Z-Wave device xml update, how to submit?
lost
Target OS: Raspberry Pi
Post by lost » Friday 21 April 2017 15:33
I currently have a few problems in using a qubino smart-meter module and digged a bit in it's ZMNHTDx.xml vs device user manual.
Doing so, I spotted a few incoherences (especially on the relays delayed auto on/off parameter sizes, that may have been a root cause for the relay buggy behavior but was not) & corrected them.
I also added the parameters to tune the relays off of a max power is reached, allowing to use the feature (tested on my module) under Domoticz... Plus some other read-only ones but that do not report anything (too bad: getting counters at least in the parameters may have proved useful) but at least do not hurt.
=> do someone know the procedure for OZW team next release?
File diff vs current:
diff qubino/ZMNHTDx.xml qubino/ZMNHTDx_orig.xml
33c33
< 		<Value type="short" genre="config" instance="1" index="11" label="Automatic turning off IR external relay output after set time" size="2" min="0" max="32536" value="0">
> 		<Value type="short" genre="config" instance="1" index="11" label="Automatic turning off IR external relay output after set time" size="1" min="0" max="32536" value="0">
39c39
< 		<Value type="short" genre="config" instance="1" index="12" label="Automatic turning on IR external relay output after set time" size="2" min="0" max="32535" value="0">
> 		<Value type="short" genre="config" instance="1" index="12" label="Automatic turning on IR external relay output after set time" size="1" min="0" max="32535" value="0">
45c45
< 		<Value type="short" genre="config" instance="1" index="13" label="Automatic turning off External relay output after set time" size="2" min="0" max="32536" value="0">
> 		<Value type="short" genre="config" instance="1" index="13" label="Automatic turning off External relay output after set time" size="1" min="0" max="32536" value="0">
51c51
< 		<Value type="short" genre="config" instance="1" index="14" label="Automatic turning on External relay output after set time" size="2" min="0" max="32535" value="0">
> 		<Value type="short" genre="config" instance="1" index="14" label="Automatic turning on External relay output after set time" size="1" min="0" max="32535" value="0">
65c65
< 		<Value type="short" genre="config" instance="1" index="42" label="Power reporting in Watts by time interval" size="2" min="0" max="32767" value="0">
> 		<Value type="short" genre="config" instance="1" index="42" label="Power reporting in Watts by time interval" min="0" max="32767" value="0">
91,159d90
< 		<Value type="short" genre="config" instance="1" index="110" label="Power auto-triggering relay(s) off" size="2" min="0" max="15000" value="0">
< 			<Help>0 - Pmax auto OFF disabled.
< 			1W to 15000W Auto OFF enabled, step is 1 Watt. Linked with param 111/112.
< 			Default value 0 (disabled).</Help>
< 		</Value>
< 		<Value type="short" genre="config" instance="1" index="111" label="Power auto-triggering off-time" size="2" min="30" max="32535" value="30">
< 			<Help>30s to 32535s Auto OFF time, step is 1 sec, if param 110 pMax is reached.
< 			Default value 30.</Help>
< 		</Value>
< 		<Value type="list" genre="config" instance="1" index="112" label="Power auto-triggered OFF relay choice" size="1" min="0" max="3" value="0">
< 			<Help>Switch OFF IR external relay and/or External relay or both of them, if param 110 pMax is reached.
< 			Default value 0.</Help>
< 			<Item label="Altern OFF IR/Wired external relays" value="0" />
< 			<Item label="Switch OFF IR       external relay" value="1" />
< 			<Item label="Switch OFF Wired    external relay" value="2" />
< 			<Item label="Switch OFF Both     relays" value="3" />
< 		</Value>
< 		<Value type="int" genre="config" instance="1" index="130" label="Serial NB" size="4" read_only="true" >
<                         <Help>Returns device S/N.</Help>
<                 </Value>
< 		<Value type="short" genre="config" instance="1" index="131" label="Firmware Version" size="2" read_only="true" >
<                         <Help>Returns device FW version.</Help>
<                 </Value>
< 		<Value type="short" genre="config" instance="1" index="132" label="Hardware Version" size="2" read_only="true" >
<                         <Help>Returns device HW version.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="140" label="Voltage U1" units="deci-V" size="3" read_only="true" >
<                         <Help>Returns U1 in deci-Volts.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="141" label="Intensity I1" units="milli-A" size="3" read_only="true" >
<                         <Help>Returns I1 in milli-Amp.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="142" label="Active power Pt" units="deci-W" size="3" read_only="true" >
<                         <Help>Returns Pt in deci-Watt.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="143" label="Reactive power Qt" units="deci-kVAR" size="3" read_only="true" >
<                         <Help>Returns Qt in deci-kVAR.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="144" label="Power factor PFt" units="milli" size="2" read_only="true" >
<                         <Help>Returns PFt(x1000).</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="145" label="Energy counter 1, active power total (input)" units="deci-kWh" size="4" read_only="true" >
<                         <Help>Return Pin in deci-kWh.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="146" label="Energy counter 2, reactive power total (input)" units="deci-kVARh" size="4" read_only="true" >
<                         <Help>Returns Qin in deci-kVARh.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="147" label="Energy counter 3, active power total " units="deci-kVAh" size="4" read_only="true" >
<                         <Help>Returns Pt in deci-kVAh.</Help>
<                 </Value>
< 		<Value type="int" genre="config" instance="1" index="148" label="Energy counter 4, active power total (output)" units="deci-kWh" size="4" read_only="true" >
<                         <Help>Return Pout in deci-kWh.</Help>
<                 </Value>
164c95
< 		<Associations num_groups="1">
> 		<Associations num_groups="5">
165a97,100
> 			<Group index="2" max_associations="16" label="Basic on/off (IR external relay)"/>
> 			<Group index="3" max_associations="16" label="Switch binary report (IR external relay)"/>
> 			<Group index="5" max_associations="16" label="Basic on/off (External relay)"/>
> 			<Group index="6" max_associations="16" label="Switch binary report (External relay)"/>
177c112
< </Product>
> </Product>
LouiS22
Re: Z-Wave device xml update, how to submit?
Post by LouiS22 » Sunday 30 April 2017 18:05
You have to submit the changes into ozw github. There's a detailed how-to on their github page.
lost
Post by lost » Wednesday 03 May 2017 7:27
LouiS22 wrote:You have to submit the changes into ozw github. There's a detailed how-to on their github page.
I'll have a look at this when I have a few spare time, as this may prove useful to others even if this device still looks buggy on the relay control side (from z-wave, ok using ext pins), as the file is now on par with the device documentation.
As well, I didn't saw it at first sight, but energy counters are now reported with here-upper update but only under z-wave control panel. Domoticz does not seem to handle this kind of data. But only for checking from time to time, it's OK.
lost
Post by lost » Tuesday 16 May 2017 11:26
Was trying to figure-out how to submit this morning as I had some time... but to see someone (nechry) did the job 4 days ago:
https://github.com/OpenZWave/open-zwave ... MNHTDx.xml
This guy also removed this at the end:
<CommandClass id="96" mapping="endpoints" />
Don't know what this is supposed to do, indeed.
Users browsing this forum: No registered users and 4 guests
