add a "link" on the device ID to filter the devices' table. This is how I'm doing it now (added to my themes custom.js)
$("#devices tbody tr").each(function() {
			var html = $(this).children()[2].innerHTML;
			var className = $(this)[0].className;
			var res = html.match(/(\s[0-9]{3}\s[\(][0-9]x[a-zA-Z0-9]{2}[\)])$/g);
			var css = "";
			if(className == "odd") {
				css = 'style="color: #FFF"';
			if(res){
				$(this).children()[2].innerHTML = $(this).children()[2].innerHTML.replace(res,'<a href="#/Devices" '+css+' onClick="filter(\''+res+'\')">'+res+'</a>');
		function filter (idx) {
			$("#devices_filter input").val(idx);
			$("#devices_filter input").trigger( "keyup" );
mischa
Post by mischa » Wednesday 14 February 2018 18:58
@SchattenMann
where to put it, if you use the default theme?
SchattenMann
Post by SchattenMann » Wednesday 14 February 2018 19:22
just create a custom.js file on /domoticz/www/styles/your_theme and paste
jQuery(window).load(function() {
	setTimeout(function () {
			var css = "";
			if(res){
	},2500);
madpatrick
Domoticz version: 4.9700
Post by madpatrick » Wednesday 01 August 2018 16:32
Edit:
It now displays like this: Knipsel.PNG
Jos
Hello Jos,
I've adjusted the file /app/DevicesController.js but i don't see any changes in list.
Do i need to chage the database also as in your previous post ? or should changing the file be enough ?
ClearOS v7.5.0 - Toon2 v4.19.10 (rooted) - Domoticz v4.9700
jvdz
Post by jvdz » Wednesday 01 August 2018 17:05
This patch is part for the current release & beta, but it should appear right away after you clear the browser cache and refresh the page.
No other changes required. ;)
Jos
madpatrick
Post by madpatrick » Wednesday 01 August 2018 17:10
I'm currently still on v.3.8153, so that must the case ;-)
I did not make any changes to the database, but only adjusted the file.
After clearing the cache and refresh nothing is changed.
jvdz
Post by jvdz » Wednesday 01 August 2018 17:13
Check with F12 in Chrome whether the source looks correct as it is really a pretty simple change to the page generation for the Zwave devices.
Jos
madpatrick
Post by madpatrick » Wednesday 01 August 2018 17:23
Jos
That was the problem :roll:
Thanks for the help
Users browsing this forum: No registered users and 5 guests
