Assistance required getting energy script to work, split string
chrisfraser05
Post by chrisfraser05 » Tuesday 10 January 2017 12:54
Hi guys.
Hoping someone might be able to help me with my script. I've not really done much with LUA before but really need to start learning.
I've been pouring over the forum and I've started getting it working but I'm not quite there.
First the purpose of the script.
I want to read my owl energy meter each time it updates, then transfer the Power and Energy values to a dummy device on Vera.
I've created 3 user variables, "energy1", "PowerF" and "EnergyF"
The script updates the string "energy1" no problem. I have no errors in the log.
I am unsure how to split this string into the two seperate values for Power and KWH.
What I have done below simply does nothing.
I've tried quite a few different things but I'm just not getting it.
I've added in the url's with which I eventually want to send the values over to Vera, but at the moment my main focus is being able to see them in the user variables so I can understand what is going on.
Lastly, the values I read for example are "482.000;764578.875" the split is ;
so 482.000 is the power and 764578.875 is Energy. I would like to divide and round the energy value down to get it to 765 in this example.
Thanks in advance guys. :roll:
energyreading = "Energy Monitor"
if (devicechanged[energyreading]) then
   print( " ####watt debug: "..devicechanged[energyreading])
   commandArray['Variable:energy1']=tostring(devicechanged[energyreading])
  watt, kwh = energyreading:match("([^;]+);([^;]+)")
  commandArray['Variable:PowerF']=watt
  commandArray['Variable:EnergyF']=kwh
--http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=WATT&Value=..watt
--http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=KWH&Value=..kwh
elmortero
Target OS: Raspberry Pi
Domoticz version: 2.3852
Re: Assistance required getting energy script to work, split string
Post by elmortero » Tuesday 10 January 2017 13:09
I think this wiki page will show you how to do that (splitting the string):
https://www.domoticz.com/wiki/Capturing ... ua_Scripts
And for the rounding part :
viewtopic.php?t=7642
chrisfraser05
Post by chrisfraser05 » Tuesday 10 January 2017 17:12
Hi Elmortero.
Thanks for your reply!
I was using that first link last night to try and figure something out but it just wasn't sinking in.
I tried writing all sorts of variations on that and couldn't get anything to work.
elmortero
Post by elmortero » Tuesday 10 January 2017 17:49
try
watt, kwh = string.match(otherdevices_svalues['Energy Monitor'], "(%d+%.*%d*);(%d+%.*%d*)")
instead of
elmortero
Post by elmortero » Tuesday 10 January 2017 18:31
I have used that script long time ago and remember struggling quite a lot with it :-)
In the end it worked, but don't really remember quite how.
Short after that I moved to dzvents which has a lot of built-in functions for these kind of things.
your script could be something like:
    active = true,
        'Energy Monitor'
    execute = function(domoticz)
		local e-watts = domoticz.devices['Energy Monitor'].WActual
		local e-kwh= domoticz.devices['Energy Monitor'].WhTotal
domoticz.openUrl("http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=KWH&Value=" ..e-kwh)
domoticz.openUrl("http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=WATT&Value=" ..e-watts)
Have a look at it, it could be worth it.
chrisfraser05
Post by chrisfraser05 » Tuesday 10 January 2017 19:35
Thanks again for all your help.
We're cooking on gas.
I have the seperated values printing in the log now!
print( " ####combined debug: "..devicechanged[energyreading])
print( " ####splitwatts debug: "..watt)
print( " ####splitkwh debug: "..kwh)
So next I want to send the values (lets ignore the math for now).
I'm going to try and get that working.
chrisfraser05
Post by chrisfraser05 » Tuesday 10 January 2017 21:00
I'm getting somewhere now but....
I can have one URL call and it works. If I do two only the second works.
No errors in log!
commandArray['OpenURL']="http://192.168.1.12:3480/data_request?i ... tts&Value=" ..watt
-- commandArray['OpenURL']="http://192.168.1.12:3480/data_request?i ... KWH&Value=" ..kwh
Egregius
Post by Egregius » Tuesday 10 January 2017 21:25
Use 2 times os.execute with curl.
chrisfraser05
Post by chrisfraser05 » Tuesday 10 January 2017 22:17
Egregius.
Thanks for your post. I just had a quick read up on curl, funnily enough I found another thread where you are involved with curl.
I take it that involves installing curl onto the PC and putting it in the correct folder for it to be called in the script?
I'll do that later to make things nice and neat.
For the mean time I've just made two scripts, one for energy and one for power.
Imperihome rounds the values for display and on the graphs so I've divided the KWH reading but not bothered with rounding.
Thanks for both of your help. I'm learning now slowly!
chrisfraser05
Post by chrisfraser05 » Wednesday 11 January 2017 0:41
just for the fun of it I've offset the reading to match my Energy supplier meter to save me having to go to the cabinet to update my online billing
-- print( " ####combined debug: "..devicechanged[energyreading])
watt, kwhraw = string.match(otherdevices_svalues['Energy Monitor'], "(%d+%.*%d*);(%d+%.*%d*)")
kwhdiv = (kwhraw / 1000 )
kwh = (kwhdiv + 12553)
-- print( " ####splitkwh debug: "..kwh)
 commandArray['OpenURL']="http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=KWH&Value=" ..kwh
Nautilus
Post by Nautilus » Wednesday 11 January 2017 9:12
chrisfraser05 wrote:I'm getting somewhere now but....
No errors in log!
Do it like this and it should work without curl as well:
commandArray[#commandArray + 1] = {['OpenURL']="http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=Watts&Value=" ..watt}
commandArray[#commandArray + 1] = {['OpenURL']="http://192.168.1.12:3480/data_request?id=variableset&DeviceNum=271&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=KWH&Value=" ..kwh}
chrisfraser05
Post by chrisfraser05 » Thursday 12 January 2017 23:09
I'll give that one a go later. Thanks
