Find My iPhone implementation in LUA script
BluesBro
Re: Find My iPhone implementation in LUA script
Post by BluesBro » Friday 16 December 2016 14:35
Is there a way to make the script send this info instead:
json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=<iframe%20width="365"%20height="300"%20frameborder="0"%20style="border:0"%20src="https://www.google.com/maps/embed/v1/pl ... n></iframe>
Should pop up like the attached image if possible...
2016-12-16 13_33_56-Domoticz.png (81.73 KiB) Viewed 2504 times
Nautilus
Target OS: Raspberry Pi
Post by Nautilus » Friday 16 December 2016 14:49
BluesBro wrote:Is there a way to make the script send this info instead:
Yes, check my post on previous page: http://www.domoticz.com/forum/viewtopic ... 00#p107716
As I describe, having some weird issues with it while a family member was travelling, I'm now using just:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..string.gsub(address, ', Finland', '')..'</a><br>('..drivedistance..' / '..drivetime..')'
which gives the person's position as address which is a clickable link that opens in a new tab (or google maps app if browsing with phone). The drivedistance / drivetime variable I parse from google maps api to see the actual distance (not just the "direct line" distance) and the expected drivetime...
BluesBro
Post by BluesBro » Friday 16 December 2016 15:38
I get this error when using your code:
lua: script_time_checkphones.lua:52: bad argument #1 to 'gsub' (string expected, got function)
stack traceback:
[C]: in function 'gsub'
script_time_checkphones.lua:52: in main chunk
[C]: ?
Nautilus
Post by Nautilus » Friday 16 December 2016 15:52
stack traceback:
[C]: ?
I assume you are not parsing the drive time or distance, did you remove those? Do you get an error from:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..address..'</a>'
I've modified the original so much that I'm not exactly sure what needs to be changed in order to get this to work. The point is anyhow that just change the "position_text = ..." to your liking and "anything" is possible...:)
Edit: I checked the first post and yes, now "address" is a function and "position" the result. So you need to have something like:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(position, ' ','+')..'/@'..lat..','..lon..'">'..position..'</a>'
BluesBro
Post by BluesBro » Friday 16 December 2016 17:02
Thank you! It's working now :-)
pinda
Post by pinda » Monday 19 December 2016 11:18
edit: omg i switched the dummy switch and text name.....got it working now.
I'm doing this with almost zero script knowledge. So just followed the manual and tried some googling :)
Getting the following errors in domoticz on my synology nas. So any help would be welcome ;)
2016-12-19 10:05:01.658 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
2016-12-19 10:10:01.945 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
 -- Script to check the location of multiple iPhones every X minutes,
-- test if they are "home" and represent this using virtual switches
-- polling interval in minutes (1-59), setting this too low may drain the phones' batteries
interval = 5
local m = os.date('%M')
if (m % interval == 0) then
  json = (loadfile "XXXX PATH/JSON.lua")()
  -- Array of users to be checked
  users = {
            Tom = {username = 'XXXXXX@mail.com' ; password = 'XXXXXXXXXXX' ; devicename = 'XXXXXXXXX'};
  -- The latitude and longitude of your house (use Google Maps or similar to find this)
  homelongitude = XXXXXXXXXX
  homelatitude = XXXXXXXXXX
  -- Radius (in km) which will be used to determine if a device is at home
  radius = 5
  function address(longitude, latitude)
    command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false"
    local handle = io.popen(command)
    local result = handle:read("*a")
    handle:close()
    output = json:decode(result)
    return output.results[1].formatted_address
  for user,credentials in pairs(users) do
    stage1command = "curl -s -X POST -D - -o /dev/null -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
    local handle = io.popen(stage1command)
    handle:close()
    stage2server = string.match(result, "X%-Apple%-MMe%-Host%:%s(.*%.icloud%.com)")
    stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://" .. stage2server .. "/fmipservice/device/" .. credentials.username .."/initClient"
    local handle = io.popen(stage2command)
    handle:close()
    for key,value in pairs(output.content) do
      if value.name == credentials.devicename then
        lon = value.location.longitude
        lat = value.location.latitude
        distance = math.sqrt(((lon - homelongitude) * 111.320 * math.cos(math.rad(lat)))^2 + ((lat - homelatitude) * 110.547)^2)  -- approximation
        position = address(lon,lat)
        position_text = string.gsub(position, ', Netherlands', '') .. ' (' .. (math.floor(distance*10+0.5)/10) .. ' km)'
        prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)'
        prev_distance = tonumber(string.sub(prev_distance_str, 2,-5))
        -- update text device, but only if postion has changed more than defined in "radius" to reduce log size
        if math.abs(prev_distance - distance) > radius then
          table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['Position ' .. user] .. '|0|' .. position_text})
        --print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home')
        if distance < radius  then
          if otherdevices['iPhone ' .. user] == 'Off' then
            commandArray['iPhone ' .. user] = 'On'
            table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'})
          if otherdevices['iPhone ' .. user] == 'On' then
            commandArray['iPhone ' .. user] = 'Off'
            table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'})
fiscvs
Post by fiscvs » Monday 09 January 2017 19:14
i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home ;)
ben53252642
Post by ben53252642 » Monday 09 January 2017 21:32
mvzut, change this in your first post. It allows for names like:
Ben's iPhone
devicename = "Ben's iPhone"};
Specifically swap the '' for double "" around the device name.
mvzut
Post by mvzut » Monday 09 January 2017 21:45
fiscvs wrote:i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home ;)
Hmmm... that's strange. It should only change the value of the virtual switches to "On" if it was off, using the following statements:
End
What do you see in the logs, does it report successive "On"s every 5 minutes?
Raspberry Pi 2B - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Sonos Connect & PLAY:1 - Kodi - Wall mounted tablet + Imperihome - MANY switches/sensors
mvzut
Post by mvzut » Monday 09 January 2017 22:07
ben53252642 wrote:mvzut, change this in your first post. It allows for names like:
Ben's iPhone
Good suggestion, I updated the original post.
fiscvs
Post by fiscvs » Tuesday 10 January 2017 14:01
It seems the dummy switch doesnt toggle?
2017-01-10 12:50:02.175 LUA: Adress, Postcode, Netherlands
2017-01-10 12:50:03.665 EventSystem: Script event triggered: script_time_checkphones.lua
But the switch is not flipped. If i do it manually then the notification stops..
What have i forgotten?
blindlight
Post by blindlight » Wednesday 11 January 2017 17:31
Great script!!
I've got it working.....for almost 48h
but i get an error this morning.
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:40: attempt to concatenate global 'stage2server' (a nil value)
so i put print(result) right before stage2server = string.match(.....) to see what stage1command gets. here's what log shows:
LUA: HTTP/1.1 200 OK
Server: AppleHttpServer/3b804a0
Date: Wed, 11 Jan 2017 15:23:02 GMT
Content-Type: application/json;charset=UTF-8
Transfer-Encoding: chunked
X-Responding-Instance: fmipservice:10200801:st11p02me-fmipservice008:8001:16H103:2cc8f06
X-Responding-Server: st11p02me-fmipservice008_001
X-Responding-Partition: p02
Vary: Accept-Encoding
Strict-Transport-Security: max-age=31536000; includeSubDomains
Set-Cookie: NSC_q02-gnjqtfswjdf=ffffffff12a4c85645525d5f4f58455e445a4a422971;path=/;secure;httponly
via: icloudedge:hk03p01ic-zteu010412:7402:16G41:Hong Kong
X-Apple-Request-UUID: a82b2ad2-6903-4d6c-91ca-80e675c434c0
access-control-expose-headers: X-Apple-Request-UUID
access-control-expose-headers: Via
i see there's no "X-Apple-MMe-Host" in the result. maybe that's the reason stage2server is a nil.
so why suddenly it doesn't work? can anyone show me a correct response of stage1command?(maybe statue 200 is not ok?)
thx a lot!
Egregius
Post by Egregius » Wednesday 11 January 2017 17:34
I think Apple changed something yesterday or today.
There are also replies about not functioning anymore on the PHP implementation on Github.
Nautilus
Post by Nautilus » Thursday 12 January 2017 14:32
If someone has access to Vera plugins there seems to be a fix available already:
http://forum.micasaverde.com/index.php/ ... #msg306362
http://forum.micasaverde.com/index.php/ ... 7.885.html
Was not able to find a source for those anywhere, though, so I guess you need to have Vera to be able to download and use (them and hopefully see what they contain?)...
redina
Post by redina » Thursday 12 January 2017 14:50
They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Remove stage1Command (to find server) and call the generic server directly: fmipmobile.icloud.com
Snippet:
    stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
    handle:close()
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL » Thursday 12 January 2017 15:05
Yes!
Changed
Into
stage2server = "fmipmobile.icloud.com"
And it works again!
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
Nautilus
Post by Nautilus » Thursday 12 January 2017 23:23
redina wrote:They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Thanks! :)
Out of curiosity - is the Vera source (for plugins at least) available somewhere or did you find this out from somewhere else?
redina
Post by redina » Friday 13 January 2017 8:33
I just tested and saw that it's returning the data in the first call.
ropske
Domoticz version: V3_8394
Post by ropske » Friday 13 January 2017 10:28
stack traceback:
[C]: ?
Hi Nautilus,
thanks for this script!
One question: is the link made where you can see your devices?
Because there i cannot click anythone that opens this 'map'
In my domoticz log i get a link and i can click it.
Am i doing something wrong?
Thanks :D
Nautilus
Post by Nautilus » Friday 13 January 2017 10:48
ropske wrote:
Hi Nautilus,
Thanks :D
not sure if I quite understand the question :) What do you mean with Domoticz log? There are two things updated with the script, the On/Off switch which only gives the status whether the phone is at home or not (i.e. no links there) and then the "text sensor" that shows the current position as text. And this text you can format into a clickable link as well as discussed earlier in this thread.
Maybe you have some debug setting on that writes the text sensor value to log as well, but the sensor itself (once you create it) is found on the Utility tab (add as favorite to see it on the Dashboard)...
