Gearoticz | Galaxy Watch, Gear S3 and S2 Tizen implementation
ehallq
Re: Gearoticz | Gear S3 and S2 Tizen implementation
Post by ehallq » Tuesday 16 January 2018 18:20
xavier1306 wrote:
Tuesday 16 January 2018 18:11
Thanks for the answer. But that is what i did :(
I'll keep trying
Envoyé de mon MI 5s en utilisant Tapatalk
Hmm, in your browser, try to go to
https://username:password@IP:Port/json.htm?type=devices&filter=light&used=true&order=Name
This is the request that the watch does basically. If you dont get an answer similar to below from this, then something is wrong with your settings:
"result" : [
"IsDimmer" : false,
"Name" : "Bedroom lights",
"SubType" : "Energenie",
"Type" : "Lighting 1",
"idx" : "43"
"IsDimmer" : false,
"Name" : "Hall",
"Type" : "Lighting
It shouldnt be a problem, but I havent tested it butif you have a custom HTTPS port, try changing it to the standardport 443 on your domoticz setup.
ehallq
Post by ehallq » Tuesday 16 January 2018 18:35
vidjer wrote:
Wednesday 27 December 2017 10:09
vidjer wrote:I just bought the app on Galaxy App. It's very frustrating to have nothing functional. Thank you for doing the best.
Envoyé de mon SM-G935F en utilisant Tapatalk
Hello
I do reset. Reinstall all soft.
Now I can see devices.
Temperature looks like switch. Swith too.... But no effect! I test in http and https. I test on stable and beta server. I have 2 domoticz server.
Help please
Thank's ImageImage
Hi again, the solution I wrote in the first answer to you is still valid. However, I noticed that you for some reason doesnt run the updated app. The menus should be blue, like my pictures above your post. Version should be 1.2.0 if you check the store.
xavier1306
Post by xavier1306 » Tuesday 16 January 2018 18:56
I'll keep trying
"result" : [
"IsDimmer" : false,
"idx" : "43"
"IsDimmer" : false,
"Name" : "Hall",
"Type" : "Lighting
For some reason it works now ImageImageImage
Is there a possibility to decrease the font size in gearoticz ?
I have configured my Gear S3 to the smallest font, but gearoticz is still far to Big to properly display the labels of my switches
skybehind
Target OS: Raspberry Pi
Post by skybehind » Thursday 18 January 2018 1:34
ehallq wrote:
skybehind wrote:
Wednesday 27 December 2017 2:23
Got one for Christmas, first app I looked for was Domoticz, lol. Was happy to see it existed. So I added server and got it working, so far so good.
Question, can we add by domain name or is address only? Domain would be beneficial when not at home and in the case of dynamic is.
Sent from my Nexus 6 using Tapatalk
xavier1306 wrote:
Tuesday 16 January 2018 18:04
Hi Ehallq
I dis not see the answer regarding the fact of using domain name instead of IP in the server parameters.
For those who dont have a fixed IP, this is a must when outside the house wifi...
I can easily access to domoticz with any brother using https://mydomainname:myport but it does not work with gearoticz.
Any idea?
I use a domain instead of IP for Gearoticz, and it works. You shouldnt enter https://mydomainname:myport in the IP field
Since you use SSL (HTTPS)
You should have the following settings:
IP: mydomainname
Port: myport
User: username
Password: password
HTTPS?: yes
In my case I navigate to https://www.mydomain.com
Then
IP: www.mydomain.com
Port: 443
HTTPS?: yes
I did what was instructed for the domain, port, etc. I am behind a reverse proxy, which may be the reason why this doesn't work. Are there any settings that need to be accounted for in an nginx configuration (i.e. forwarding headers, etc.)?
domoticzba
Post by domoticzba » Friday 29 June 2018 19:13
I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
denman091
Domoticz version: 3.8153
Post by denman091 » Tuesday 17 July 2018 23:36
domoticzba wrote:I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
Have the same problem
domoticzba
Post by domoticzba » Friday 20 July 2018 19:33
Nobody Knows ?
denman091
Post by denman091 » Thursday 09 August 2018 7:03
Nobody Knows ?
I found it a few days ago. I've searched for gearoticz and first there were no search result. But you have two types of stores, one for dials and one for apps. By default you only search in the dials section. Select apps and you wil find the app
sonar
Post by sonar » Friday 07 September 2018 21:46
Hi Ehallq,
I have added blinds and a sunscreen to my domoticz.
If I add these as switches I can only switch them on or off.
It would be nice if there was an option like in the web interface -> up - stop - down.
Including the current state.
Can you add support to your gear app?
Ewaldharmsen
Post by Ewaldharmsen » Friday 02 November 2018 10:02
I am in the Netherlands, just got a Galaxy Watch yesterday. The first thing I wanted to do is install gearoticz. But I can't find it in the App Store. Is it still available?
ehallq
Post by ehallq » Thursday 08 November 2018 22:59
Hi Ehallq,
Hi!
Sorry for late response, I am not visiting this forum that much these days, but I will try to get better. Also I will try to make an update for the app with some small fixes. Like making the app updating the status of the switches without closing and opening the app, and add support for locks in a nicer way other than ordinary switches.
About blinds, I might be able to add that later on in that update. I don't have any blinds myself, but I could always try it with a dummy switch :)
About the app, yes it should be available, however it costs 1$, which might make it hidden for some countries. But Netherlands should definitely find it. Be sure that you are under the watch category in the galaxy app store. Also I don't have the Galaxy Watch, so not sure if that watch is supported, and if that could make it hard for you to find it on the app store. But my guess is that the app should be supported by all round samsung watches. I have no plan to buy the Galaxy Watch currently, mostly due to that I find it to expensive, when I currently have the Gear S3 :roll:
EDIT: A friend have the Galaxy Watch and we were able to download it. However, the app doesnt appear in the app store on the watch. You need to use the phone to find the app.
dise
Re: Gearoticz | Galaxy Watch, Gear S3 and S2 Tizen implementation
Post by dise » Monday 12 November 2018 15:43
Dear Collegues, is there any possibility to use this ap on Xiaomi Amazfit Stratos 2 ?
