Telegram custom keyboards
bigpea
Target OS: Raspberry Pi
Post by bigpea » Tuesday 17 October 2017 16:29
I'm trying to create a custom keyboard with telegram in order to have a simple way to do more action.
Like this (detail: https://core.telegram.org/bots#keyboards):
In detail if I use this link to send a message all works fine:
https://api.telegram.org/botMyToken/sendMessage?chat_id=myId&text=test
But if I try to add the custom keuboard with this URL (adding only this part "&reply_markup={"keyboard":[[{%20text:%20"Si"%20}]]}"):
https://api.telegram.org/botMyToken/sendMessage?chat_id=myId&text=test&reply_markup={"keyboard":[[{%20text:%20"Si"%20}]]}
I receive this error:
{"ok":false,"error_code":400,"description":"Bad Request: can't parse reply keyboard markup JSON object"}
I tryied also with serialized JSON but the result is the same.
Somebody use this function in telegram?
Thanks.
jvdz
Domoticz version: Stable
Re: Telegram custom keyboards
Post by jvdz » Tuesday 17 October 2017 16:43
You mean like this?
http://www.domoticz.com/forum/viewtopic ... enu#p52245
This is implemented in DTGBOT. ;)
Jos
bigpea
Post by bigpea » Tuesday 17 October 2017 17:20
yes, I had seen this script, but I just wanted to have the correct url string.
But in the code you indicated I can not find the url track.
jvdz
Post by jvdz » Tuesday 17 October 2017 17:48
There is no one single answer to your question as it depends on the functionality you want but generically this is the format i've used:
reply_markup={"keyboard":[["opt 1","opt 2","opt 3"],["menu"]],"resize_keyboard":true}
The url syntax is defined in the telegram website and I've used that to develop all LUA script functions: https://core.telegram.org/bots/api#replykeyboardmarkup
There is also a version of DTGBOT available that uses the inline keyboard option.
Jos
bigpea
Post by bigpea » Tuesday 17 October 2017 17:55
The inline version works fine, for example:
https://api.telegram.org/bot/sendMessag ... e_keyboard":[[{"text":"Visualizza spoiler!","url":"http://google.com/"}]]}
But when I try a replykeyboardmarkup, for example your url I receive this error:
{"ok":false,"error_code":400,"description":"Bad Request: inline keyboard expected"}
jvdz
Post by jvdz » Tuesday 17 October 2017 18:17
Show me the total URL (without the personal info like API key) so I can have a look please.
Jos
bigpea
Post by bigpea » Wednesday 18 October 2017 9:34
Yes, sure, the link is:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[[{"Yes"}],[{"No"}]]}
jvdz
Post by jvdz » Wednesday 18 October 2017 9:39
I can't test it untill the evening, but shouldn't that be like this?:
https://api.telegram.org/botToken/sendMessage?chat_id=-1&text=Choose&reply_markup={"keyboard":[["Yes"],["No"]]}
Jos
bigpea
Post by bigpea » Wednesday 18 October 2017 10:15
The message is sent but the keyboard not appear.
jvdz
Post by jvdz » Wednesday 18 October 2017 19:33
Just tried your modified command from my previous post with only putting in my bottoken and chat_ID and it shows the Yes/No buttons nicely underneath each other.
Not sure why it doesn't for you.
Jos
bigpea
Post by bigpea » Thursday 19 October 2017 19:10
I have am IPhone, and you? Maine the problem is this.
jvdz
Post by jvdz » Thursday 19 October 2017 19:36
I opened the URL to send the telegram in a Chrome browser on my win10 laptop and run Telegram on multiple platforms, but honestly that shouldn't really matter I would think.
Jos
bigpea
Post by bigpea » Thursday 19 October 2017 21:09
Mmhh ok I will try tomorrow. Thanks for your time.
