cheap(er) p1-to-USB cable for smart meter (looking for a ...)
Dirk
Target OS: Raspberry Pi
Post by Dirk » Wednesday 30 August 2017 19:24
I want to have Domoticz make a readout of my Smart Meter (Dutch, Stedin). On Dutch shops I find cables starting from 20 euro's. On AliExpress I found this cable for 6 euros (including shipping): https://nl.aliexpress.com/item/ftdi-ft2 ... 4.8.vkFUnV
But the amount of technical info (in hard-to-understand English) overwhelmes me. Is this the same cable and will it work to connect my slimme meter to my Domoticz? (Otherwise: suggestions for cheaper alternatives welcome; I already found a DIY post but that is not feasible for me).
migwelly
Re: cheap(er) p1-to-USB cable for smart meter (looking for a ...)
Post by migwelly » Sunday 03 September 2017 20:37
Dirk wrote:I want to have Domoticz make a readout of my Smart Meter (Dutch, Stedin). On Dutch shops I find cables starting from 20 euro's. On AliExpress I found this cable for 6 euros (including shipping): https://nl.aliexpress.com/item/ftdi-ft2 ... 4.8.vkFUnV
This cable Might work.
For some meters, you need to do a modification by soldering a pull - up resistor.
It also depends how they crimp the wires in the RJ 11 connecter.
You only need 3 wires.
5 v
Ground
Rxd
And sometimes the chip needs to be programmed if it is not done by the supplier.
Best,
Migwelly
Dirk
Post by Dirk » Tuesday 05 September 2017 9:44
Ah, OK. Well 'might work' is not good enough for me I'm afraid. Since I'm a newby and have the time nor experience to do modifications myself, I think I'll either wait for a recommendation of somebody that has tried or just spend the 20 euro's. Thanks a lot for you response!
JimmyH1969
Post by JimmyH1969 » Tuesday 05 September 2017 14:02
Have you ever thought of a WiFi solution? I have a small Wifi ESP8266 adapter connected to my Stedin smart meter and connected it to Wifi.
In Domoticz you can add a "P1 smart meter with Lan interface" and connect it to the P1 Wifi module. Works great overhere.
Not sure if i'm allowed to do this, but it's not as spam intended:
http://www.esp8266thingies.nl/wp/
migwelly
Post by migwelly » Thursday 14 September 2017 12:58
Dirk wrote:Ah, OK. Well 'might work' is not good enough for me I'm afraid. Since I'm a newby and have the time nor experience to do modifications myself, I think I'll either wait for a recommendation of somebody that has tried or just spend the 20 euro's. Thanks a lot for you response!
Which meter do you have?
Dirk
Post by Dirk » Thursday 14 September 2017 21:39
@migwelly I have an iskra am550, provided by Stedin.
joost81
Post by joost81 » Friday 15 September 2017 10:40
I've bought a cheap cable from ebay. For most smart meters you need to invert the RxD signal in the FTDI chip.
Most of the China copies are read only, you cannot reprogram them.
So in the end I bought a cable of €20 which is already programmed and has the right RJ11 connector on it. Works out of the box.
Dirk
Post by Dirk » Saturday 16 September 2017 13:33
Yeah thanks @joost81. I figured as much: either fiddling to make it work or spend the 20 euro's on a ready-to-go solution. I was hoping to find some kind of deal, like those 6-euro thermometers...
migwelly
Post by migwelly » Monday 18 September 2017 21:28
Dirk wrote:@migwelly I have an iskra am550, provided by Stedin.
Yes, it will work.
You need to do some modification.
You need to solder a 10K resistor (Pull-up resistor ) between 5 V and RXD
You also need to invert the signals of the FTDI chip.
You need to use FT-Prog for that.
If you need help with that, just sent me a private message.
Dirk
Post by Dirk » Monday 18 September 2017 21:46
Thanks for your offer, but since I've never soldered before, I have neither the experience or equipment to do that.
I'm currently too busy to dive into that, so I'll either wait a bit (until I stumble upon a cheaper cable) or pay the full retail price.
pvm
Domoticz version: Stable
Post by pvm » Monday 18 September 2017 22:03
Yes, it will work.
Is it also possible to convert a ready made cable to work with the latest iskra?
My cable works on a 10 yr old meter but not on the new one
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
migwelly
Post by migwelly » Saturday 23 September 2017 11:10
pvm wrote:
Yes, it will work.
What cable do you have?
And what chip is inside? Like ( FTDI,... Etc)
Best,
Migwelly
pvm
Post by pvm » Saturday 23 September 2017 14:18
How can I see that?
It is not possible to open the connector and check the chip
Draakje
Domoticz version: 3.5468
Post by Draakje » Monday 27 November 2017 21:19
I would like to chip in this conversation as my meter has just been replaced by the ISKRA MA550 (And metering does not work.
I believe I have the FTDI chip (Profolic cable)
Could you make something like a schematic ?
(I can handle a soldering device :P)
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
EnderWolf
Post by EnderWolf » Sunday 13 May 2018 0:56
I got a ISKRA AM550 meter a little while ago and I bought a Serial converter with a FTDI chip embedded into the pcb, however I am not seeing any data. The manufacturer of the cable has put a 10k resistor between RXD and RTS.
Should I move the Resistor to be between RXD and +5v?
Kind regards,
EnderWolf
Edit: Found the problem, the RTS and RXD cables were incorrectly mapped, after swapping those back the cable is working.
