Control Domoticz using Harmony Hub and HA Bridge
bellissimo
Target OS: Raspberry Pi
Re: Control Domoticz using Harmony Hub and HA Bridge
Post by bellissimo » Saturday 05 November 2016 12:44
Got the Ha-Bridge set up now and it is controlling all my Harmony activities and some of the my Domoticz switches.
However I can't seem to get the dimming working. I see there is a 'Dim URL', which does not seem to handle a variable dim level (?) but I did try adding the following url to get it to dim to 50%
http://192.168.0.99:8080/json.htm?type=command&param=switchlight&idx=44&switchcmd=Set%20Level&level=50
However pressing on 'Test Dim' does not seem to do anything and nothing appears in the Domoticz logs.
Has anyone got this working with a dimmer in Domoticz and if so could they post how they configured it?
bellissimo
Post by bellissimo » Saturday 05 November 2016 13:27
D'oh. Should have read the manual. For others information, the following is required for dimming:
http://192.168.0.99:8080/json.htm?type=command&param=switchlight&idx=44&switchcmd=Set%20Level&level=${intensity.percent}
Thomasdc
Post by Thomasdc » Friday 23 December 2016 12:58
remb0 wrote:Can somebody add a nice instruction to the wiki (same username and password)
Is someone working on this? i would like to try this HA bridge out in my setup!
it would be great to just see how to install and configure and integrate this on one page instead of scrolling through the forum :)
StanHD
Re: RE: Re: Control Domoticz using Harmony Hub and HA Bridge
Post by StanHD » Friday 23 December 2016 13:02
Have a look here. Worked fine for me. Image Image
https://www.domoticz.com/wiki/Alexa
Domoticz Slave - Asrock Ion - Linux, Python:- Broadlink RM2, Sonos
doh
Post by doh » Monday 09 January 2017 13:26
I'm using HABridge with my Echo and it's working fine. I'm trying to use it to add devices to my Harmony Hub so that when I start my TV it can also power-on some LED backlights, etc. The Harmony finds the HA Bridge as a Hue device and adds it, but it only seems to add one device out of the 17 I have in there. Any ideas how to get this to detect all the devices in there? Thanks
StanHD
Post by StanHD » Monday 09 January 2017 13:44
Not sure if this helps, but I do it slightly differently:-
I have added the Harmony Hub hardware to Domoticz. This gives me a switch for each "activity" plus "power off".
I then use a simple blockley to call a lighting scene and other switches when "Watch TV" is on.
So when I say:- "Alexa, turn on Watch TV", the HA-Bridge tells the harmony hub what to do, and Domoticz detects the harmony activity and sorts the lights out. ;)
doh
Post by doh » Monday 09 January 2017 13:52
doh wrote:I'm using HABridge with my Echo and it's working fine. I'm trying to use it to add devices to my Harmony Hub so that when I start my TV it can also power-on some LED backlights, etc. The Harmony finds the HA Bridge as a Hue device and adds it, but it only seems to add one device out of the 17 I have in there. Any ideas how to get this to detect all the devices in there? Thanks
Never mind - figured it out. I had created multiple switches as copies and updated the URL's, but they all had the same Hue ID so it only kept the last one it found. I've re-created them and they're all now visible.
Thomasdc
Post by Thomasdc » Monday 09 January 2017 14:03
Can someone explain how to ad 'devices ' in the ha bridge?
i use 'manual add' in the web interface from habridge
this is selected:
Target - Encapsulated
Device Type - Custom
Map Type - --Please Select--
then a use a json link ( its working from my browser)
but when i juse the 'test on' and 'test off' its not working..
do i need to do something more?
the http header and verb i dont need to use do i?
the habridge is running on the same rpi as domoticz (other port off course) i dont need to use 'localhost' instead of the rpi ip adress? (ive tried this, but this is not working neither)
or are there some divices that ar not supported? now i've id (in the json link) from an rfx dimmer (but i only use the on and off commando to test.. but without result.
StanHD
Post by StanHD » Monday 09 January 2017 14:21
Thomasdc wrote:Can someone explain how to ad 'devices ' in the ha bridge?
this is selected:
That all looks ok. I am using LightwaveRF dimmers with RFX, here are my working JSON URL's:-
On URL:-http://IP:PORT/json.htm?type=command&param=switchlight&idx=IDX&switchcmd=On
Off URL:-http://IP:PORT/json.htm?type=command&param=switchlight&idx=IDX&switchcmd=Off
Use your IP:PORT and idx and watch out for case sensative On & Off
Do you get an error message from the HA-Bridge when you test?
Thomasdc
Post by Thomasdc » Monday 09 January 2017 21:21
this is selected:
this is the error i get:
Request Error, Pleae look in your habridge log: error {"type":6,"address":"/lights/6","description":"Error on calling url to change device state","parameter":"/lights/6state"
Thomasdc
Post by Thomasdc » Friday 27 January 2017 23:18
i got it working
there was a setting not right (UPNP IP Address in the web interface was wrong)
but now i have an other question...
i want to change the default port to port '80' (because thats the only way to let it work with google home)
but wen i use the command:
sudo java -jar -Dserver.port=80 ha-bridge-3.5.1.jar
this happens:
pi@raspberrypi:~/habridge$ sudo java -jar -Dserver.port=80 ha-bridge-3.5.1.jar
2017-01-27 22:07:20,061 [main] INFO  com.bwssystems.HABridge.HABridge - HA Bridg        e (v3.5.1) starting....
2017-01-27 22:07:20,179 [main] INFO  com.bwssystems.HABridge.BridgeSettings - re        ading from config file: data/habridge.config
2017-01-27 22:07:20,600 [main] INFO  com.bwssystems.HABridge.HABridge - HA Bridg        e initializing....
2017-01-27 22:07:20,702 [main] INFO  com.bwssystems.HABridge.SystemControl - Sys        tem control service started....
2017-01-27 22:07:21.342:INFO::Thread-0: Logging initialized @4038ms
2017-01-27 22:07:21,864 [Thread-0] INFO  spark.webserver.JettySparkServer - == S        park has ignited ...
2017-01-27 22:07:21,875 [Thread-0] INFO  spark.webserver.JettySparkServer - >> L        istening on 0.0.0.0:80
2017-01-27 22:07:21.894:INFO:oejs.Server:Thread-0: jetty-9.3.z-SNAPSHOT
2017-01-27 22:07:22.262:INFO:oejs.ServerConnector:Thread-0: Started ServerConnec        tor@1476d3d{HTTP/1.1,[http/1.1]}{0.0.0.0:80}
2017-01-27 22:07:22.269:INFO:oejs.Server:Thread-0: Started @4983ms
2017-01-27 22:07:23,198 [main] INFO  com.bwssystems.harmony.HarmonyServer - setu        p initiated ....
2017-01-27 22:07:26,342 [main] ERROR com.bwssystems.harmony.HarmonyHome - Cannot        get harmony client (Harmony) setup, Exiting with message: Failed communicating        with Harmony Hub
java.lang.RuntimeException: Failed communicating with Harmony Hub
        at net.whistlingfish.harmony.HarmonyClient.connect(HarmonyClient.java:17        9)
        at com.bwssystems.harmony.HarmonyServer.execute(HarmonyServer.java:78)
        at com.bwssystems.harmony.HarmonyServer.setup(HarmonyServer.java:50)
        at com.bwssystems.harmony.HarmonyHome.<init>(HarmonyHome.java:45)
        at com.bwssystems.HABridge.HABridge.main(HABridge.java:70)
Caused by: org.jivesoftware.smack.SmackException$ConnectionException: null
        at org.jivesoftware.smack.tcp.XMPPTCPConnection.connectUsingConfiguratio        n(XMPPTCPConnection.java:433)
        at org.jivesoftware.smack.tcp.XMPPTCPConnection.connectInternal(XMPPTCPC        onnection.java:808)
        at org.jivesoftware.smack.XMPPConnection.connect(XMPPConnection.java:396        )
        at net.whistlingfish.harmony.HarmonyClient.connect(HarmonyClient.java:11        5)
        ... 4 common frames omitted
2017-01-27 22:07:26,464 [main] INFO  com.bwssystems.HABridge.devicemanagmeent.De        viceResource - HABridge device management service started....
2017-01-27 22:07:26,537 [main] INFO  com.bwssystems.HABridge.upnp.UpnpSettingsRe        source - Hue description service started....
2017-01-27 22:07:26,551 [main] INFO  com.bwssystems.util.UDPDatagramSender - Ini        tializing UDP response Seocket...
2017-01-27 22:07:26,567 [main] INFO  com.bwssystems.util.UDPDatagramSender - UDP        response Seocket initialized to: 50000
2017-01-27 22:07:28,223 [main] INFO  com.bwssystems.HABridge.hue.HueMulator - Hu        e emulator service started....
2017-01-27 22:07:28,277 [main] INFO  com.bwssystems.HABridge.upnp.UpnpListener -        UPNP Discovery Listener starting....
2017-01-27 22:07:28,283 [main] INFO  com.bwssystems.HABridge.upnp.UpnpListener -        UPNP Discovery Listener running and ready....
and then it all works (habridge is running on port 80)
but..
as long i keep running putty it works, but when i close putty, or use 'Control + C' to end the action (because it doesnt end on its own for some reason?) then it is not running on port 80 anymore...
jeroenvanpelt
Domoticz version: 3.8153
Post by jeroenvanpelt » Saturday 28 January 2017 9:20
Check the readme at:
https://github.com/bwssytems/ha-bridge/ ... ge-on-a-pi
It tells you how to use a simple starthabridge.sh script to start ha-bridge and keep it running. If you want ha-bridge to run on port 80, you may also just configure that under the "Bridge Control" tab. After saving the new config, and restarting ha-bridge, you will find it will listen on port 80 by default.
BTW, I also noticed you're running an older version of ha-bridge. You might want to consider downloading v4.1.0 at:
https://github.com/bwssytems/ha-bridge/ ... -4.1.0.jar
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
Thomasdc
Post by Thomasdc » Sunday 29 January 2017 20:47
jeroenvanpelt wrote:Check the readme at:
in the new version (4.1.0) you can add 'Domoticz Names and IP Addresses"
when i do that, and i save it.. then i look again in that page.. but it isn't there anymore?
i get this in the log:
01-29-2017 19:41:42.508	INFO	Domoticz Home created. No Domoticz devices configured.	com.bwssystems.HABridge.plugins.domoticz.DomoticzHome
01-29-2017 19:41:42.510	WARN	Error reading the file: data/device.db - Does not exist or is not readable. continuing...	com.bwssystems.HABridge.dao.DeviceRepository
01-29-2017 19:41:42.511	INFO	HABridge device management service started....	com.bwssystems.HABridge.devicemanagmeent.DeviceResource
jeroenvanpelt
Post by jeroenvanpelt » Sunday 29 January 2017 21:04
The UI of ha-bridge is a bit confusing. When you enter all the Domoticz information, you need to click the green "Add" button on the right (next to the line you just added information on) to add the Domoticz information and then click the "Save" button at the top of the settings page in ha-bridge. Same goes for adding action for ha-bridge devices.
Thomasdc
Post by Thomasdc » Sunday 29 January 2017 21:19
jeroenvanpelt wrote:The UI of ha-bridge is a bit confusing. When you enter all the Domoticz information, you need to click the green "Add" button on the right (next to the line you just added information on) to add the Domoticz information and then click the "Save" button at the top of the settings page in ha-bridge. Same goes for adding action for ha-bridge devices.
yeah i did that,
i also tried it for adding the Harmony hub.. but everytime (after i added it (domoticz/harmony) and saved it) it wasnt there anymore after it saved an reinitilazed..
can it be that it uses an old config file or something (from the previous version?) instad of the new one after reinitialzing or something?
why do i think that?
--> there was an harmony device device allready in it (my harmony with the old ip adress) , i deleted this, and added the harmony with the new ip adresss and saved.. but then the new one was gone, an the old one was there again..
so what i did then was (with putty) i opened:
pi@raspberrypi:~/habridge/data$ sudo nano habridge.config
and in that file was the harmony with the old ip adress.. then i changed the harmony ip in this file.. and after i did this i was abbly to see my harmony in the habridge...
jeroenvanpelt
Post by jeroenvanpelt » Sunday 29 January 2017 21:24
Have you stopped and started the ha-bridge after you updated it? From the log you quoted earlier, it looks like ha-bridge can't read your device.db.
Let's start at the beginning: How did you update ha-bridge? I have done so this morning by just downloading the 4.1.0 jar file and placing it in the habridge directory I had created. After that I killed the old ha-bridge process. After updating the starthabridge.sh script with the correct version, I started ha-bridge again.
Thomasdc
Post by Thomasdc » Sunday 29 January 2017 21:37
jeroenvanpelt wrote:Have you stopped and started the ha-bridge after you updated it? From the log you quoted earlier, it looks like ha-bridge can't read your device.db.
no i didn't stop the old one, i just installed the new one (following the instructions on github) but i did a reboot of the rpi allready.. the old habridge didnt start up at reboot..
yeah i changed the Starthabridge.sh script to the new version..
but it still doens't work to edit the config file from the webinterface
jeroenvanpelt
Post by jeroenvanpelt » Sunday 29 January 2017 21:44
That is really strange. I am just trying to eliminate most likely causes. Did you start starthabridge.sh as root? Is the data/device.db file there if you check from the command line? Is the config file in the data directory?
And, do you see any of the config you did before the update?
Thomasdc
Post by Thomasdc » Sunday 29 January 2017 22:11
jeroenvanpelt wrote:That is really strange. I am just trying to eliminate most likely causes. Did you start starthabridge.sh as root? Is the data/device.db file there if you check from the command line? Is the config file in the data directory?
the only thing i saw in the config from before the update was the harmony hub with the old ip.. (my devices that i added allready (with manual ad) were gone)
pi@raspberrypi:~/habridge/data$ ls
device.db habridge.config
so it is all there..
and this is how i started it:
pi@raspberrypi:/etc/systemd/system$ sudo nano habridge.service
pi@raspberrypi:/etc/systemd/system$ sudo systemctl daemon-reload
even when i try to delete the harmony hub in the bridge control it appears again when i click the "save" button..
its just like that the "save" button doesnt change the config file..
i
jeroenvanpelt
Post by jeroenvanpelt » Sunday 29 January 2017 22:23
Thomasdc wrote: [codepi@raspberrypi:~/habridge/data$ ls
[/code]
so it is all there
Can you do a 'ls -l' on your data directory, so we can check the permissions to be absolutely sure?
And, the contents of your service file?
Sent from my Nexus 6P using Tapatalk
Users browsing this forum: No registered users and 4 guests
