domoticz in synology as package! Available now.
jeroenkl
Re: domoticz in synology as package! Available now.
Post by jeroenkl » Saturday 01 July 2017 7:39
mvveelen wrote:I installed Domoticz on my MacBook and used the latest DB. It ran pretty well and I was able to disable all lua scripts under Events. Saved the DB and uploaded it to my Synology: everything fine. So I switched on a few lua scripts and about halfway Domoticz wasn't reachable anymore. So now I'm running it with just the most important lua scripts enabled.
Tomorrow I'll have another go at it.
Same issue here, went back to version 3.8005 and running smoothly again with very low CPU load.
Wondering the root cause of failure.
mvveelen
Post by mvveelen » Saturday 01 July 2017 9:41
EdKo66 wrote:I'm having the same problem (I think), as @mvveelen. Once or twice a day the complete NAS (413J) seems to come unreachable and needs to be restarted.
already have a topic open for that on the Dutch forum (https://www.synology-forum.nl/synology- ... /msg225817), but a solution has not yet been found.
I don't think it's the same problem. I can reach and use my NAS and all other packages on it. Only Domoticz is giving me a hard time. When I add a few lua scripts, the NAS is soon running on 99% and I can't open Domoticz anymore in the browser. Other packages, nzbget, sickbeard, etz. are still working and can be reached via the browser.
I saw a sql process running at about 50% and stopped Spotweb and MariaDB (updated MariaDB a few days ago), but still the same result.
Where did you find that version? Willing to try !!
Synology DS414 DSM6.1 + RFXCOM rfxtrx433E + Xiaomi Gateway + Philips HUE Lights + Nefit Easy + Dashticz v2 + Domoticz latest Beta
mvveelen
Post by mvveelen » Saturday 01 July 2017 10:57
Jadahl manage to send me a package for my DS414 with Domoticz version 3.8005 and that is running fine now for about 15 minutes. One dead (Zwave) node, so I have to figure out what that is all about, but everything else seems to be smooth and steady !
jeroenkl
Post by jeroenkl » Sunday 02 July 2017 11:11
Waiting for Jadahl to have the armadaxp version ready to be able to test 3.8034 ;-)
mvveelen
Post by mvveelen » Sunday 02 July 2017 11:14
He won't be back for another 14 days and so he will probably release a newer version than 3.8.034 :D
tweakertje
Post by tweakertje » Thursday 06 July 2017 16:37
how can I downgrade an keep the database scrips and settings I made?
My problem is that curl is not working in scripts after upgrade tov 3.8005
or does anyone have an solution.
mvveelen
Post by mvveelen » Thursday 06 July 2017 17:28
Curl works for me on my Synology with the same version.
Edit:
If you still want to downgrade, you will need the .spkg package for your Synology (I'm guessing you run it on your Synology?), and you will have to backup your scripts first and make a backup of your DB within Domoticz. After that you have to delete Domoticz and install the .spkg manually, import the DB and upload your scripts (set the CHMOD to the right values).
EdwinK
Target OS: Raspberry Pi
Post by EdwinK » Wednesday 12 July 2017 10:18
Anyone else having problems visiting Jadahl's website? I needed his Synology package for the 413J, but although the site seems to be up, I can't seem to connect.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
EdwinK
Post by EdwinK » Wednesday 12 July 2017 10:30
Also, the package manager can't reach it.
manutremo
Post by manutremo » Wednesday 12 July 2017 14:47
Yes, jadahl site seems to be down.
EdwinK
Post by EdwinK » Thursday 13 July 2017 15:52
Works again :)
mvveelen
Post by mvveelen » Tuesday 25 July 2017 19:18
Just updated to the latest, but now I get this error message:
2017-07-25 19:15:49.011 Error: EventSystem: in /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: cannot open /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: No such file or directory
The dzVents.lua isn't there. Does anyone have this file for me so I can shut this error down....?
Edit:
switching off dzVents (which I'm not using) solved the sh*tload of errors :)
EdwinK
Post by EdwinK » Tuesday 25 July 2017 19:27
I thought there are some problems with the Domoticz and Synology atm.
O.. new version is out there.
mvveelen
Post by mvveelen » Tuesday 25 July 2017 19:29
The path also doesn't seem right, it should be something like:
/volume1/@appstore/domoticz/var/scripts etc. right?
So Domoticz does work for now, but the log is cluttered with this error message. Every 1 or 2 seconds .....
EdwinK
Post by EdwinK » Tuesday 25 July 2017 20:22
I turned off Dzvents for now.
matsumoto
Domoticz version: V3.8134
Post by matsumoto » Wednesday 26 July 2017 0:00
same here !
digimate
Domoticz version: lastbeta
Post by digimate » Wednesday 26 July 2017 9:49
@jumbotroll : Thanks, your back again with updated releases. :)
Hopefully we're soon also able to use dzVents 2.x, cause now it doesn't work and do we have to disable it to prevent errors.
Thumbs up for your great help!!
Synology DS716+. Domotica devices (on about 30): KaKu (and other 433MHz devices), Z-Wave, Mi-Light, Xiaomi.
mvervoorn
Post by mvervoorn » Wednesday 26 July 2017 16:15
I have got the same error message. Where and how can I disable dzVents?
EdwinK
Post by EdwinK » Wednesday 26 July 2017 17:44
In setup/settings/other
Check the box before 'disable dzevents'.
gomario
Post by gomario » Thursday 27 July 2017 4:22
Hi guys. I've been using domoticz for a couple of years but it's my first time on Syno. So I'm really sorry if this sounds stupid, but...
I'm running DSM 6.1 on 215j.
I didn't really want to chance it with beta package for 6.1 as I run quite a lot of different devices and sensors and re-installs are usually a serious pain.
I'm bit lost trying to navigate the version numbering used in the Jadahl package source. For comparison...
My Raspi runs latest stable 3.5877.
On Syno I used http://www.jadahl.com/domoticz_stable_6/ - Which is marked as 3.5877 - once installed shows as 3.5876 So why is it only 76? Am I supposed to update after installation? From what I understand I can only disable built-in update check and update through package center. Which shows no update. So am I missing something or is it a typo on Jadahls web?
Also...
When I try to add source for 6.0 beta or 6.1 beta I am offered Domoticz v3.0.7067-7 and v3.0.8134-7 respectively.
What version are these...? Domoticz Git only shows 3.5878 and 3.7988 ... I mean..Jebus, my head is spinning!
From what I see here... if I can live without scripts (DzVents) beta seems quite stable... Is it worth the possible risk?
Thanks in advance for any help with this cluster**** of a question!
