Pemoticz: Control Domoticz from your Pebble
KixAss
Post by KixAss » Friday 18 December 2015 14:44
I created a small app to control your Domoticz-system from your Pebble watch.
This is a first test-version to control scenes. In the next version it will also be possible to control switches and temperatures.
Url: https://apps.getpebble.com/applications ... 3b8f000010
voorstad
Target OS: Raspberry Pi
Re: Pemoticz: Control Domoticz from your Pebble
Post by voorstad » Friday 18 December 2015 15:24
Great idea! Installed it, configured it with both ip and ip:port, but nothing is displayed on the Pebble. Smartphone can connect. Do I miss something?
KixAss
Post by KixAss » Friday 18 December 2015 17:40
Have you entered an internal or external ip-address, and did you include http:// in front and a / after?
voorstad
Post by voorstad » Friday 18 December 2015 21:05
http://192.168.1.110:8080/
Is what I entered. I do not have a user/pw protection.
Pasting The exact same in my browser shows the site.
KixAss
Post by KixAss » Friday 18 December 2015 21:06
Strage, should work. I'll make a better errorhandler and post here when its done.
KixAss
Post by KixAss » Friday 18 December 2015 22:04
Could you try again? First to the settings, then Save and then restart the app.
voorstad
Post by voorstad » Saturday 19 December 2015 0:37
No luck.... I rebooted The Pebble even.
KixAss
Post by KixAss » Saturday 19 December 2015 12:06
Just made version 1.1. Could you update and try again?
voorstad
Post by voorstad » Sunday 20 December 2015 0:46
Thanks! But no luck.
Uninstalled it and reinstalled... No change.
When I switch off my wifi, app reads "Error Connecting". With wifi on, nothing appears.
I removed all items but one switch from my dashboard... No change.
KixAss
Post by KixAss » Sunday 20 December 2015 9:34
Have you got any scenes in your installation?
voorstad
Post by voorstad » Sunday 20 December 2015 15:58
That did the trick! Adding a test scene and now all switches are shown!
philipgoodfellow
Post by philipgoodfellow » Monday 28 December 2015 19:08
I have installed Pemoticz. I have entered my Domoticz url as:
https://192.168.0.15:443/ (I also tried without the :port)
All I get on the pebble is Error Connecting: 0
All I can think of is you are not supporting https: Am I right?
It is good to see a pebble domoticz app (even if it does not yet work for me).
Philip.
KixAss
Post by KixAss » Tuesday 29 December 2015 14:52
It should work. Are you using an official certificate, or a self-signed?
goncaloazevedo
Post by goncaloazevedo » Tuesday 29 December 2015 14:57
Is compatible with time round?
philipgoodfellow
Post by philipgoodfellow » Tuesday 29 December 2015 16:51
KixAss wrote:It should work. Are you using an official certificate, or a self-signed?
It is the "self signed" certificate that is installed by the Domoticz installation. It describes itself as "Issued to: Raspberry.local Issued By: Domoticz CA"
KixAss
Post by KixAss » Tuesday 29 December 2015 16:54
Then I think that's the problem. Other problem is that I don't have control over the certificates (which should be accepted and which shouldn't). You could try to add the certificate to your phone, maybe then it will be accepted.
Egregius
Post by Egregius » Thursday 24 March 2016 16:53
Just received my Pebble Time and installed your app. Worked instantly :)
Maybe a tip: possibility to use a roomplan.
In a roomplan you can select switches, that way it could be a short list on the pebble. Now it's a list of > 50 devices wich is quite huge to browse on such a small screen.
Egregius
Post by Egregius » Thursday 24 March 2016 17:49
Sorry, will use the HTTP Push app.
I need to be able to send update commands for switches that can't be switched...
knielen
Post by knielen » Sunday 10 September 2017 9:47
Hi KixAss,
this app looks great, but doesn't support the Pebble Time Round yet. Is it much work to make an update?
Verstuurd vanaf mijn XT1562 met Tapatalk
