[MyDomoAtHome] Bêta version in nodeJS Topic is solved
epierre
Post by epierre » Monday 16 November 2015 23:14
DEBIAN PACKAGE:
an betaversion as a debian package on Raspbian (no automatic startup yet), works well on debian.
http://www.e-nef.com/domoticz/mdah/node ... latest.deb
==>> SEE HERE FOR INSTALLATION: https://github.com/empierre/MyDomoAtHome/tree/nodejs
on Raspbian, please install first to have a stable nodeJS :
http://www.e-nef.com/domoticz/mdah/npm_2.14.7_armhf.deb
http://www.e-nef.com/domoticz/mdah/node ... _armhf.deb
on all other, version 4 is required (testing/unstable are fine):
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
you need to edit /etc/mydomoathome/config.json containing(change your ip !):
  "app_name": "MyDomoAtHome",
  "domo_path": "http://192.168.0.28:8080",
  "port": "3002"
it runs on port 3002 and App name is "MyDomoAtHome Dev", so you can run legacy and beta at the same time.
FYI new install is in /usr/share/mydomoathome/
TESTING/SUPPORT:
preffered method: https://mydomoathome.slack.com/messages ... s-testing/
==> Please mail me on [email protected] with your email to get an invite
SYNOLOGY PACKAGE:
a very alpha alpha version as a debian package (NOT TESTED):
https://github.com/empierre/MyDomoAtHom ... noarch.spk
UPDATES:
- faster than the legacy perl dancer on a pi B
- sorted out the armv6 nodejs situation (raspbian is compiled for armv6 and works for armv7 too (not the opposite)), specific packages needed available here: http://www.e-nef.com/domoticz/mdah/
- all is there except graphes
CURRENT ISSUES:
- debian package: auto startup ok
- Docker to be tested
- graphs not yet implemented
- synology package: first untested version for all arch
- synology: define where to place configuration file
- have the package hosted on raspian archive
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Re: [MyDomoAtHome] Bêta tests
Post by epierre » Monday 16 November 2015 23:17
current issues:
- dependencies not installed
- run on startup ?
epierre
Post by epierre » Friday 20 November 2015 23:52
updates:
- sorted out the armv6 nodejs situation (raspbian is compiled for armv6 and works for armv7 too (not the opposite)), specific packages needed available here: https://github.com/empierre/MyDomoAtHom ... ejs/binary
current issues:
- debian package: auto startup not possible as is on wheezy class raspbian
- actions/graphs not yet implemented
- synology package: first untested version for armada375
kinghuzi
Post by kinghuzi » Saturday 21 November 2015 16:40
Hi.. can you add x86 support for syno spk
epierre
Post by epierre » Saturday 21 November 2015 17:25
kinghuzi wrote:Hi.. can you add x86 support for syno spk
I will, but since I do it manually I add the architecture manually... what is you so I make it ?
jumbotroll
Post by jumbotroll » Saturday 21 November 2015 18:48
You can use:
arch="noarch"
and it's arch independent
Jumbotroll
http://www.jadahl.com
epierre
Post by epierre » Saturday 21 November 2015 19:02
jumbotroll wrote: You can use:
arch="noarch"
Thanks Jumbotroll, it is done !
epierre
Post by epierre » Tuesday 24 November 2015 15:10
@kinghuzi @jumbotroll have you tested it yet ?
raym
Re: [MyDomoAtHome] Bêta version in nodeJS
Post by raym » Sunday 20 December 2015 17:48
Hi epierre, will this nodejs version eventually replace the existing mdah version? If so, am I able to test on Ubuntu?
epierre
Post by epierre » Sunday 20 December 2015 18:13
raym wrote:Hi epierre, will this nodejs version eventually replace the existing mdah version? If so, am I able to test on Ubuntu?
yes it will, I've not yet finished, others things went in the middle... too much time one one thing and many solicitations and in the end priority management :D
you can test it, it covers all information but does not yet manages actions (no switches, no graphs...). I still have not tested whether it works fine on raspbian (non systemd), but on ubuntu it is fine !
deennoo
Post by deennoo » Sunday 20 December 2015 18:47
Thx for this, which nodejs did you use ?
What about homebridge from sdcard img who need node 0.12.1?.
As it tooks me 3 mounth to make it finally works, i dont want to break it by updating MDAH.
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
epierre
Post by epierre » Sunday 20 December 2015 18:51
if you have nodejs 0.10 nothing to change, only raspbian is on.0.6 and is thus broken for everything...
raym
Post by raym » Sunday 20 December 2015 22:46
Thanks for your reply. It sounds exciting and I look forward to testing soon.
Where can I find the install procedure for Ubuntu and similar?
Thanks again.
epierre
Post by epierre » Monday 22 February 2016 15:14
Hi All,
I've restarted yesterday, .deb not updated, but on/off is tested working.
epierre
Post by epierre » Monday 22 February 2016 23:47
version 0.0.13 is open for testing, no graphes though...
modify the config file as fitted, report bugs to github, and discussion here !
epierre
Post by epierre » Friday 26 February 2016 14:32
version 0.0.14 is open for testing, no graphes yes.
Debian package available.
epierre
Post by epierre » Saturday 27 February 2016 23:19
0.0.15 tested working on debian with systemd
deennoo
Post by deennoo » Sunday 28 February 2016 0:37
Have you try it on a regular Synologie ? Dunning DMS 5
epierre
Post by epierre » Sunday 28 February 2016 10:16
@deenoo it will, it was too high a target to start, so I prefer to make it more MVP and then extend si ut will be tested first before expending.
also syno has more needs, you don't mess with its filesystem... so specific strategy for it to be done
deennoo
Post by deennoo » Sunday 28 February 2016 10:22
OK !
Just start an xpenology before purchase a real syno, i saw that be can made a debian chroot part. Homebridge can be set and running on it, so i was hoping doing the same for MDAH.
