Heating DZvents Multi Zone
Must be cleaned all topics go to the right subforum
dawsmac
Target OS: Raspberry Pi
Post by dawsmac » Thursday 19 January 2017 0:18
Hi not sure if any one can help I have tried to amending the heating script that I download from DZvents. but got a little stuck. am I doing this all wrong ?
Cheers
Rich
local BOILER_DEVICE = 'Boiler call' -- switch device
local TPV_DS = 'Downstairs Rad' -- Downstairs two port valve
local TPV_UP = 'Upstairs Rad' -- Upstairs two port valve
local SETPOINT_DS = 'Downstairs SetPoint' -- Upstairs rads
local SETPOINT_US = 'Upstairs SetPoint' -- Downstairs rads
local SETPOINT_UFH = 'UFH SetPoint' -- Under floor heating
local TEMPERATURE_DS = 'Downstairs Temperature' -- Upstairs Temp
local TEMPERATURE_US = 'Upstairs Temperature' -- Downstairs Temp
local TEMPERATURE_UFH = 'UFH Temperature' -- Under floor heating Temp
local HW_Thermostat = 'H/W Thermostat' -- Hot water Thermostat call
local HYSTERESIS = 0.5 -- temp has to drop this value below setpoint before boiler is on again
local SMOOTH_FACTOR = 3
local LOGGING = true
		['timer'] = 'every minute',
		SETPOINT_DS,
		SETPOINT_US,
		SETPOINT_UFH,
		TEMPERATURE_DS,
		TEMPERATURE_US,
		TEMPERATURE_UFH
	data = {
		temperatureReadings = { history = true, maxItems = SMOOTH_FACTOR }
	active = true,
	execute = function(domoticz, device, triggerInfo)
		local avgTemp
		local temperatureReadings = domoticz.data.temperatureReadings
		-- first check if the sensor got a new reading or the setpoint was changed:
		if (triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
			local sensor1 = domoticz.devices[TEMPERATURE_DS]
			local sensor2 = domoticz.devices[TEMPERATURE_US]
			local sensor3 = domoticz.devices[TEMPERATURE_UFH]
			if (sensor*.changed and sensor*.attributeChanged('temperature')) then
				-- sensor just reported a new reading
				-- add it to the readings table
				local current = sensor.temperature
				if (current ~= 0 and current ~= nil) then
					temperatureReadings.add(current)
					-- no need to be here, weird state detected
					domoticz.log('Strange sensor reading.. skiping', domoticz.LOG_ERROR)
					return
			elseif (domoticz.devices[SETPOINT_DEVICE].changed) then
				-- a new setpoint was set
				if LOGGING then domoticz.log('Setpoint was set to ' .. device.state) end
				-- no business here, bail out...
				return
		-- now determine what to do
		local boiler = domoticz.devices[BOILER_DEVICE]
		local setpoint = domoticz.devices[SETPOINT_DEVICE]
		if (setpoint.state == nil or setpoint.state == 'Off') then
			boiler.switchOff()
			return -- we're done here
		local setpointValue = tonumber(setpoint.state)
		-- determine at which temperature the boiler should be
		-- switched on
		local switchOnTemp = setpointValue - HYSTERESIS
		-- don't use the current reading but average it out over
		-- the past <SMOOTH_FACTOR> readings (data smoothing) to get rid of noise, wrong readings etc
		local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR)
		if LOGGING then
			domoticz.log('Average: ' .. avgTemp, domoticz.LOG_INFO)
			domoticz.log('Setpoint: ' .. setpointValue, domoticz.LOG_INFO)
			domoticz.log('Current boiler state: ' .. boiler.state, domoticz.LOG_INFO)
			domoticz.log('Switch-on temperature: ' .. switchOnTemp, domoticz.LOG_INFO)
		if (avgTemp >= setpointValue and boiler.state == 'On') then
			if LOGGING then domoticz.log('Target temperature reached, boiler off') end
			boiler.switchOff()
		if (avgTemp < setpointValue and boiler.state == 'Off') then
			if (avgTemp < switchOnTemp) then
				if LOGGING then domoticz.log('Heating is required, boiler switched on') end
				boiler.switchOn()
				if LOGGING then domoticz.log('Average temperature below setpoint but within hysteresis range, waiting for temperature to drop to ' .. switchOnTemp) end
elmortero
Domoticz version: 2.3852
Re: Heating DZvents Multi Zone
Post by elmortero » Thursday 19 January 2017 10:31
Do you get any errors in the log?
That sure would help us help you :-)
dawsmac
Post by dawsmac » Saturday 21 January 2017 17:43
Thanks elmortero...
As this is my 1st Lua script I thought it might be better to start a little simpler.. :) Below is the script but still getting error I have attached the logs also.
local TPV_Down = 'Downstairs_Rad' -- switch device
local SETPOINT_DEVICE = 'Downstairs SetPoint' -- selector dummy device
local TEMPERATURE_SENSOR = 'Downstairs Temperature'
local HYSTERESIS = 0.5 -- temp has to drop this value below setpoint before Downstairs_Rad is on again
TEMPERATURE_SENSOR,
SETPOINT_DEVICE
data = {
active = true,
local avgTemp
local sensor = domoticz.devices[TEMPERATURE_SENSOR]
if (sensor.changed and sensor.attributeChanged('temperature')) then
return
return
local Downstairs_Rad = domoticz.devices[TPV_UP]
Downstairs_Rad.switchOff()
-- determine at which temperature the Downstairs_Rad should be
-- switched on
if LOGGING then
domoticz.log('Current Downstairs_Rad state: ' .. Downstairs_Rad.state, domoticz.LOG_INFO)
if (avgTemp >= setpointValue and Downstairs_Rad.state == 'On') then
if LOGGING then domoticz.log('Target temperature reached, Downstairs_Rad off') end
if (avgTemp < setpointValue and Downstairs_Rad.state == 'Off') then
if LOGGING then domoticz.log('Heating is required, Downstairs_Rad switched on') end
Downstairs_Rad.switchOn()
-21 15:37:00.623 LUA: -----------------------------------------------------
2017-01-21 15:37:32.116 Under-floor Heating OFF
2017-01-21 15:37:32.516 Boiler Call ON
2017-01-21 15:37:32.520 Boiler Call OFF
2017-01-21 15:38:00.493 LUA: =====================================================
2017-01-21 15:38:00.493 LUA: >>> Handler: Downstairs_Rads
2017-01-21 15:38:00.493 LUA: .....................................................
2017-01-21 15:38:00.496 LUA: An error occured when calling event handler Downstairs_Rads
2017-01-21 15:38:00.497 LUA: /home/pi/domoticz/scripts/lua/scripts/Downstairs_Rads.lua:73: attempt to concatenate local 'avgTemp' (a nil value)
2017-01-21 15:38:00.498 LUA: .....................................................
2017-01-21 15:38:00.498 LUA: <<< Done
2017-01-21 15:38:00.498 LUA: -----------------------------------------------------
2017-01-21 15:39:00.362 LUA: =====================================================
2017-01-21 15:39:00.363 LUA: >>> Handler: Downstairs_Rads
2017-01-21 15:39:00.363 LUA: .....................................................
2017-01-21 15:39:00.366 LUA: An error occured when calling event handler Downstairs_Rads
2017-01-21 15:39:00.366 LUA: /home/pi/domoticz/scripts/lua/scripts/Downstairs_Rads.lua:73: attempt to concatenate local 'avgTemp' (a nil value)
2017-01-21 15:39:00.366 LUA: .....................................................
2017-01-21 15:39:00.366 LUA: <<< Done
2017-01-21 15:39:00.367 LUA: -----------------------------------------------------
elmortero
Post by elmortero » Sunday 22 January 2017 2:51
I think avgTemp is nil because the persitent variable 'temperatureReadings' is not being populated.
Can you check if the exact name of your temperature sensero is 'Downstairs Temperature'? Keep in mind that Lua is case sensitive..
Users browsing this forum: No registered users and 5 guests
